Fill/Drain plug washers part number
Old Oct 23, 2006 | 03:59 PM
Im just wondering are these correct ?
Originally Posted by rx8cited
Part # for:
Transmission filler/drain plug crush washers - Y601-17-361 (oddly, description in Mazda parts system is "Tape, Protector")
Differential filler/drain plug crush washers - 9956-41-800
Both sets were identical in size except for the fact the the transmission washers were a bit thicker.
rx8cited
I called a few places up they have the differntial fillter plug. but not the Transmission one, they said its *in-corrected* So .....
Old Oct 27, 2006 | 09:10 PM
KKMmaniac's Avatar
VW coulda had it...
Well let's see here... I dug up my invoice -
Yep, it's what you said. (and yes "tape, protector" for some damn reason)
I don't know why I wrote down 9956-41-801 for the diff., but the receipt says 9956-41-800.
Old Oct 28, 2006 | 12:36 AM
I got it already, I dont know wheres my invoice (its in my car I think) but these should be the part number, and I think your receipt is right.
Top plug:Y601-17-495
Bottom Plug:Y602-17-495 (Magnetic plug)
Both Gasket Rear Covers:Y601-17-361.
LSD
top-plug:99511-1800
gasket:99562-1800
bottom-plug:0810-17-121 (Magnetic plug)
gasket:99564-1800
I just changed my oil today .... both transmission and rear diff .... took me 3 fooking hours ! yea Im slow .... but hey its my first time so I think its ok ... pain in the *** to take the bolts out with my hand, tried like 30 mins just for one bolt with no luck, in the end I have to *kick* it to get it loose ..... Kick all 4 in 15 minutes .... not so bad. the next painful part was to add oil to the transmission, Rear diff was pretty easy because I have enough room to let my bottom go upside down so I can squeeze it ... but the transmission part has no room and That alone took me one hour ....
I could've pay someone to do all these, nice and easy, only 50 bucks. not even 1 hour of work. but the more I work on my car, the more I love my car :D
P.S : damn btw, I strongly recommend everybody to change their gear and rear diff oil more often. First change was when I hit 5K miles, now Im 21K miles. God damn it all those dirt that got stuck on both Magnetic plug. I still have them next to my desk maybe I should take a picture of it before I throw it away.
Old Oct 29, 2006 | 10:30 AM
KKMmaniac's Avatar
VW coulda had it...
First time probably took me longer than that - mainly 'cause I had a problem getting the old oil to go into the drain pan instead of on the floor!
I used a long vinyl hose to transfer the lube from the bottle to the diff. and tranny; that seemed to help, I know clearance is pretty limited underneath.
Old Oct 29, 2006 | 10:32 AM
KKMmaniac's Avatar
VW coulda had it...
Yeah, the old stuff usually looks pretty bad, gotta make you feel good about changing it!
Old Oct 31, 2006 | 12:21 AM
LionZoo's Avatar
road warrior
So we have a different washer for the diff drain and fill plug, but it seems that finishlineperformance only lists one type of washer for the diff. What gives?
Old Oct 31, 2006 | 02:35 AM
BoosTED's Avatar
We poured the transmission fluid in where the shifter goes into the transmission. A bit of work to take the shifter out but much easier to pour.
Old Oct 31, 2006 | 05:48 AM
Yes. they're different.
The transmission has the same washer. but the rear diff, the top one is a *brown/bronze-ish* looking washer. while the bottom one looks almost the same as the one in transmission, except that its thinner.
Well if I had a longer tube I could've done it in 15 minutes
Lesson learned, will buy a long long tube before my next transmission/rear diff oil change (due in 10K miles)
Old Oct 31, 2006 | 05:57 AM
BoosTED's Avatar
I hear you on that.
I wish I had a pump that screwed on to fit the bottle for the Amsoil 75w90...
It takes like a hundred or two pumps to fill the diff.
Old Oct 31, 2006 | 06:43 AM
lol :P
yea ..... I learned mine thru the hard way .........
So far I did all the oil change myself .... changed the intake myself, installed the ram air duct myself... lets see what should I do next ? maybe its time to do some harder stuff ?
Old Oct 31, 2006 | 07:12 AM
BoosTED's Avatar
Make yourself a custom grounding kit.
An exhaust isn't too hard to install once you learn how to conquer the rubber hangers.
Changing out your flywheel for a lighter one would be considered harder.
Baby steps... baby steps.... then custom work.
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
airlive
Nov 4, 2016 12:15 PM
IamFodi
Aug 11, 2015 01:51 PM
06rx8nate
Aug 4, 2015 08:29 AM
