Rx8 Gps
Old May 3, 2007 | 04:36 AM
microjax's Avatar
Rx8 Gps
Any of you having the Build-in GPS system?
Is your Japan Spec GPS?
could it use in SG/MY? any known kits, add-on or mods can make it work?
please share.
Old May 3, 2007 | 10:15 PM
jaii13's Avatar
Try this;
http://www.automotivesynergy.com/gps.htm
http://www.navisolutech.com/l500.htm
Both links I got from this site. Read around more for details on it.
Old May 4, 2007 | 07:02 AM
airspeed's Avatar
Velocity REight
Originally Posted by jaii13
Try this;
The Garmin costs ard US$600(unit only) + US$249 for S'pore/M'sia maps on SD card.
The L530 was SGD$1150 last I enquired. Comes with free S'pore/M'sia map.
Old May 7, 2007 | 04:59 AM
hellangel's Avatar
bro u will get lost in singapore meh?
Old May 7, 2007 | 10:26 PM
jaii13's Avatar
Cheaper Garmin GVN-52 found here:
http://www.sltsb.com/prod01.htm comes with Msia & SG map.
Old May 16, 2007 | 09:26 PM
microjax's Avatar
Thanks a Lot, I am the one always get lost in Malaysia FxxKing roadsign.
Old May 16, 2007 | 09:29 PM
microjax's Avatar
Hi Jaii,
Is this GVN-52 able to connect to RX8 build in LCD TV?
Old May 16, 2007 | 09:44 PM
sebmoy's Avatar
Hi jaii,
Thanks for this info. Have you install one yourself with the GVN-52. I would like your feedback on this if you do use one. I called up the shop and they don't do installation. So I wonder if it's ok for any accessory shop to do it. The shop owner claim it's pretty easy to install.
cheers!
Old May 16, 2007 | 11:49 PM
jaii13's Avatar
Originally Posted by microjax
Hi Jaii,
Yes.
Originally Posted by sebmoy
Hi jaii,
cheers!
I don't have one yet, but all that is needed is the video output. Very straightforward.
Old May 17, 2007 | 02:34 AM
lennon's Avatar
I got plug-in type GPS...... Can change to other car whenever you like....
Old May 17, 2007 | 02:50 AM
jaii13's Avatar
Which one do you own? Can use back the built in screen?
Old May 17, 2007 | 03:14 AM
woodtcb's Avatar
CLK & Z4
buy one GPS handphone better la..only rm1500....
05TR1CH
Apr 18, 2023 04:56 AM
SupraG
Sep 21, 2015 12:09 AM
talonhart2
Aug 26, 2015 04:14 PM
dbarber
Jul 25, 2015 01:34 PM
RX7.9
Jul 20, 2015 12:01 PM
