View Poll Results: Rate my How-To (please)
5 Supa-Dupa!
78.95%
4 Good
15.79%
3 Blah
0%
2 Bad
0%
1 Sucked!
0%
0 Meatwad
5.26%
-1 Frylock
0%
-2 Master Shake
0%
Voters: 19. You may not vote on this poll
DIY: Radio Removal / Add an AUX Input
Old Aug 27, 2010 | 08:49 PM
  #126
ling_keven's Avatar
It works!!!!
I did on mine today, and i am proudly to say that it works perfectly
Attached Thumbnails DIY: Radio Removal / Add an AUX Input-dsc05267.jpg   DIY: Radio Removal / Add an AUX Input-dsc05269.jpg   DIY: Radio Removal / Add an AUX Input-dsc05270.jpg
Old Sep 18, 2010 | 03:07 PM
  #127
aaiceman's Avatar
I am looking at doing this and plugging in my iphone audio jack. Does anyone know if there is a cable that allows for a mic input to the iphone (and the rca jacks for left/right) that I can then run a seperate mic in the car for it?
Edit: I just did this to my car and every step was right as it should be! I have a 2005 AT. The only parts that were a bitch was the side bolt on the radio and getting the back radio plugs undone. If you have big hands, this is a toughy.
A Silent MP3 file to burn!
http://www.burninwave.com/#silence
Old Jan 6, 2011 | 12:54 PM
  #128
keithstone193's Avatar
need help....
Hey I did everything and even added a ground loop isolator but it still doesnt work. Everytime i put in a blank cd it will scan it and then spit it back out and say check cd? Im guessing all the rx8's are like that so im wondering how this hack could work... Please get back to me thanks
Old Jan 6, 2011 | 07:52 PM
  #129
SayNoToPistons's Avatar
Wheels, not rims!!
You need a CD with a silent file, not a blank CD................................................
Old Jan 6, 2011 | 07:55 PM
  #130
l008com's Avatar
Yeah sounds like a problem with the CD. If it's a "blank" CD, that's the problem. You need a cd full of silence.
Old May 15, 2011 | 06:46 AM
  #131
fc2se's Avatar
Former FC Owner
Originally Posted by l008com
http://www.whatsmyip.org/ipodrx8
I just wanted to show off how I installed my iPod ... LOTS more pictures than the average tutorial.
Thanks for the great pictures on the radio removal. I just installed an AuxMod Basic (audio only, no iPod controls):
http://www.sylfex.com/products/AuxMod/
that was previously in my wife's Mazda 3. I know this thread is old, but the tutorial is good. And the AUX input I installed is still available for purchase for a decent price of $60. It uses the Tape/MD input, so there is no soldering required.
Old May 16, 2011 | 08:54 AM
  #132
Go Steelers's Avatar
I agree 100%. I used the great pictures to remove my radio & install a GROM iPod adapter. Not sure I would have gotten the radio out without the full tutorial! Worst part was I spent about 20 minutes trying to find that damn 10MM bolt that hold the back of the radio in place. Turns out I couldn't find it because IT WASN'T THERE. Evidently the previous owner had the radio out and never replaced the bolt.
Old May 17, 2011 | 02:11 PM
  #133
slvrmzdrx8's Avatar
Stock - O - Licious
Is this a good solution. SO it really only cost but 5 bucks or so for cables, And some time to fit it all in? Sound quality is good?
Old May 17, 2011 | 09:00 PM
  #134
TYork's Avatar
2004 RX8 Engine #2
Wow thanks, fantastic DIY! Did mine today now I have all 16 discreet temp settings. Next project pass side power door lock repair.
Old May 18, 2011 | 12:24 AM
  #135
smegma69lol's Avatar
wtf
just install an aux cable in it bro
Old May 18, 2011 | 07:15 AM
  #136
TYork's Avatar
2004 RX8 Engine #2
Ha WTF is that I used this procedure to get at my temp control circuit board but woah is me I posted my success to the wrong thread. Damn enthusiasm I hate it when I do that.
PS - this is my first WTF post, took longer than I thought!
Old May 18, 2011 | 12:16 PM
  #137
slvrmzdrx8's Avatar
Stock - O - Licious
I think that the WTF was directed at me. However, unlike you, im not big into jumping into a DIY that only works half as good or half the time. I dont do anything half-assed, I do it once the right way. Just like anything else, research.
Old May 22, 2011 | 09:05 PM
  #138
zildijianxiv's Avatar
Thanks, works like a charm!
Old May 26, 2011 | 05:31 PM
  #139
faviodrummer87's Avatar
I did mine and worked perfectly. Tried to do my buddy's and he has a 6-cd changer and i did the same thing, but now the left speakers are mute... i double checked and resoldered everything and samething... i checked everything and no luck. Any ideas...? I swaped radios and on mine it works good but his HU doesnt... Also if you put the AM/FM radio it it works perfectly, but when you put a cd it only comes out from the right side speakers. and Yes i did soldered correctly and used Red on Right and White on left, and obviously, the ground.
Old May 27, 2011 | 09:39 AM
  #140
Feitl's Avatar
http://www.walmart.com/ip/Macally-Ca...vices/15120567
8$ and you can do the same thing, just plug and play
Old May 27, 2011 | 09:44 AM
  #141
alnielsen's Avatar
Show me one RX8 that came with a cassette player.
Old May 27, 2011 | 01:18 PM
  #142
profase's Avatar
Well, I hope someone can help me out. I've been working on this for a good while, but I must be doing something wrong, or my RCA->minijack cable isn't suited for the job.
First off, I'm not entirely sure which wire is positive and which is negative within the RCA cable. Mine doesn't have two separately insulated wires, but it has one wire down the center and then another braided around it. Which is which? (Granted, I've tried both ways and with the same result......)
My result: the audio is almost completely inaudible. If I put the volume at max, I can just barely hear it. Would this indicate the wire is too small, or the solder is inadequate? I compared my solder to post #126, and I would say it's of similar quality. Any advice?
John
Old May 27, 2011 | 02:54 PM
  #143
I would probably just go buy a new cable, the braided wire is probably the ground. I used a 3.5mm stereo audio cable and cut the tip off and inside it was two wire and braided wire around it, put the braided wire to ground put the white to the left and the other to the right.
Old May 29, 2011 | 02:34 AM
  #144
profase's Avatar
I made my own wire (took some 16 gauge speaker wire, soldered 3 wires to the solder joints on the 3.5mm jack) and then I soldered it to the radio PCB, and still no dice (same result, very quiet, can just hear it at max volume). Any other pieces of advice?
Old May 29, 2011 | 11:44 AM
  #145
Dumb question but is the volume on the device you're using all the way up?
Old May 29, 2011 | 01:26 PM
  #146
profase's Avatar
Yeppers, as up as can be. I've tried using my phone and my laptop as a source.
Old May 30, 2011 | 12:35 PM
  #147
profase's Avatar
It's like my signal isn't getting amplified at all. What could be wrong?
Old Jul 22, 2011 | 01:30 AM
  #148
griffin89's Avatar
i tried this diy, soldering went fine, but when i hooked everything back up, none of the lights on the headunit turned on, including the a/c lights, and the lcd screen above didnt turn on.
Any ideas on wht i did wrong? im really hoping i dont need a new radio
edit* well i desoldered everything and hooked it back up, and it still didnt work, so i ended up hitting the faceplate cuz i was pissed and it started working again, so i guess it was a loose connection. i ended up ordering the auxmod so hopefully thtll work
Old Aug 20, 2011 | 03:58 PM
  #149
SPHINX144's Avatar
Originally Posted by thew
good point but the pie was always here.. we just did not understand the firmware issues..
But also the P.I.E. is a very high quility input. It will allow you to use an Alpine CD controller as well. and accese it via the OEM controlls.. its just that we are converting that box to a RCA input for the other usees.. But for $90.49 shipped to Rx8 members free .. how can you beat that ..
will such adapter work with the factory satellite radio?
Old Aug 21, 2011 | 02:22 PM
  #150
ourfirstrx8's Avatar
Jbomb & Kimm
did it today worked awsome !! thanks 1008com..... i didnt have to deal with the side bolt uder the dash as the previous owner never replaced it! ..
