dsc flashing
Old Sep 23, 2003 | 01:55 AM
mikeb's Avatar
100% Italian
dsc flashing
my check engine light came on so I disconnected negative on battery waited and then turned car back on. check engine light is off now but dsc is flashing. Does anyone know how to fix that
Old Sep 23, 2003 | 04:02 AM
RobDickinson's Avatar
Theres a wheel alignment process that you turn the steering full lock etc but I cant remember the details.
Resets the DSC.
Is on that tech highlights cd, may be in the manual.
I'm sure someone else has all the details.
Old Sep 23, 2003 | 06:23 AM
tpryor's Avatar
Resets the DSC.
From the pdf version of the Owners Manual:
NOTE
If the battery is disconnected, the DSC
will be inoperable. In this case, the DSC
OFF indicator light flashes and the
TCS/DSC indicator light illuminates.
To make the DSC operable, do the
following procedure.
1. Turn the ignition switch to the ON
position.
2. Turn the steering clockwise fully,
then turn it counterclockwise fully.
3. Make sure the DSC OFF indicator
goes off.
4. Turn the ignition switch to the OFF
position, then turn it to the ON
position again.
5. Make sure the TCS/DSC indicator
light goes off.
If the TCS/DSC indicator light and the
DSC OFF indicator light remain
illuminated even after turning the
ignition switch to the ON position,
consult an Authorized Mazda Dealer.
Old Sep 23, 2003 | 07:56 AM
eccles's Avatar
Prodigal Wankler
It's also covered in the little "Quick Tips" booklet that came with the car.
Which begs the question: Don't people read this stuff? Personally, I sat down and read through the manual from cover to cover. If there's anything I should know about the car, I want to know it!
Old Sep 23, 2003 | 12:06 PM
mikeb's Avatar
100% Italian
THank you guys
After I posted this I did a search and found eccles instuctions that were posted to reset dsc. You guys saved me a trip to the dealer.
I love this forum.. Thanks again
Old Sep 24, 2003 | 04:33 AM
Efini 8's Avatar
no pistons!
Originally posted by mikeb
THank you guys
happened to me too, twice, but first time it went off by itself. damn man u got more posts than me and I recommended you to it lol!
Old Sep 24, 2003 | 02:26 PM
mikeb's Avatar
100% Italian
I remember that , you did recommend the forum to me.
I love it
D13
Oct 1, 2015 07:55 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
