need help choosing tire size
Old Feb 12, 2007 | 04:25 PM
sheba's Avatar
Hi guys, I have 18 x 10 volk Sf challange wheels in the back. and I'm using 265/35z/18. I want to know what is the widest tire I can use 285/30z/18? will that fit?
Old Feb 12, 2007 | 05:03 PM
O'Renesis's Avatar
Cant say if you will have enough clearance for that size wheel/tire combi. ? 285's will fit that 10" wheel as will any tire between 255 and 305. To keep your speedometer reading near accurate (assuming stock tire was 225x45) you should look at 285x35 instead of 285x30. Google; tire size calculator for more in depth info. eg, http://www.1010tires.com/TireSizeCalculator.asp
Old Feb 12, 2007 | 05:10 PM
avenger's Avatar
likes to do drawerings
What's the offset you're running in the rear? I know you can run a 18x9.5 with a 45 offset to 275/35/18s.
Old Feb 12, 2007 | 09:52 PM
ac3mastuh's Avatar
Got Ings?
i've seen guys on the forum run a 275 rear tire on a +37 rim so essentially since the 285 is only 5mm wider on each side, you could run a +42 or higher rim with no problems.
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
