Transmission Fluid Flush
Old May 1, 2007 | 12:59 PM
AdamTay's Avatar
Ok, read a few threads for DIYs on changing your transmission fluid etc. but I can't quite find out if the dealer is trying to con me or not....
'04 AT, in for a regular service.
Apparently the dealer notices the transmission fluid is 'a little dirty' and wants to flush the whole system. Apparently this is more than just topping up 2 or 3 quarts and involves replacing everything (something like 12 quarts?).
Anyway, they want $195, deal or no deal?
Old May 1, 2007 | 01:10 PM
mikeb's Avatar
100% Italian
195 seems high
i think i paid 150 last week or something
Old May 1, 2007 | 02:13 PM
I will say
No ******* DEAL
Come on. I mean ATFs are CHEAP!
Old May 1, 2007 | 02:31 PM
AdamTay's Avatar
Just found $120 at another local dealer. That seems to be a little better.
Old May 1, 2007 | 02:38 PM
mac11's Avatar
Rotary , eh?
i would say to change/flush as recommnded in the owners/maintinance manual
anyone knowledgable in the trans business will tell you those flush machines are all overpriced marketing hype, just get a standard drop the pan and refill flush at an old school trans shop
Old May 1, 2007 | 03:02 PM
AdamTay's Avatar
Current quotes stand at $99 for drain/refill or $120 for full flush. Worth the extra? Perhaps just going to some 'old school trans shop' would save me a bunch on the drain/refill?
Don't have the owners manual to hand the moment, but I'll give it a read later...
Thanks all.
Old May 1, 2007 | 03:06 PM
Do it yourself.
Its Fun. and cheaper.
Old May 1, 2007 | 03:10 PM
AdamTay's Avatar
I'm a little new to all this stuff, but when people talk about doing it themselves, they seem to be replacing 2-3 quarts, but the dealer seemed to suggest there was much more to be replaced throughout the whole system? And that they use some 'flushing machine' to clean it all out a little more thoroughly?
a DIY does sound like more fun though.
mac11's Avatar
Rotary , eh?
yea...the ATF to fill the trans yourself would prolly cost <$20
Old May 1, 2007 | 04:19 PM
devildog1679's Avatar
Book says 1.85 quarts. I used almost 2.
Old May 1, 2007 | 04:27 PM
AdamTay's Avatar
I think that for a manual, the owners manual seems to suggest 9.2 quarts of automatic transmission fluid.
Is the replacement procedue the same?
Old May 1, 2007 | 05:20 PM
CosmosMpower's Avatar
1935 lbs. FTW!
Do it yourself, I did my manual tranny for 20 bucks.
Old May 1, 2007 | 05:39 PM
mysql101's Avatar
thats about right for the MT, but they're talking about AT.
Old May 1, 2007 | 07:04 PM
mac11's Avatar
Rotary , eh?
i believe for an auto you are going to drop the trans fluid pan drain and clean it and then reinstall. At least thats how it was on a few of the cars I used to work on. That way you will be able to clean all the shavings off the magnet in the pan and be sure you have a (nearly) debris free tranny.
Old May 1, 2007 | 07:17 PM
I'm going to give you this:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-tranny-fluid-change-auto-74759/
in exchange for you learning how to use this:
https://www.rx8club.com/search.php
Old May 1, 2007 | 07:49 PM
AdamTay's Avatar
tried all combinations of 'automatic', 'transmission', 'flush' and 'fluid' in the search, but only found the MT version.
cheers.
Old May 1, 2007 | 10:29 PM
OOPS, I need to get glasses.
Old May 1, 2007 | 11:58 PM
ninjarama's Avatar
ninjarama
letting loose 9.2 quarts of transmission fluid? better get one of those gigantic sized oil containers lest you get tranny fluid spilling all over the place... won't be fun to clean up!
Old May 2, 2007 | 12:41 AM
Old Rotor's Avatar
Did you see this "TSB" about the changing and flushing of the A/T. Look down the page til you find this one.....
AUTOMATIC TRANSMISSION COOLER/LINES FLUSHING PROCEDURE
http://www.finishlineperformance.com...ins_index.html
Old May 2, 2007 | 02:26 PM
AdamTay's Avatar
Interesting thanks. It does seem to suggest there is significant advantage to flushing over a simple drain and refill, which doesn't seem to be everyone's opinion.
Old May 3, 2007 | 06:15 AM
ninjarama's Avatar
ninjarama
That does not look like fun! I liked chaning the fluids on my MT better... I wouldn't say that's fun either, but much simpler to say the least! Support the car on 4 jack stands, unbolt trans. -- drain, rebolt & refill...unbolt rear diff. -- drain, rebolt & refill. The only thing that would mak it easier is if you could fill from the top like engine oil =)
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
XianUnix
Sep 29, 2015 03:48 PM
