Pictures my Powdercoated Calipers
Old Jan 31, 2007 | 12:06 PM
rx8guy86's Avatar
Drive Like you stole it
I went ahead and put on the PowerSlot slotted rotors, Hawk brake pads, and powdercoated my calipers. Here are a few pics. Questions/Comments are welcome
Click to make larger
Old Jan 31, 2007 | 12:33 PM
im not into red colored calipers (except BBK's) but atleast you did it the right way.
Old Jan 31, 2007 | 01:18 PM
type59's Avatar
mrjackwong
me neither. not a fan of the faded reds but yours look clean. thumbs up for you! you have a shot with the whole car?
Old Jan 31, 2007 | 06:52 PM
rx8guy86's Avatar
Here are a couple that I have. I need to get some more sideshots.
Old Jan 31, 2007 | 06:59 PM
snipaz2420's Avatar
the bukkake master!
i think they look pretty good. i want to eventually do mine red also. probably not powercoated though. how long did you have to wait for them to be powdercoated?
Old Jan 31, 2007 | 07:02 PM
shinka213's Avatar
Pettit fangurl <3
well done and very clean.....actually they are the best looking caliper i have seen...im not into red for my car with the black cherry but they look sweet with the white....
Old Jan 31, 2007 | 07:03 PM
DarkBrew's Avatar
Extraordinary Engineering
What did it cost you for the powder coat? What sort of life expectancy will it give in this application.
Old Jan 31, 2007 | 07:06 PM
rx8guy86's Avatar
To break down and sand blast all four calipers, powercoat them, install the pads and rotors, took us about 7hrs. The longest part is breaking the calipers down. You have to make sure every rubber seal is removed. There is a tiny O-ring seal in behind the cylinder in the front two calipers that was a pain to get out.
Old Jan 31, 2007 | 07:08 PM
rx8guy86's Avatar
The Caliper rebuild kit for the front and rear were about 40.00 per set (front/rear), powder was 20. The gun kit was about 200, but the cost of that was split two ways. We use the kit for alot of other things. As for the life of the powdercoat.... I use the most expensive powder. i tried to knock the color off by hitting metal against metal and it wouldnt come off. The manufacture said that the only way to remove the powder coat is to sandblast again. The calipers also clean VERY easy. Pretty much just spray them off.
Old Jan 31, 2007 | 07:41 PM
Wilson's Avatar
Peeping over the fence
I think they look great. Nice and slick so they should clean up easily.
Old Jan 31, 2007 | 08:08 PM
llzjayarzll's Avatar
meow
you think your rotor is gonna rust?
Old Jan 31, 2007 | 08:11 PM
rx8guy86's Avatar
I dont know. Its been about 3 months and they still look awesome!
Old Apr 5, 2008 | 11:26 AM
prospectjtaz's Avatar
Do you need to rebuild your caliper when powdercoating. Thanks.
Old Apr 5, 2008 | 01:04 PM
kersh4w's Avatar
Hit & Run Magnet
looks very nice.
Old Apr 5, 2008 | 01:49 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Could you post pictures of the rears?
Old Apr 5, 2008 | 01:58 PM
WoodsOfGreenRx8's Avatar
Where did you get the rebuild kit from?
Old Apr 5, 2008 | 06:32 PM
altspace's Avatar
Eccentric Shafting
Nice work!
Old Apr 5, 2008 | 06:38 PM
nuke0907's Avatar
Never Blend In
old thread, but those look really good. how they holding up?
Old Apr 5, 2008 | 10:43 PM
Nopstnz8's Avatar
Check out my garage. I had mine powder coated and they are holding up great. It has been over a year and there isn't really any corrosion on the surface. Also, they stand out more than spray paint.
Old Apr 5, 2008 | 11:24 PM
Did you rebuild your caliper too thou when you got them powdercoated?
Old Apr 5, 2008 | 11:26 PM
Nopstnz8's Avatar
I don't think so. I bought my car used, and the guy who sold it to me owned a powder coating shop and had recently done it before I bought the car.
Old Apr 6, 2008 | 06:18 AM
rx8spiritR's Avatar
----Got Rice?----
if you don't think so then it's most likely not powdercoated.
you can't powdercoat a caliper without taking everything apart, i mean pistons, seal, and all the hose well in this case no hose. they then will sand down the caliper and powdercoat it, after it's done, you'll have to rebuild the caliper that means put everything back together, be extra careful with the piston seal. That is a lot of work to do to a single piston rx8 caliper don't you think?
Old Apr 6, 2008 | 08:31 AM
Kris's Avatar
I was going to powder coat my claipers, however its too much time and effort to get it done. So i said eff it, i will stick with black paint.
But they look nice.
Old Apr 6, 2008 | 08:35 AM
mbrule6465's Avatar
Rex8
Like that look......
Great results. Are those stock calipers? Nice looking rotors too. Thanks for sharing your photos.
Old Apr 6, 2008 | 10:51 AM
Nopstnz8's Avatar
Ok then I guess he did rebuilt the caliper because he did take them apart and then powdercoated them. Check my garage and you can see the pics.
