DIY: No Heat? Repair the Heater Control
Rating: Thread Rating: 7 votes, 5.00 average.
Old Nov 14, 2009 | 03:57 PM
  #151
tasteslikechicken's Avatar
I'm yet another '04 owner who had this problem, followed the DIY, and now am back to fully functional heat/chill.
I'll just add my comments for any who find their way to the back pages.
- the bolt on the side of the radio was easy to remove by hand after starting it with a wrench. Just be careful and keep a good grip. (I re-attached it hand tight.)
- the biggest PITA in the entire process is disconnecting the various harness connectors. I found a mini-screwdriver to be the best tool to eventually do the trick.
- I broke one of tabs holding in the center section top plate (around the shifter). If you've never removed it (as was my case) keep in mind that they all pull straight up. The one on the right, to the back of the hand brake was the one I lost.
But it's a very do-able, if frustrating, DIY.
Old Nov 28, 2009 | 05:44 PM
  #152
RXei8ht's Avatar
Hi I'm trying to go through with this diy but im having a real hard time pulling out the radio. I checked to see if if might of been the bolt thats behind the dash however I do not see one there, just an empty hole. I'm pretty sure its the right one cuz its right above the two that you are not suppose to take out. Ive got the radio part way out but it feels like somethings snagging it on the left side. Any ideas?
Old Nov 30, 2009 | 08:25 PM
  #153
glennrx8's Avatar
i just did mine this weekend.. works like a charm!! It took me an hour to take it out solder then put it back together
Old Nov 30, 2009 | 08:51 PM
  #154
getdamafiaonyou's Avatar
It was a great DIY. Took me entirely to long. But thats because that long somewhat hidden screw to remove the radio...didnt exist for me. so i looked for about a hour, and then just pulled it straight out, felt like a dumb ***. lol.
Old Dec 2, 2009 | 01:45 AM
  #155
RXei8ht's Avatar
Was it easy to pull straight out? Cuz Im using as much brute force as I can without breaking it and that thing will not budge, I have it about an inch out and it wont go anywhere after that....
Old Dec 2, 2009 | 03:53 AM
  #156
Jon316G's Avatar
Grasshopper
If you have it an inch out you're home free.
The main radio wire bundle is secured in the back (I believe) by electrical tape if I remember correctly.
I just pulled extra hard and managed to break it free from what was holding it back.
Old Dec 2, 2009 | 07:32 PM
  #157
Highway8's Avatar
Registered RX8 Nut
My heater temp control goes between 13 and 16 and my fresh air/recirculation button is stuck on fresh air. Both problems started at the same time. Thoughts?
My car is an 07 with 16K miles, 2 days out of warranty but I have a $100 deductable on my extended warranty.
Old Dec 2, 2009 | 07:42 PM
  #158
Jon316G's Avatar
Grasshopper
You might have the same issue with the heater temp control where you need to solder the three leads for the pot.
And since you'll have that circuit board out, then look at the push button and see if its stuck.
I don't recall if the push button is surface mounted for PTH, but you can inspect for insufficient solder on that too.
Old Dec 3, 2009 | 10:47 PM
  #159
RXei8ht's Avatar
When you were pulling it out were you grabbing it (center console) from the top and bottom or the sides? Could it be possible that one of the wire harnesses might have caught on to something?
Old Dec 3, 2009 | 10:50 PM
  #160
Jon316G's Avatar
Grasshopper
Possibly.
Next time I pull out my radio I'll look to see if there is any tape or ties broken.
If not... then maybe it was just caught on something.
Old Dec 10, 2009 | 08:46 AM
  #161
The Drunk IT Guy's Avatar
I just shat myself
Finally completed this yesterday! Worked as promised.
I'd say getting the wiring harnesses disconnected from the radio was by far the biggest pain in the ***. I can't imagine getting a big hand back there to disconnect it, mine got dam near crushed. And I thankfully managed not to drop the radio-bolt but I did remove that metal plate for easier access. That dam ash trey light never would come out for me, I just let it hang to the side.
Bonus tip: I think it's easiest to wrench on the radio bolt when laying down on the seat backwards with your head underneath the wheel.
Old Dec 10, 2009 | 06:47 PM
  #162
Jon316G's Avatar
Grasshopper
If you remove the bottom plastic cover under the steering wheel column, you can see the hidden bolts through there.
I used a socket with an extension + U-joint from underneath while watching/navigating it to the bolt through the opening under the steering wheel column.
Old Dec 11, 2009 | 07:58 AM
  #163
Balthus's Avatar
User shadetreehill posted this message in another forum and I am having the exact same problem. Any ideas/help would be appreciated:
"heater problem 2005 RX-8, vent on driver's side is blows cold and vent on passenger side blows luke warm. checked temp control function (utilizing test mode with radio buttons) and temp control advances between 1 and 16 (one number at a time). both the inlet and outlet tubes at the heater core are extremely hot. Any idea problem? how do I test the blend door actuator? Could it be anything else? "
Old Dec 12, 2009 | 04:50 PM
  #164
mannerofspeakin's Avatar
Awesome. Just did this. Took a while as some of the connections are a bear to get at in order to pull apart. Just hit the leads with a little bit of new solder. Good tips throughout the post. Funny as I came up with two extra screws ... oops. Oh yes and dropped the socket down into the abyss when removing stereo screw but pulled back carpet enough to reach down and grab it with finger tips. lucky me. I am not that auto mechanically inclined so I am very happy with how it went. Heat is working as it should now. Thanks to all. Taking the metal shield off from under the dash is a definite help.
Old Dec 16, 2009 | 03:28 PM
  #165
ShinkaZoomZoom's Avatar
Talking "It is my day of Luckee!"
I am sooooo glad to find this DIY repair. My temp **** was on full heat and only cold cold cooooold air was blowing out. It was FREEZing the other morning and this morning too! I haven't had a chance to do the diagnosis, but I'm confident this is my problem. I'm going to try this fix ASAP!
Old Dec 17, 2009 | 03:48 PM
  #166
boarderjosh10's Avatar
Resident Cool Guy
I am about to do this right now, its been about -5 out this past week and I finally gave up with having cold air always coming out.
Old Dec 22, 2009 | 08:26 PM
  #167
Lunacy's Avatar
Registered Abuser
Just figured out mine is broken 2 days after buying it. Luckily it is stuck on 13-16 and it's pretty chilly outsite. I'm taking it to the dealership tomorrow to see if they will do it for free. If not, I think I can manage the DIY.
Old Dec 23, 2009 | 05:09 PM
  #168
xfree's Avatar
Does anyone know if the same hack for the ipod would work for a satellite radio output jack?
Old Dec 27, 2009 | 01:08 PM
  #169
Lunacy's Avatar
Registered Abuser
Took me about 2 hours. Hardest part was finding the bolt underneath the steering column. I took pictures of a direct line of sight to the bolt.
http://www.e-imagesite.com/Files2/27519849.jpg
http://www.e-imagesite.com/Files2/1566900.jpg
Old Dec 31, 2009 | 02:04 PM
  #170
xfree's Avatar
Well I just got done searching for the bolt and finial found it, then I can on here real quick to see if anyone answered the question about if the ipod hookup would work like jack for any sound device like the ipod or satellite radio.
I wished I would have checked on here before the bolt search, thanks for posting pics to help anyone else.
Old Dec 31, 2009 | 05:14 PM
  #171
SBD69's Avatar
Can someone post a picture of what the connections should look like after the soldering has been done, thanks.
Old Dec 31, 2009 | 07:48 PM
  #172
seanh1150's Avatar
This just happened to me.
But i'm not smart enough to do this my self.
I will check and see what the dealer will charge, and i'll post back.
Old Jan 1, 2010 | 01:28 PM
  #173
Lunacy's Avatar
Registered Abuser
If your ac is for sure broken. Then it wouldnt hurt to go over each of the 3 solder points. All 3 of mine were bad. It just looked like a metal rod going out of the circuit board. After i put solder on each one, there was a nice pool of solder going around the circuit.
Example
They were going to charge me about $300. Which isn't bad but figured i would give it a shot myself first. Turns out it worked.
Old Jan 4, 2010 | 09:35 AM
  #174
rotary718's Avatar
Originally Posted by Wingnut
No heat and only cooling, or only heat and no cooling, or erratic temperature control?
The temperature control **** seems to have quite a bit of issues for early RX8 owners where the system will cool only, and not provide heat despite the position of the control ****. This can also work in the opposite way, only heating and no cooling. After living with it for a season, I finally pulled the heater control unit out and repaired the circuit board. It was simple to repair and because I was going to have to pull the unit out anyway to replace it, it was not much extra work. The replacement unit (part FE01-61-190) retails for $350, some vendors on this site sell it for $240ish, and I hear there are some that sell used parts for $125ish. It is definitely covered under warranty for those lucky enough to be under warranty.
If you do not have heat, or only have heat, IMHO it is most likey the AC/heater control unit. This is the part which has the AC/heat control buttons and *****.
Easy Diagnosis:
The easiest way to verify this is to turn on the radio, press and hold the power on/off button and press and hold the scan-up button for a second (full second). The word "A/C TEMP" should appear on the left of the display and a number from 0 to 16 on the right. I suspect yours will have the number 0 (or 16 if heating only problem) displayed no matter where you turn the temperature control ****. If this is the case you could turn the temp. **** to full heat and see if it goes to 16 after pushing down or to the right on the ****.
In a working system, the number moves evenly in increments of 1, from 0 to 16 as you turn the temperature ****.
Easy Fix:
I was able to take mine out and solder 3 loose connections to fix it.
The beginning steps are the same as for any radio removal procedure. Instead of reinventing the wheel I would like to direct anyone to John Masone’s excellent DIY for radio removal at this DIY:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-radio-removal-add-aux-input-36001/
or directly linked here:
http://www.whatsmyip.org/ipodrx8/
The procedure is basically the same until page 7, second frame. Here is the modified step at that phase:
Removal of Heater Control Unit
I did not take pictures of the next step which is basically removing the cover on the temperature **** side of the control which requires a small screwdriver to three plastic clips on the perimeter of the cover. This will be evident when you get it in front of you. I stripped the circuit board down further than you may need to because I was also repairing cracked defrost (windshield and rear) buttons with superglue.
Then re-solder the 3 joints indicated in the next photos. A little bit of heat and just a little extra solder and they should be good to go.
Front of Heater Control Circuit Board
Front of Temperature Control **** (3 connections noted)
Back of Heater Control Circuit Board
Back of Heater Control ****
3 Bad Solder Joints (Note cracks) Prior to Re-soldering
I did the power-button/up scan combination to get the head unit to display the dial position and it now travels even increments from 0 to 16, instead of jumping from 0 to 16 when pushed like before. And the temperature control works perfectly.
Good luck.
yo thanx alot dude your thread realy put me on in understanding the situation man. good looking out kee!
now should i attempt this .. lol
Old Jan 4, 2010 | 02:08 PM
  #175
Lil_Gato's Avatar
Thanks for the DIY on how to fix the heater...
Its been atleast three long and very cold years for me, For anyone who lives in mountain areas, they know that when winter comes around mountains get very cold, and for me when it was 28 degrees outside... it was 28 degrees in the car.
Thanks again for the help, and my biggest problem was just doing the solder, also the wingnut had a upside down picture of where the solder points were. I didnt know what to solder really at first, but to help whoever gets in the same pickle, just add more solder to each connector, thats all I did and now I have a working heater.
Thanks again.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
