Magentic Reverse Sensor
Old Mar 2, 2007 | 09:39 PM
blackgt's Avatar
hi folks,
anyone installed the holeless reverse sensors? Those that stick a strip of magnectic sensor onto the reverse of the rear bumper... is it good? Also what is the price and where to install... thanks!
Old Mar 2, 2007 | 10:31 PM
DarkBrew's Avatar
Extraordinary Engineering
Old Mar 3, 2007 | 03:53 AM
blackgt's Avatar
wah lau ... me referring to those reverse sensor that doesn't need to drill 2 holes on the bumper kind lah ...
Old Mar 3, 2007 | 06:05 AM
INXS's Avatar
INXS
ang moh si bei kpo.
Old Mar 3, 2007 | 06:52 AM
Silver_Z's Avatar
As long as magnet not strong enuff to pull car towards railing and smashing back windscreen(On Stomp now), I think it is good.
Old Mar 3, 2007 | 11:10 AM
seraph's Avatar
i've got the magnetic reverse sensors on my car..
the distance it senses isn't as far as the drilled ones so when it starts beeping, you know you are pretty close. So when you use this, you gotta be a little more careful. Check the instructions which comes with the box, it will tell you the rough distance for the beeps. I would tell you, but i've forgotten
The beeping is also not as sharp, and personally, i think that sounds better. I would call it more like a chime rather than a beep actually.
Also, one thing about the beeping is that when you are too far for the sensor to sense anything, ie, over for example 2m away from the wall.. the reverse sensor doesn't beep unlike the drilled ones which start beeping no matter how far you are away from anything.
mine also has an "engaged" chime when i put my gear into reverse. goes "di du di" or "ti tu ti" something like that.. haha..
Old Mar 3, 2007 | 01:34 PM
mkl22's Avatar
dont waste time with those concealled reverse sensors. quite useless. got rid off mine and used the normal ones. much more accurate.
Old Mar 4, 2007 | 06:52 PM
blackgt's Avatar
is it a feature of the 8 that when i put the 4AT gear to R, there is a bee bee sound? Mine have no reverse sensor installed..
Old Mar 5, 2007 | 07:49 AM
Freestyle's Avatar
Renesis Perfection
Yes. Very misleading right? Beeping sound even though there's no reverse sensor! Imagine if you loan someone else your car and he/she reverses it right into the wall because of the beeping!
Old Mar 5, 2007 | 06:30 PM
blackgt's Avatar
harharh... oh ... i was the stupid one who thought the car came with the reverse sensor and almost crash onto the wall when parking!! .. feel so silly after that.. harhar
so anyway to disable the beeping.. cannot imagine after installing the reverse sensor, there will be 2 sets of beeping...
Old Mar 7, 2007 | 09:58 AM
FlyingAce's Avatar
...Sunset Drive...
I have the same type as the one Seraph has. Given by the PI. just 2 words to describe... IT SUCKS!
It doesnt sense properly at all. After complaining, the installer told me frankly he has received many complaints from other users. Probably Seraph is the only lucky one.
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
