SevenStock Archive Find threads for past SevenStock events here
Sevenstock RX-8 dyno secret
Old Sep 17, 2003 | 03:43 PM
RodimusOne's Avatar
Sorry If I sounds kinda lost in this forum, but I read somewhere in some previous thread that someone is going to unveil in Sevenstock on why dyno results of the RX-8 so far is incomplete/inaccurate due to the ECU intervention. Is this true, and is someone going to shed some light on what was done by Mazda in the port during those mysterious weeks?
Old Sep 17, 2003 | 04:17 PM
mikeb's Avatar
100% Italian
I havent heard of that
Old Sep 17, 2003 | 04:29 PM
rotarynews.com's Avatar
Banquet
We will have a good number Mazda employees who are players in the RX-8 development, including Ikuo Maeda, RX-8 Chief Designer. There will also be folks like the RX-8 US Manager in attendance (Remeber? the guy last year that showed us the raw track footage of the RX-8 and the Spirit-R RX-7 at the Mazda Proving grounds)
They will be at the banquet, and while they won't have a "press release" information dissemination, there is usually a Q&A session with the folks in attendance.
Old Sep 17, 2003 | 04:33 PM
mikeb's Avatar
100% Italian
nice
I'm sure somethings will clear up then
Old Sep 17, 2003 | 05:21 PM
RodimusOne's Avatar
To Rotarynews.com member,
I think you mentioned in some other thread (I can't seem to find it now) or dropped a hint that the "federal government" is to blame for this, and that you and/or someone will disclose the secret of this hp mishap during sevenstock. Please clarify on this - does anyone recall what thread the above mentioned issues/comments were placed in?
Old Sep 17, 2003 | 05:30 PM
here is where Dan said it the first time in response to someone not believing Bern.
Old Sep 17, 2003 | 05:35 PM
Gord96BRG's Avatar
Here's the first quote you're looking for:
Originally posted by bern
Guys,
Through some research and talking to a few folks, I can speculate with high degree of certainty, that the RX-8 is pulling back some timing and adding fuel up high, to protect the engine while on a chassis dyno. This among other things. If my understanding of the matter is correct, the sophisticated 32-bit ECU collects data from several inputs to implement the operational fuel and timing maps. It seems that some of the inputs that the ECU is receiving, while on a dyno, is telling it something is not absolutely correct, and that it should use, what I would term, safe maps.
I have not been able to absolutely confirm all of this information, but it seems to be a very plausible explanation for the descripency between 1/4 times and dyno results.
And here's the second quote:
Originally posted by rotarynews.com
These cars can't be dynoed. and obtain the same results as street driving (with the US ECU program)
See me at SevenStock for info on why :D Here's a hint though, the federal government is to blame
They're both from this thread: Dyno results w hard data (on a known dynajet)
Regards,
Gordon
Old Sep 17, 2003 | 06:13 PM
RodimusOne's Avatar
Thanks zoo44 and Gord96BRG for your prompt replies!
So from what was posted, I am assuming rotarynews.com will have something to say how the dyno hp losses/ECU/federal govt are connected during Sevenstock. Please confirm this rotarynews.com.
Old Sep 17, 2003 | 06:19 PM
I'm not going to get up on stage and announce it, but I will be able explain in person.
Plus, the people who designed the car will be there, so ask them
Old Sep 17, 2003 | 06:35 PM
RodimusOne's Avatar
Thanks for the reply,
Can you drop another hint - Is there a way to remedy whatever the fed govt/ecu did to get the ponies back up? If it's fixable, then I'm sure it'll give a lot of us, the 2004 RX-8 owners, the peace of mind that eventually, we'll get what we paid for.
Old Sep 17, 2003 | 06:48 PM
Gord96BRG's Avatar
Sure - from what Bern has said, the easy remedy is to stop driving on a dyno and drive on the street! In other words, what he said is that there are reasons why the car is dynoing at lower than expected hp levels, but that the car is making the rated hp on the street. It's a problem that shows up only when on a dyno. On the street, you are getting what you paid for.
Regards,
Gordon
Old Sep 17, 2003 | 07:00 PM
There are two issues we are seeing here:
1. The RX-8 cannot be rear-wheel dynoed
2. Reduction in horsepower from the 247 (or the Jspec)
But both of these issues are caused by the US federales estupido...
Old Sep 17, 2003 | 07:15 PM
RodimusOne's Avatar
Federal gov't and their intervention.....
But back to the question - is there a way to fix what the fed took away from my new ride?
Old Sep 17, 2003 | 07:19 PM
mikeb's Avatar
100% Italian
I guess you will have to wait to get that answer
Old Sep 17, 2003 | 08:15 PM
test driver's Avatar
So, the car can detect when it's on a dyno, and modify the engine controlling as a result?
According to the EPA, that's exactly the definition of a "Defeat Device," and that's VERY against their rules.
If this is true, expect EPA to be issuing a recall as soon as they find out.
...and somewhere, and engine calibration engineer will be falling on his sword...
Old Sep 17, 2003 | 08:18 PM
mikeb's Avatar
100% Italian
what
Old Sep 18, 2003 | 03:05 AM
jmanolov's Avatar
Ok, you say it may turn out the car can not be measured at the dyno because the ECU retards smth knowing the car is not moving.
What about a GTechPro Competition?
The car is moving in real world, and the GTechPro Comp is a quite accurate device. Or you say the RX-8 smart ECU even detects our thoughts about attaching g-meters to the car and hides the horsepower just like on a dyno.
I can't say more but check an upcoming issue of Sport Compact Car related to GTech and RX-8 :p
Old Sep 18, 2003 | 07:05 AM
rxeightr's Avatar
M0D Squad -charter member
Would that be their next issue, by chance?
Old Sep 18, 2003 | 07:34 AM
j1mb0x99's Avatar
Caution!
Guys,
The 8 has a 32 bit ECU? That is quite a bit of processing power for a car. I wouldn't be surprised then if it has different maps for for various conditions like snow/ice, break-in, a malfunctioning part, and others. Therefore, when it's on a dyno the car might think its in a various condition and implement a different map for it causing lower h.p. We could have a very smart car on our hands.
I have no idea if this is even plausible, it was just a thought I had. Also I have no idea if this has been discussed before, I have tried to stay away from all the dyno/hp threads.
-JiM
Old Sep 18, 2003 | 03:11 PM
bern's Avatar
Guys:
Don't forget my 3rd quote:
As far as SevenStock, I hope you all can come and visit with us. I won't be speaking on this subject at all, but Dan sure seems to think he can...
I'm not even sure what Dan can or will say, so I'll be looking forward to this too . There will be Mazda Product experts at the event, that will hopefully shed some light, but I doubt they will be saying anything specific. I'm just not sure that they will talk directly to this issue, there will probably be a party line at SevenStock!
On the Federal Goverment thing, this was put out by Mazda direclty, a few weeks ago, also in the general press.
-Bern
Old Sep 27, 2003 | 02:43 PM
FutureRX8owner's Avatar
Pity those of us who can't make it to Sevenstock this year and post any details that you hear from the Mazda folks. Thanks!
Old Sep 29, 2003 | 11:48 AM
jsotelo's Avatar
Okay fresh from Sevenstock.. the RX-8 guys hit Mazda pretty hard with questions on HP.. and when you read between the lines this is what the deal is.
Mazda re-flashed the ECU to fatten the mixture. That seems to be it. They said they did it for a number of reason.. the biggest seems to be that new cars have to have a cat that lasts for 10+ years.. running lean will kill the cat before that so they had to change the map. Then they went into this crap about how hot the cat gets when running lean and starting fires but I don't buy that. It was also hinted that if you get ahold of a J-spec ECU it will plug and play and give you full HP.
The test cars the journalists used were running 100 octaine with the J-spec ECUs. The ECU will give mo powah with higher octaine.. or at least it did before they changed it. The Japanese Renesis guys freaked when they found out that Cali only has 91 octaine and told them to put in 100 for the tests.
Mazda says that you need at least 91 octaine to get good HP out of the car but it will run on 87 and the engine will de-tune itself to avoid detonation.
Mazda (inadvertatly) admitted to a fuel starvation problem on the track once you get to about 3/8 of a tank. They are working on a fix and it sounded like they had one before they basicly told the guy to shut up. Sounds like the pickup in the tank isn't in the best spot but you won't notice this in daily driving.. only track days.
Once again if you read between the lines.. they are testing a turbo Renesis right now but they refuse to admit it. They said they are testing various different versions of engines and some include forced induction.
Lastly.. Mazda says that if the RX-8 doesn't sell around 2000-2500 cars a month it will be considered a failure and not to expect any other rotary cars any time soon.
Old Sep 29, 2003 | 12:15 PM
med_mx6's Avatar
mikeb, i had to think about this too... I'm going to assume in CA they strap your car on a dyno to test emissions at different speeds/loads. but does this mean all cars, or just cars with OBD-I?
here in texas, for cars with OBDII ('96+) they just plug into the ECU and so the "defeat device" is not relevant.
Old Sep 29, 2003 | 12:16 PM
Speed Racer's Avatar
Certified track junky!!!
jsotelo,
Thanks for the update from SevenStock. As for the fuel starvation problem, I can say that it does exist and it reared its ugly head when I was at Watkins Glen. The car cuts out in the upper revs when the tank is about 1/4 full. After I pulled off the track and let the car sit for a moment I was able to limp it back to pit row.
Old Sep 29, 2003 | 12:18 PM
med_mx6's Avatar
does this mean world wide sales? or just north america? if it's just the good ol' US, that's 400 to 500 cars per state! personally, i don't see it happening... which makes me _very_ sad.
thanks for the SS footnotes...
