Catalytic Stud Question?
Old Feb 27, 2007 | 01:13 AM
grinn253's Avatar
Question Catalytic Stud Question?
Hello,
While removing the Cat a few days ago, the 3 bolts (near the engine side) were stuck pretty good. So i used some "Liquid Wrench" as well as "PB Blaster" (could not find Kroil oil locally ). After letting the Cat sit for 2 nights and respraying the bolts periodically, the nuts were still stuck on. I now ventured on to a butane torch to heat up the nuts. This somewhat worked, as the nuts fell off...taking a piece of the bolt with them. Doh! At least i was able to get the Cat off.
Question is, does the 3 bolts that are on the Cat come off, or are the welded on? They are still stuck on. May I have some suggestions on how to remove the bolts. I recall 'drilling them out' is what others have used, is this true? What type of drill bit is necessary?
Thanks for everyone's time.
Edgardo
The three bolts I am referring to are in the attached pic. (pix courtesy of Swoope from another thread)
Old Feb 27, 2007 | 01:33 AM
lurch519's Avatar
www.evoperform.com
you can bang em out, just be careful
Old Feb 27, 2007 | 09:09 AM
they fit like splined wheel studs, knock them out with a hammer
Old Feb 27, 2007 | 04:39 PM
grinn253's Avatar
Thanks all!
By the way my local Mazda dealership wants ~$6.50 per bolt! Does anyone suppose I can use 'normal' and not 'splined' type bolts for this application? (Automotive grade) So that when i need to remove the Cat again I don't run into this issue again.
Edgardo
Old Feb 27, 2007 | 04:54 PM
Mazda-Rati's Avatar
the WANKEL made me do it
yeah. just go to the hardware store a get 3 bolts, 3 nuts, 3 washers and 3 lock washers. It'll work fine. This is how I did it when one of those nuts sheared off with some of the thread. I haven't had any problems since
Old Feb 28, 2007 | 01:33 AM
grinn253's Avatar
Thanks all!
Using my cousins 4lb hammer did the trick. Thanks for all the suggestions. Here are some pix:
Attached Thumbnails Catalytic Stud Question?-dsc05760.jpg   Catalytic Stud Question?-dsc05761.jpg
Old Feb 28, 2007 | 06:05 AM
Mazda-Rati's Avatar
^nothin like a good ol' baby beater to do the trick!
Old Oct 1, 2007 | 02:20 PM
BoosTED's Avatar
I just tapped mine out today.
Will be replacing with stainless bolts and it will make swapping the cat out much, much easier.
Old Oct 6, 2007 | 10:10 PM
Crazy Rx-8 Driver's Avatar
XYELLR8
where did those bolts on the Cat connected to?
Old Oct 6, 2007 | 10:42 PM
cajunrx8's Avatar
Rotary Crawfish
Also make sure to add a little never-sieze to the threads. It will make it easier if you need to remove later.
Old Oct 7, 2007 | 05:21 AM
BoosTED's Avatar
The header side.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
yankeepicker
Sep 11, 2015 05:42 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
