Timing Problem ?????
Old Feb 23, 2007 | 09:44 PM
WreakLoosE's Avatar
Hay guys... I got a new A Gen Cy Power pully for my 8 today and put it on... Everything is all good and fine with the install however, I got a CEL for P0302 Cyl. 2 Misfire detected... Now when I installed the pulley I noticed that I spun the crank when I was trying to take off the bolts that hold the pulley on.. Did this mess the timing up some how?? and if so... How do I check the timing and correct it?? any help would be nice... Thanks..
Old Feb 23, 2007 | 10:01 PM
StealthTL's Avatar
Cool I think....
I think you just pull the battery cable off, to make the ECU forget the screwed-up timing setting, and set a new one.
S
Old Feb 23, 2007 | 10:07 PM
WreakLoosE's Avatar
I thought of that.... Didnt work...It came back on...I will try to drive it more to see if it retimes it self..
Old Feb 23, 2007 | 10:25 PM
StealthTL's Avatar
Cool Sticky....
We should both have consulted the sticky thread in the Tech section - "How to reset the ECU"
Link
MazdaManiac posted the reset procedure.
S
Old Feb 23, 2007 | 11:35 PM
WreakLoosE's Avatar
Nope Still nothing... CEL still lit.. When I disconnect the batterie it goes out and when I start the car it is off for about 3-5 mins. then comes on...
Old Feb 23, 2007 | 11:46 PM
Search.. there is ananswer on the forum.
Also good information at MazdaTrix site.
Old Feb 25, 2007 | 03:30 AM
WreakLoosE's Avatar
OK I fixed it.... After Crank is moved from its possition the computer sensors need to be reset... the KAM the 20 presses on the brake did the trick...
Old Feb 25, 2007 | 05:38 AM
StealthTL's Avatar
Cool Check.....
I posted that in post #4, you didn't follow the Link.....
S
xAgyex
Jun 3, 2026 03:47 PM
WingleBeast
22
May 23, 2016 09:22 PM
uZu
Dec 30, 2015 12:35 PM
Solmors
Aug 21, 2015 10:11 PM
mesaboogie
Aug 7, 2015 10:48 AM
