Cumulative Synthetic Oil Discussion
Old Jan 17, 2005 | 01:10 PM
  #101
Texas 8's Avatar
Integrity First...
pennzoil 5-20
Old Jan 17, 2005 | 01:29 PM
  #102
NomisR's Avatar
BTW, mobile 1 has this 0W20 but the bottle says recommended for use on Ford & Honda engines for 5w20 or something like that, would that be ok?
Old Jan 17, 2005 | 01:35 PM
  #103
MELRX8's Avatar
"RX-8 my stress reliever"
Castrol GTX 5W-20
Old Jan 17, 2005 | 01:46 PM
  #104
TooBIG's Avatar
Redline 5W-20
Old Jan 17, 2005 | 01:58 PM
  #105
Nubo's Avatar
Lubricious
Mobil1 5w-30.
Old Jan 17, 2005 | 02:10 PM
  #106
Tigster's Avatar
RX8 ADDICTED!!!
Mobil 1 5w-20
Old Jan 17, 2005 | 04:03 PM
  #107
kellybrf's Avatar
penzoil 5-20
Old Jan 17, 2005 | 04:17 PM
  #108
blksf8's Avatar
castrol GTX 5w-20
Old Jan 17, 2005 | 05:15 PM
  #109
jbaseball's Avatar
Try to catch me!
5w-20 (ducking) Castrol
Old Jan 17, 2005 | 05:25 PM
  #110
ZoomZoomH's Avatar
Mulligan User
Motorcraft Syn Blend 5w-20
Old Jan 17, 2005 | 06:21 PM
  #111
G-ReX's Avatar
A Torque-Free Zone
Castrol GTX 5w-20 also.
Old Jan 17, 2005 | 11:21 PM
  #112
Rick's Avatar
pennzoil 5w-20
Old Jan 18, 2005 | 12:11 AM
  #113
jaedcem's Avatar
Originally Posted by Tigster
Mobil 1 5w-20
When did that come out? Last I checked, Mobil 1 was only available in 0W-20 or 5W-30, but not in 5W-20.
Old Jan 18, 2005 | 12:22 AM
  #114
shakRpahX8's Avatar
Unknown
Shell 10w-20
Old Jan 18, 2005 | 12:53 AM
  #115
SilverTrigger's Avatar
Castrol-GTX 5W-20
Old Jan 18, 2005 | 02:32 AM
  #116
azureknight's Avatar
anything wrong with dealership oil?
Old Jan 18, 2005 | 08:22 AM
  #117
EvilBostonRX8's Avatar
Its been around for quite some time. A couple years at least.
Old Jan 18, 2005 | 08:30 AM
  #118
srm858's Avatar
Only Castrol 5W-20. Our VW Passat has run on Castrol since new 5 years ago. I change it every 5k. Turbo Passats have had problems with clogged oil pumps from oil sludge, 2 of my friends with the same car have had oil pumps fail. VW now recommends synthetic oil. I checked the inside of my oil pan after 70k miles with Castrol and it was perfectly clean. I now use Mobil 1, per VW, but Castrol has never let me down in over 20 years. My Saturn ran on only Castrol and I sold it to a friend when it had 175k miles on it. Didn't burn any oil and ran perfectly. Stick with Castrol and you will do fine.
Old Jan 18, 2005 | 08:53 AM
  #119
Gambit's Avatar
Screw gas mileage
Castrol Syntec 5W-20, I believe
Old Jan 18, 2005 | 10:34 AM
  #120
Paul_in_DC's Avatar
Rotary Public
Synthetic Oil?
FIRST - Calm down, I use Castrol GTX 5w-20.
SECOND - A buddy once explained to me a strange side effect of synthetic oil. He said that because it lubricated so much better, and had much less friction than normal oil, it took much longer for his car to warm up, so... it took much longer for his heater to warm up. With the anemic heater we have in the 8, I don't think I'd much care for such a side effect.
Has anyone experienced this? Confirm? Falsify? Flame?
Old Jan 18, 2005 | 12:01 PM
  #121
Gord96BRG's Avatar
BS. If it made that much difference to internal friction, you'd see a significant mileage jump from switching to synthetic - and you don't. I've run synthetics and dino oils in various cars through Canadian prairie winters - and the oil doesn't make a degree of difference to the warm-up or heat output.
Regards,
Gordon
Old Jan 18, 2005 | 02:33 PM
  #122
galleychief's Avatar
Unbalanced & Unmedicated
I use whatever the local Mazda dealer uses. . .
Old Jan 20, 2005 | 11:21 AM
  #123
jaedcem's Avatar
My Mobil dealer (last year) said they don't make 5W-20 Mobil 1, and that my Ford van should use the 0W-20 Mobil 1, as it was designed for those vehicles needing 5W-20. I had not heard that they added the 5W-20 viscosity yet.
Also, I just checked the mobil1.com website, and 5W-20 is not listed. Are you talking about a different 5W-20 Mobil oil?
Old Jan 20, 2005 | 11:26 AM
  #124
jaedcem's Avatar
The heat generated by the friction of a few well-lubrucated metal parts sliding together is insignificant compared to the power of The Force. er- I mean - insignificant compared to the heat generated by combustion.
Old Jan 20, 2005 | 11:51 AM
  #125
aruffell's Avatar
Doesn't the user manual state NOT to use Synthetic oils? The RX-8 actually burns oil and I believe I read that synthetics caused problems due to this... please do your car a favor and check w/ Mazda.
