West RX-8 Forum Serving CA, NV, AZ, HI
anyone here try the mod "make oem cat into a high flow one"
Old Apr 10, 2007 | 12:41 PM
bao0518's Avatar
I was just wondering if anyone one of us in s.cali try that mod? is it worth it or it's better to buy a $400 high flow cat? I just order my B&B exhaust so i wanted to see if any of us did that mod and if you did, can you let me know the result.
thanks in advance. here the thread for it.
__________________________
Gutting out your Catalytic Converter
1. Take off your cat.
Taking it off is very straightforward.
All you neet is to disconnect the oxygen sensor from the connector jst above it.
Unscrew three 14mm nuts on the front joint, two 14mm nuts on the back joint, detach the 2 horizontal support panels by unbolting 12 mm bolts that hold them in place (4 in each) and finally pulling off the rubber mount.
Even after you take off everything that holds your cat, the pipe will remain in place. To get it off grab a large screwdriver (carefully not to damage the metal ring in there) jam it between the flanges on the front join and using the screwdriver as a lever separate the joint. Once it is out, Just pull the whole pipe out of the rear joint.
2. Take out the Oxygen sensor:
Remove the sensor guard by unscrewing two 10mm nuts.
Unscrew and remove the sensor.
2. Gutting your cat.
Get a 11/2-2 foot long half 1/2" steel rod or something similar ( Home depot for about a buck ) and a hammer.
Flip the pipe vertically with the front (triangular flange facing up)
stick the rod inside the cat opening and using the hammer keep on whacking the internals until the rod breaks through. The is made of 2 parts, meaning that there are actually 2 elements inside that pipe, so when you break the first one, shake the pieces out, and continue whacking on it and shaking stuff out until there is nothing left. Use a light to see inside to make sure that it is empty. When everything is out, you'll see that the inside walls of that (now just resonator) are relatively clear and there is nothing left.
This is it. Now you are a proud owner of a completely stock looking catless midpipe
Reinstall the sensor, and put everything back following the directions above in reverse.
Happy modding.
Old Mar 26, 2008 | 04:57 PM
DanRedRx8's Avatar
What a Nice Ass
im in so cal and i gutted my cat and i have a borla exhaust..... sounds f-ing amazing and i love it.... but no way in hell are you passing the emissions test without a 100$ bribe...
Old Mar 26, 2008 | 05:07 PM
^^^ yup, you'll never pass emissions in CA with a gutted Cat.
Do what I did: buy an RP high flow and save the OEM cat 'just in case'
Old Mar 26, 2008 | 05:09 PM
dozer's Avatar
on his 3rd rx8
thanks for the info bao, ill see if i can come up on an extra cat and do it.
Old Mar 26, 2008 | 05:11 PM
HAHAHA!!!!
I just noticed the banner at the top of the screen, "Honda Catalytic Converters Buy replacement honda catatlytic converters. Plus all new and aftermarket parts"
WTF?! WRONG FORUM GUYS!!!!
Old Mar 26, 2008 | 05:15 PM
dozer's Avatar
on his 3rd rx8
^ahahahahhahhahah stupid honduh!
Old Mar 26, 2008 | 05:28 PM
StealthTL's Avatar
A little search reveals this 'gem'.......
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/best-sounding-exhaust-everrrr-132269/
S
Old Apr 4, 2008 | 08:07 PM
DOMINION's Avatar
I don't buy Kool-Aid
https://www.rx8club.com/showthread.php?t=132269
S
Oh wow lol good thing I never did it. Bet tat 1/2 CAT did not last long lol
Kahl
Aug 20, 2015 11:49 PM
TheWhiteAce
Aug 6, 2015 02:26 PM
dbarber
Jul 25, 2015 01:34 PM
Jvswan
28
Jul 23, 2015 09:02 AM
AussieGray
Jul 16, 2015 03:58 AM
