Mazda Appearance Package Front Lip
Old Jan 2, 2007 | 11:02 AM
L8APEX's Avatar
Smooth Criminal
Quick question, if you are installing the Factory Appearance package front lip, does it require any extra pilot hole to be drilled in the bumper face? That said, if you took off the lip, would there be any unsightly holes left behind?
Thanks in advance for any answers.
Rotor On
-L8
Old Jan 2, 2007 | 12:20 PM
r0tor's Avatar
4 or 6 holes are drilled if I remember correctly
Old Jan 2, 2007 | 01:05 PM
L8APEX's Avatar
Smooth Criminal
that is disconcerning.
anyone out there that knows for sure?
Old Jan 2, 2007 | 01:23 PM
8rotor8's Avatar
Back in the day...
it's six holes, I need to install mine, I wonder if anyone out there has the template for it?
Old Jan 2, 2007 | 01:31 PM
L8APEX's Avatar
Smooth Criminal
thanks, that does not bode well for me.
Old Jan 2, 2007 | 02:00 PM
jskup1's Avatar
The Chief
You don't need a template. If you look on the inside of the bumper, there are small circles with a + in them. That is where you drill.
Old Jan 2, 2007 | 02:36 PM
r0tor's Avatar
yup!
Old Jan 2, 2007 | 05:12 PM
8rotor8's Avatar
Back in the day...
AHHH!!! that makes sense, I didn't look yet. is it the same for the rear and sides?
Old Jan 2, 2007 | 06:36 PM
jskup1's Avatar
The Chief
For the rear aero flares, there are two of the same circles that you drill out and then cut out between the two drilled holes making a "slot." For the sides, there is a paper template which you tape to the car and then drill the 4 holes into the side of the car and then two holes into the wheel well.
MsKingRotary
Apr 23, 2016 05:45 PM
MsKingRotary
Jan 28, 2016 12:12 PM
akagc
Aug 11, 2015 07:07 PM
cushing75
Jul 30, 2015 12:21 PM
cushing75
Jul 22, 2015 09:37 AM
