Mazmart The leader in late model Mazda parts
need improvements, Mazmart will help?
Old Nov 9, 2006 | 08:13 AM
Yusik's Avatar
Question need improvements, Mazmart will help?
Hi from Moscow!
I've been readdressed from other forums to yours and to Paul personally, may be you can help.
first: may I install climate-control option? Its standart package in europe (my RX8 from US market)
second: can you provide me with radio tuner of european frequency spec, or the way to change firmware in it?
Old Nov 9, 2006 | 08:48 AM
Mazmart's Avatar
Greetings my friend across the sea. You come bearing interesting questions. Are you wanting auto climate control that uses all push button functions?
Paul.
Old Nov 9, 2006 | 08:55 AM
Mazmart's Avatar
Okay, I've re-read your post and understand exactly what you're saying. I'll look into it and give my best opinion shortly.
Paul.
Old Nov 9, 2006 | 09:13 AM
LostAngel's Avatar
Glad you found where I pointed you Yusik!
Old Nov 9, 2006 | 09:30 AM
Yusik's Avatar
Smile Thanks for warm welcoming!
Right turn **** at right down corner of dash, when pushing works as auto climat mode, by turning it you change desire temp.
Left turning **** works as it is, but one can see speed of fan on display.
Paul.
Old Nov 9, 2006 | 04:42 PM
Mazmart's Avatar
Thanks Lost.
Paul.
Old Nov 9, 2006 | 09:31 PM
Conundrum's Avatar
It would be interesting to see the conversion from standard climate control to auto climate control... please keep us informed of your progress
Old Nov 9, 2006 | 09:55 PM
Mazmart's Avatar
Yusik,
See if you can get me the Mzda part # being used in Europe for the climate control please.
Paul.
Old Nov 10, 2006 | 03:48 AM
Yusik's Avatar
Question Climate-control part#
This is it:
F151-61-190 Control, heater , picture attached. It cost here about 300$. I called to mazda service, they doesn't know do I need something else, never did that job. All the RX8 here with climate-control but without cruise-control for example. Mystery!
Yusik,
Paul.
Attached Thumbnails need improvements, Mazmart will help?-climate-cotrol.jpg
Old Nov 10, 2006 | 07:47 AM
jskup1's Avatar
The Chief
At the very least, there would have to be a temperature sensor somewhere for the climate control to adjust to probably mounted on top of the dash somewhere by the windshield.
Old Nov 10, 2006 | 10:14 AM
Yusik's Avatar
Sensors
Yes, I found it, see picture, besides, there are two of them: 61751A sensor sun(its closed by cover on ours RXs)
other is 61757 sensor incar.
Will it work if we all of it to install? wiring must be same but better to check. Awaiting for MazMart decision.
Attached Thumbnails need improvements, Mazmart will help?-climate-control.jpg
Old Nov 10, 2006 | 05:39 PM
Mazmart's Avatar
You've provided what is known as the D-codes which is a start. The part #s often
iclude these. If you can't get the full #s I may have to get real creative in my search. I'll also have to compare wiring diagrams. This could take a while. I hope you aren't really relying on me.
Paul.
Old Nov 11, 2006 | 04:31 AM
Yusik's Avatar
Talking
Paul, no problem if it won't work.
But you can pleased by so useful option so many customers! Suppose many of them will apply to you for this option! Just let them know!
Paul.
Old Nov 13, 2006 | 04:45 PM
Mazmart's Avatar
Any luck on the complete part #s?
Paul.
Old Nov 14, 2006 | 04:58 AM
Yusik's Avatar
Paul,
No, people from mazda here cannot give me full parts #, its an internal info as they said, sorry, I can't! But there is one new interesting thing I knew from them- radio head unit ## depends of existance of full climat control, thus, the main unit is one of important parts to handle this matter.
Now its all more complicated for me: I want to order head unit here to have an European frequency change steps and RDS, but what kind of radio to order, with or without full climate control, wiring/connections may be different, and it won't work
Old Nov 16, 2006 | 08:57 AM
Mazmart's Avatar
I have a local Russian friend who imports and exports cars. I'll see if he can be of any help.
Paul.
poacherinthezoo
Aug 3, 2016 11:01 PM
archon
Oct 1, 2015 06:08 AM
xAgyex
Sep 28, 2015 08:54 AM
