{ FS } <22K~ Miles RX-8 13B Renesis Engine
Old 11-07-2011, 06:57 PM
Themare's Avatar
Category: Engine - Complete Motors
Price: $1400
SOLD
6port Hi-Power 6 Speed Manual Transmission
2004-2008 R2 Model Series I
Cranked up to 158mph in 6th gear recently on asphalt and still stable with some more revs til redline.
* Works perfectly fine
* No leaks, cracks, or anything bad
* Good Compression
- with a Compression Test of avg 6.5 front and back @ 200rpm at local Mazda Dealership OR avg 7.4 front and back @ 250rpm
* New belts added ~4,000 miles ago
* New GReddy Lightened Performance Pulleys ~4,000 miles ago
- Priced at $200
FOR SALE at $1400 OBO
Selling because of part-out
Old 11-07-2011, 07:08 PM
RIWWP's Avatar
Is it a Series 1 or Series 2? you list both, but they are not the same engine, and can't be directly swapped.
If it is a Series 1 engine, then you need to list if it is a 4port or 6 port. If you are selling all the accessories attached, I believe you also need to list what transmission it was originally paired with.
Compression test of 6.5 is not "good", but "passing". More accurate would be "passing but headed toward failure". At 22,000 miles, I would get concerned with that low of a compression number. OEM factory should be high 6s, if not mid to high 7s. I've seen a factory engine in the high 8s.
If you are going to list any compression numbers though (which would be wise), you should list all 6 compression numbers with the RPM of the engine during the test. I admit it's possible that all 6 facings could have exactly the same compression, but it's gotta be rare. That could be stellar compression at horribly low RPM, or terrible compression with RPM over test spec.
Old 11-07-2011, 07:27 PM
LifeAfterRx8's Avatar
+1
When I had my engine replaced my numbers were in the low 7's and high 6's and they confirmed my engine as needing replacement.
Old 11-08-2011, 07:52 AM
Themare's Avatar
Edited post to clarify some things.
The Mazda Dealership said that my engine is still strong. I apologize for not specifying the RPM in which it was tested with.
Compression rating of 6.5 front n back @ 200 is "good" condition, because avg new factory series I (2004) engines comes out at a avg rating of 6.8 @ 200RPM.
Plus I was able to crank out a lot of power out of that engine, much better than a few of my other friends with the same year RX8.
Old 11-08-2011, 07:59 AM
RIWWP's Avatar
Got it, thanks. Corrected 7.2 @ 250rpm can be called "good"
Old 11-08-2011, 08:04 AM
Themare's Avatar
:] I'm glad that's clarified :P
Old 11-08-2011, 08:36 AM
Charles Bundy
Grace_Excel's Avatar
I just PM'd you, forgot to ask where are you located in CA?
Old 11-16-2011, 05:14 PM
Themare's Avatar
I am located in southern california 91803.
engine still for sale :]
Old 12-20-2011, 04:31 PM
dizenman's Avatar
Sent you a PM if you still have it. very interested
Old 12-20-2011, 06:11 PM
No respecter of malarkey
Received 2,013 Likes on 1,640 Posts
I figured even the most recent n00bs would have called BS on this ...
Old 12-20-2011, 06:46 PM
dizenman's Avatar
It did sound odd to me, I had trouble getting a stock 350z past 154, I couldn't imagine trying on an RX8, but everyone always bullshits stuff like that when trying to sell their stuff..
Old 02-12-2012, 12:03 AM
terrydavis57's Avatar
Is this motor still avaiable?? I would be very interested if it is!! I live in southern AZ and would drive to CAL to pick up!!!
Old 02-12-2012, 07:23 PM
Has anyone ever accused you of being naive?
Old 02-12-2012, 08:45 PM
elysium19's Avatar
158 and beyond? ehhhhh 148 or video?
Old 02-12-2012, 08:56 PM
spgcyn's Avatar
158 @ 6 gear? pfffffFFFFFFF
Old 02-22-2012, 04:40 PM
DarkHelmet's Avatar
still available? where in CA are you?
F51
08-02-2021 04:07 AM
vapor2
11-03-2020 03:38 PM
dbarber
07-25-2015 01:34 PM
RX7.9
07-20-2015 12:01 PM
vssystemluba
07-19-2015 04:16 PM
Quick Reply: { FS } <22K~ Miles RX-8 13B Renesis Engine
