my car doesnt burn oil at all!!
Old Apr 22, 2007 | 03:40 PM
steven000e's Avatar
I will forever miss my 8!
is that normal.?
4367 miles sinse last oil change, getting it ready for a newone this friday. But sinse i bought it i have had not added any oil.
at the beginning i used to check every 2 weeks (no change)
now i check may be once a month or sometimes twice but "the oil is always in the same spot in oil stick"
is there something wrong with my car?
I drive it hard most of the time...
ps: its a 2004 model with 34000miles
Old Apr 22, 2007 | 03:46 PM
staticlag's Avatar
The Professor
used?
my oil consumption slowed greatly after the recall flash also. Nothing to be worried about.
Old Apr 22, 2007 | 05:12 PM
tajabaho1's Avatar
Destroying Threads
I thought you ment gasoline....I was like @.@
Old Apr 22, 2007 | 06:34 PM
supergoat's Avatar
I don't "smell good".
My 05 went through a quart every 1500miles.
My 04 so far has been much less thirsty. Went 1000 miles in it so far and the level still shows full.
Old Apr 22, 2007 | 10:50 PM
i am in the same club.. i drive lots of hiway miles. i almost never have to add any between changes...
you do realize that the from the top of the fill line to the bottom is 1.75 qts. i think..
Old Apr 22, 2007 | 10:52 PM
Nemesis8's Avatar
Bigus Rotus
Weird, but you would have thrown a CEL if the MOP was faulty.
Old Apr 22, 2007 | 10:55 PM
TomAssBender's Avatar
Skeet skeet skeet
thats weird since i thought that flash included MORE oil in the system
Old Apr 23, 2007 | 04:25 AM
Mistersql's Avatar
GT Lightning Moon
Mine used to not burn that much if any between changes. But in the last 6 months or so I've had to top it up regularly.
Old Apr 28, 2007 | 09:37 PM
Buford's Avatar
Adrian Monk Clone
Red face sorry in advance for my dumb question
I'm a newbie to the whole rotary engine concept (and pretty new to this forum). "It burns oil" is the first thing you hear people say when you tell them you're considering buying a rotary.
I figured there must be some info on this in the FAQ area, but I couldn't find it. I'm sure there must be some sort of info on this. Could someone post up a link to it... or maybe just give me a quick "rotary 101" on it.
Is the engine designed to burn oil... or is more of a shortfall of the design?
Old Apr 28, 2007 | 10:23 PM
psychodad's Avatar
Mulletproof
That is the word on the street.
I tend to check my oil often anyway, and after my first 3/4 of a tank, there was a visible indication of usage on the dipstick. Given that by all accounts the thing is supposed to consume oil, I would be concerned were mine not.
Old Apr 29, 2007 | 12:42 AM
cleoent's Avatar
n00b
i've never had to fill up my 04. Between changes it stays fine... go figure.
Old May 26, 2007 | 08:04 PM
chmod's Avatar
It is not a shortfall of the design, but a necessary design decision. In order to keep a proper seal between the rotating combustion chambers (the apex seals) some oil is injected into the combustion chambers. So, yes it burns oil... but not in a bad way like when a piston engine starts burning oil. Read some of the posts on oil choice for more info.
Old May 28, 2007 | 10:42 AM
GRGJTSN's Avatar
vV Me on the Dragon Vv
I've had my used '05 for about 1200 miles now (26k total), and it didn't appear to use any at first...I just now can barely see a drop in oil level, not even enough to worry about adding any yet.
mr. GrandGame
Sep 9, 2025 10:41 PM
Skyl3r
Dec 2, 2019 04:51 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
dbarber
Jul 25, 2015 01:34 PM
RotaryRider
Jul 20, 2015 07:05 AM
