More Heat Than Other Cars?
Old Dec 30, 2006 | 10:12 AM
SaikoMelon's Avatar
aka Bananaman
I did a rough search and couldn't find an answer so I thought I'd post. Forgive me if it's been posted before. (;_; )
My dad has been telling me that my 8 is generating much more heat than a normal car, in the sense that the boot, cabin and cup holder/compartments are warmer than his Ford. (cabin with air conditioning off in tropical weather)
Anyone find their 8 warmer than any other cars?
Old Dec 30, 2006 | 10:17 AM
guy321's Avatar
Humpin legs and takin nam
yes , duh
Old Dec 30, 2006 | 10:24 AM
vectorwolf's Avatar
Totally confuzzled...
Sure do. When it's warmed up, it's *warmed up*. Terriffic in chilly winter weather, but bothersome in the summer (to a point). Glad the AC works so well.
Old Dec 30, 2006 | 10:37 AM
wicked1044's Avatar
wait till the summer and you put something in your trunk that need to stsy cold! your F-ed!
Old Dec 30, 2006 | 10:52 AM
Boot, because The engine is right next to it.
Cabin, Im not sure about where in cabin you talking about. Lets assume its the *middle* part. Especially Cup Holder. Thats because The Catalyst Converter is RIGHT UNDER the cup holder then the exhaust pipe goes all the way to the back.
Oh the trunk someone said? Thats because the WHOLE exhaust Thing is right under it. Dont even expect it to be cold (even winter, its NOT going to be that cold)
ITs great if you wanna keep the food warm (perhaps HOT)
Nothing really wrong with the car, thats what most sports car are like. (due to low clearance)
Old Dec 30, 2006 | 11:01 AM
SaikoMelon's Avatar
aka Bananaman
I see! Thank you! (@_@)
*learns*
Old Dec 30, 2006 | 11:25 AM
Endor's Avatar
Vroom
Great in the winter though! Cranking the heat up to full and the fans to max feels like you could cook a turkey on the dashboard.
Old Dec 30, 2006 | 06:28 PM
prescriptionmazda's Avatar
FULL FRONTAL ...downforce
Or better yet, put something in your trunk during winter that needs to be kept warm, works very well.
Old Dec 30, 2006 | 06:38 PM
mysql101's Avatar
your engine/exhaust will run in the 1600 - 2000 degrees Fahrenheit range.
also look at where the engine is located - and where the exhaust is routed:
Old Dec 30, 2006 | 07:20 PM
Spin9k's Avatar
Momentum Keeps Me Going
One can pretty nearly take care of this whole heat issue in doing a couple things:
1) make sure the dealer has done the necessary TSBs/recalls for gas tank heat shield/over cup holder heat shield (cup holder fix is actually a pretty weak fix on Mazda's part if you see what is done)
2) if you're the DIY type, installing a roll or two of aluminized foam heating duct sound deadener (USA home depot 10sq/ft/roll)/or similar dynamat type sheeting if you want to spend more. Remove the center console area and coat the tunnel with material, also remove the trunk liner and carpet and do the same there.
This helps alot up front, and as a side benefit in the rear, exhaust sound/ road-tire noise (esp if you have a cat-back) is significantly subdued.
Old Dec 30, 2006 | 07:51 PM
Endor's Avatar
Vroom
An engine in the front of the car.... and an exhaust system which runs *underneath* the passenger section, and an exhaust at the back of the car! Brilliant!
Old Dec 30, 2006 | 08:23 PM
Phade2's Avatar
It's a front-mid engine car....so it's one of the side effects of having the engine behind the front axle. Just like the porsche caymen's rear mid-engine placement, their cockpits are a lot warmer than the normal 911.
Old Dec 30, 2006 | 08:39 PM
SaikoMelon's Avatar
aka Bananaman
I see! /(@0@)\
this is all very informative! Thank you for the replies!
Old Dec 30, 2006 | 09:53 PM
User24's Avatar
The catalytic converter is about the hottest thing I've ever touched in my life.
Old Dec 30, 2006 | 10:17 PM
Easy_E1's Avatar
^ooooooops
Old Dec 30, 2006 | 10:35 PM
User24's Avatar
I hope you don't mind the heat too much. It's a real minor issue. I'm thankful, because it could be worse, much worse. For example, we could have a shifter that looked like this:
http://img227.imageshack.us/img227/6...G_0081ORIG.jpg
Terrible, humiliating.
Old Dec 30, 2006 | 10:49 PM
Freddie's Avatar
^^^^^^^^^ W. T. F is that ? ? ? Whatever it is, it's just wrong.
Old Dec 30, 2006 | 11:01 PM
8is>enuff's Avatar
Bland
Haha.
This thread is funny and informative with not one "Search noob!" in sight. I have to try the DIY on this.
Old Dec 30, 2006 | 11:16 PM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
Good news - it will keep your coffee warm
Bad new - you can't cook an MRE by throwing it under the hood
Good news - fresh bread in the trunk will come out still warm, also pies
Bad New - a bag of ice with a lobster in it, if placed in the trunk will become a bag of water with a lobster in it. Use ice chest if moving good wines or place on passenger seat
Old Dec 30, 2006 | 11:19 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Is that a joke?
The AC in this car "blows" especially down here where I live, in hell. Even the 4 cylinder econocars I've rented while my 8 is being serviced had better AC systems. If you live in a place where it's always at least 80 out and you're sweating when you get into your car, it takes forever for the damn air conditioning to actually feel cold. You have to set it to highest (4) and even then it's still weak compared to other vehicles. I've complained about it a bunch of times in both RX-8s I've owned. It's just shitty AC. Oh well.
Old Dec 30, 2006 | 11:24 PM
Raptor75's Avatar
The rotary's exhaust is few hundred degrees hotter then a piston engine. This is one reason for the poor fuel economy. More energy is lost to heat then in a piston engine.
Old Dec 30, 2006 | 11:28 PM
^^^ Yup
Rotary Engine Produce and *trap* lots of heat. its Science and Nature that cannot be fix that easily.
Maybe one day they can come up with something like transfer the heat into other source of engery ? O_O
Skyl3r
Dec 2, 2019 04:51 PM
akagc
Aug 11, 2015 07:07 PM
thewatcher101
Aug 4, 2015 10:42 AM
dbarber
Jul 25, 2015 01:34 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
