Al's Nitrous Install Thread!
Old May 2, 2011 | 07:30 AM
  #176
bobsaggit's Avatar
I orderd the zex kit from summit racing. I have used summit many times befor knew they ship fast and are safe.this was befor i was a member of this forum. Now that i know there is a company out there that also adds install suport i will use them next time. At the time of purchase tho i didnt.
Old May 2, 2011 | 07:36 AM
  #177
bobsaggit's Avatar
So the gas line tap that comes with the kite dose not fit are stock gas line? Also the gas line u guys are using has a red clip sorta by the fire wall rite?
Old May 2, 2011 | 08:18 AM
  #178
Rote8's Avatar
Um, double and triple check any gas line fittings before starting, after starting, after driving and again the next day
I converted my gas line to a -6 AN from the firewall to the fuel rails, I do not like any plastic gas line.
Old May 17, 2011 | 11:24 AM
  #179
bobsaggit's Avatar
the only connector i see has about 8 wires and non are white there all like red and orange
Old May 17, 2011 | 04:10 PM
  #180
wcs's Avatar
wcs
no agenda
Connect white wire from the Zex kit to the bottom wire of the TB harness
Old May 17, 2011 | 08:20 PM
  #181
bobsaggit's Avatar
thanks for the picture. it really helps seeing that its a green wire. befor it sounded like i was splacing into a white one. got the install 100% now everything seems to be working good. just need to fill my bottle.
Old May 17, 2011 | 09:10 PM
  #182
wcs's Avatar
wcs
no agenda
^^^ LOL
As old as these ones as well I would imagine
Old May 21, 2011 | 04:35 AM
  #183
Cattywampus's Avatar
Turbos blow!!
^^ we know
Old May 21, 2011 | 04:28 PM
  #184
monchie's Avatar
I HATE SPEEDBUMPS!
DAMN!! Back when I was skinny and smiling. These days I am a fat, angry, ****. LOL
Any pictures of you now? lol
Old Jul 4, 2011 | 12:42 AM
  #185
RXeligion's Avatar
The X is silent
I know this thread is pretty specific to the ZEX kit, but would the possibility of popping apart one's intake be reduced by manually controlling the nitrous flow? That way one can cut the nitrous before letting off of the throttle. It makes sense to me.
Furthermore, this thread has taken most of the mystery of out nitrous, so I want to thank Al and Charles for putting so much effort into it. The only thing that could have made it better is functioning pictures...
Seems like nitrous might be right for me & mine.
Old Jul 4, 2011 | 12:51 AM
  #186
hakuna matata!
Yeah sorry about the pictures they are irrecoverable because the web server I had them on imploded.
Manually controlling nitrous flow would require discipline. I think, properly used, the nitrous module will always be a better option compared to our limited attention span and slow reaction time.
I also can't believe this was more then 2 years ago!
Old Jul 4, 2011 | 01:00 AM
  #187
RXeligion's Avatar
The X is silent
Manually controlling nitrous flow would require discipline. Properly used the nitrous module will always be a better option compared to our limited attention span and slow reaction time.
I can see your point, I've seen guys blow their intakes apart manually controlling nitrous, too. Perhaps I have too much confidence in myself.
Dont sweat the pictures, I'm sure there are pics around from other peoples installs and if I do this, I'm going straight through BHR because they have such great support. I have a couple of other upgrades that are going to happen first, and A LOT more reading, but thanks for giving me a good starting block. There are a lot more 8'ers with nitrous than I had thought, and thats a comforting thing to know.
Old Nov 1, 2018 | 03:27 AM
  #188
Kamal El's Avatar
all the flipping pictures are gone! Any other good install threads?
Old Nov 1, 2018 | 06:56 PM
  #189
200.mph's Avatar
FULLY SEMI AUTOMATIC
what do you need to know?
Old Feb 10, 2019 | 01:39 AM
  #190
TripleRotor's Avatar
New here, as you can see by my post count, but not new to rotaries (three RX-7s) and nitrous(spraying for 20 years). I saw somewhere that the secondary and tertiary injectors are far below their duty cycle values. How much hp/torque can the injectors support at 80% and 100% duty cycle. Can the factory fuel pump handle that much flow? I have always been a big fan of dry shots and letting the factory injectors take car of extra fuel.
Old Feb 10, 2019 | 06:51 AM
  #191
Kamal El's Avatar
Didnt see this reply thanks. I dont think Im going to consider this mod anymore. It would be nice to see the original pics though.
Old Feb 10, 2019 | 09:33 PM
  #192
You should consider a dry set-up. Really easy to set-up. Not a big fan of wet set-ups, because most intakes are not designed to distribute fuel properly. Based on what I read on here, seems like some people have had some puddling issues. Also, for some reason, the fuel solenoids are notorious for failing. I guess you could fix this with a Hobbs pressure switch. Most cars run about 20% rich with WOT to keep the cats safe. I am thinking with 93 octane, you could get away with a 40hp shot of nitrous without touching anything. I was surprised how little HP people were getting with the BHR kit. Seems like it was too rich. Don't forget that HP is just part of the story. The real fun is torque! 40HP shot should yield around 40 ft/lb if you have enough fuel. That is a 25% jump in torque!
Old Feb 11, 2019 | 04:35 PM
  #193
200.mph's Avatar
i probably have a bunch of pics of my old set up somewhere but not a complete install pic/thread worthy
JessiahC
Nov 1, 2011 09:09 PM
getdamafiaonyou
25
Jun 8, 2009 02:33 AM
Bloodroz
43
Dec 21, 2008 01:15 PM
wcs
31
Feb 23, 2008 05:47 AM
