defrost vent pod
Old Nov 2, 2008 | 02:39 PM
  #126
Kane's Avatar
Originally Posted by Block8head
LOL i'm the one who made the pod... why would i want the pod
i mean she like the gauge with the (Chick Driven) on it
Legally the MS6 is owned by my wife and i'm the one who doing all the dirty work
I feel your pain - I own hers; but she gets to drive it and I end up doing all the dirty work...
BTW - that gauge is a custom one (with peak and warn) - let me know if you want to know where I got it made at.
Old Nov 2, 2008 | 02:54 PM
  #127
Mazurfer's Avatar
Surf Hard, Drive Hard
Originally Posted by paulmasoner
damn it, now i want to get rid of the scan gauge there, and add another gauge.
bump AFR over to the vent and add water temp on the dash center...
I'm in the same boat, but am seriously considering this!
http://www.plxdevices.com/products/dm100obd/
It would replace my Scanguage II all together, and I'd probably end up running more to it as well.
Don't blow this off because of the first crappy picture on the site in the lefthand corner of that page. Search around and you will see all it's capable of.......including "custom" gauges/backgrounds.
Old Nov 15, 2008 | 09:35 AM
  #128
Mazurfer's Avatar
Anybody wanna shed some light on how best to hold the gauge in this pod. What are you guys using?
Old Nov 15, 2008 | 11:01 AM
  #129
crazy glue.
(free bump)
Old Nov 15, 2008 | 11:14 AM
  #130
Rotr8's Avatar
whines all the way home
Hey Dave,
Heres how I did it, I didnt take any pics because I was to busy with the install but....
-First I had to modify my gauge, I cut down the two mounting post that are typically used for the gauge mount stands.
-Then I had to hack up the bulb connector to get to the bulb( gauge are going to be different with mine being mechanical I had a seperate bulb light source, will not apply to digital gauges)
-Wired and reassembled the light and taped it in place.
-I had to bore out the hole at the bottom of the pod significantly, not to fit the connectors but so they wouldn't pinch the wires at the back of the pod.
-By doing this I could now place the gauge all the way back in the pod with a nice snug fit, no need for glue or epoxy to hold it. (also didnt want to glue incase i ever need to get it out again...
-Mounted all my hardware neccessary for my gague(Boost/Vac = MAP sensor) behind the steering column, no one would even know its there,,,
-Wired it up, the bulb, I connected to my dimmer switch and ground...
-Drill out the rear most part of the defrost outlet, if you go near the front you will dril into the ac duct hardware...
-Ran the vac line through the firewall there was a nice place located right next to the washer fluid bottle and tied the vac into the vac hose running out of the LIM.
It took me a little longer(about 2.5 hrs) than I thought it would but it looks so freakin nice,,,
also Nick, 13Bturbofc has done it as well, https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/suporting-mods-pettit-supercharger-kit-157660/page5/
he may have some different techniques as well,,
Good luck...
Old Nov 21, 2008 | 12:16 AM
  #131
wow this vent pod is awesome! Definitely considering this now...
Old Dec 29, 2008 | 03:10 PM
  #132
Mazurfer's Avatar
Here's how my install went. It was a little unique due to the gauge I chose to use.
https://www.rx8club.com/showthread.p...89870#poststop
Old Feb 10, 2009 | 09:26 PM
  #133
Block8head's Avatar
i have 3 60mm left and will stop making them if anyone interested please pm me.....
Ben
Old Apr 29, 2009 | 11:03 AM
  #134
luis_o_98's Avatar
Ben
to bad he doesnt have 52 mm anymore i just got my gauge
Old Apr 30, 2009 | 08:11 AM
  #135
Block8head's Avatar
they all sold but you still can get it in 52mm
Email me @ xxredline9xx@aol.com for more info.....
i have 3 orders for 52mm about to be made, if you want 1 email me
Cheers
Ben
Old Sep 9, 2009 | 02:11 PM
  #136
Block8head's Avatar
Back from the dead LOL
Old Sep 9, 2009 | 03:02 PM
  #137
Rotr8's Avatar
COOL, does this mean you will be making more?,,, I know a few people have asked me about mine since you stopped making them...
Old Sep 10, 2009 | 11:58 AM
  #138
Block8head's Avatar
Wink
There is a GB going on , tell them to jump on it for a good Discount..
Here is the link: http://www.mazdas247.com/forum/showt...hp?t=123753844
Limited production only....
Old Sep 11, 2009 | 06:03 PM
  #139
Mazurfer's Avatar
Cool, I've had a few people ask after seeing mine as well.
Old Sep 17, 2009 | 01:34 AM
  #140
TorqueyPig's Avatar
Perfect spot for the gauge... I love it
Old Sep 17, 2009 | 09:28 AM
  #141
StormyWankel's Avatar
EVOLVChicago.org
Looks great
Old Sep 25, 2009 | 08:21 AM
  #142
TheWulf's Avatar
My 8 looks like a Smurf
The answer to my question might be obvious since I didn't actually try to install the gauge yet but I'm just trying to get a head start:
I test fitted my Prosport AFR gauge in my vent pod (which is awesome btw) but it wasn't a tight fit. Just wondering what's the best way to ensure the gauge stays in place? I was thinking of adding some thin foam to the inside ring of the gauge pod but I'd like to know what you guys did.
Old Sep 25, 2009 | 09:02 AM
  #143
I just wrapped mine in electrical tape until it fit snug.
Old Sep 25, 2009 | 10:38 AM
  #144
RedRocket8's Avatar
PISTONS are for (|)
looks good, nice placement
Old Sep 26, 2009 | 08:15 AM
  #145
Block8head's Avatar
Smile
The reason why it wasn't snug fit because some of the aftermarket gauge are slight bigger than the other even though they are 52mm..
All you have to do is use double side tape and rub of one side with water so it won't be sticky, use the other side and stick it inside the pod and slide the gauge in the....
hope that help...
Ben
Old Sep 26, 2009 | 08:39 AM
  #146
Mazurfer's Avatar
Lucky for me as mine fit snugly and while I can rotate it, but it takes a decent amount of force........should I have to do so. Once it's set, it doesn't move.
Old Sep 26, 2009 | 09:04 AM
  #147
Rotr8's Avatar
Mines pretty much the same,,,,
Old Sep 27, 2009 | 09:56 AM
  #148
Block8head's Avatar
electrical tape will be hard for you to rotate the gauge and it also ddiffical for you to take it out inthe future..
single side tape work best.....
Ben
Old Sep 27, 2009 | 10:01 AM
  #149
nuke0907's Avatar
Never Blend In
i used electrical splicing tape. its a little thicker than electrical tape and it has a rubberized texture. the more you pull it the thinner it will get allowing you to get the proper fitment.
200.mph
Dec 10, 2018 03:49 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Forevermore
Sep 20, 2015 01:04 PM
