View Poll Results: Rate my How-To (please)
5 Supa-Dupa!
78.95%
4 Good
15.79%
3 Blah
0%
2 Bad
0%
1 Sucked!
0%
0 Meatwad
5.26%
-1 Frylock
0%
-2 Master Shake
0%
Voters: 19. You may not vote on this poll
DIY: Radio Removal / Add an AUX Input
Old Oct 17, 2008 | 06:49 PM
  #101
dothackRAVE's Avatar
<3 Rotary
The AUX input is shutting off. I don't know how the previous owner did it, but the cable and such looks EXACTLY like the ones in OP's site.
CD works fine.
Old Apr 22, 2009 | 02:01 PM
  #102
White_Shadows's Avatar
I know I know old thread, but if I made a new one then I'd be "not searching". Darn Forums.....
Anywho, How hard would it be to hack into the "load" button if you don't have the 6disc and get that to play instead of trying to make a blank cd? Does anyone know the OEM Head Unit board that much?
Old Apr 22, 2009 | 02:06 PM
  #103
Dur or using the Tape button?
Old Apr 24, 2009 | 03:39 PM
  #104
Ok someone post pictures of your actual solder job because I sat with this for hours and could not for the life of me get all four wires down without something touching or being horrably uncomfortable with how it was sitting before I finally flew the white flag. Although now I'm reading and whats this PIE thing?
Old Jul 28, 2009 | 02:06 AM
  #105
Twiztog43's Avatar
CA
i have a question, before all of this, did you disconnect the battery or is that not needed?
Old Jul 28, 2009 | 02:15 AM
  #106
l008com's Avatar
You definitely want to disconnect the battery!
Old Jul 28, 2009 | 02:27 AM
  #107
Twiztog43's Avatar
ok, cause that wasnt part of the DIY
Old Aug 8, 2009 | 07:57 PM
  #108
SayNoToPistons's Avatar
Wheels, not rims!!
So let me get this right, I have to purchase the CD in order for it to work?
Old Aug 8, 2009 | 08:00 PM
  #109
l008com's Avatar
You can burn your own. Or buy one.
Old Aug 8, 2009 | 08:08 PM
  #110
Wheels, not rims!!
What fire do I burn onto a CD-R? I searched "silent wave" and "silent wav" on google and came up with many irrelevant results. I got off work at 4pm and quickly got to work.. Just finished up and was excited ot play my ipod through my radio but wasn't as simple as I expected it to be . Also lost a socket through the carpet trying to tighten the bolt in .
Old Aug 8, 2009 | 08:11 PM
  #111
l008com's Avatar
Use an audio program to make an 80 minute track of silence. Probably a piece of cake in GarageBand
Old Aug 8, 2009 | 08:23 PM
  #112
Wheels, not rims!!
I don't have a Mac. Can you recommend a program that allows me to make an adequate file?
BTW, instead of using the 1/8" male plug, I brought a 1/8" female jack and mounted it to the cubholder for a stealthy install. Took a bit more work because I have to solder and drill a hold to fit the jack though.
Old Aug 8, 2009 | 08:26 PM
  #113
l008com's Avatar
I don't know anything about windows. I'm sure someone here does. Or, you could always just order the disc online. Good luck.
Old Aug 8, 2009 | 09:00 PM
  #114
Wheels, not rims!!
Have been trying to search for a program or a file on the internet that will let me burn a silent audio CD for the past hour. Pretty much used every keyword possible.
I am going to try recording silence on windows sound recorder in wav and try to burn it onto a cd and see if that works. Only thing is that it only allows 60 seconds of recording time.
Old Aug 8, 2009 | 09:06 PM
  #115
l008com's Avatar
On a Mac just make a silent audio file in garageband, import it into itunes and burn it as an audio CD. Sounds like you need to just purchase the CD on the DIY page. Windows is.... not useful for performing tasks.
Old Aug 8, 2009 | 10:55 PM
  #116
Wheels, not rims!!
Done. Had another forum help me out and I created a 80 min wav file within seconds.
Old Oct 6, 2009 | 10:27 AM
  #117
Mr. Pilot's Avatar
Which forum was that file in? I can't believe that people would pay to get a CD with nothing on it......
Old Jan 14, 2010 | 12:19 AM
  #118
padilla08's Avatar
hey, guys. little help here.
so i had this done, but i didn't use a ground loop isolator nor an ipod adaptor. so from the unit, the auxiliary cord plugs in straight to the ipod. it worked great except for the lower volume.
problem now is, after just a day, the CD function isn't working. it sucks in the cd, but it doesn't play. i press the CD mode or even the button to change modes and nothing's happening. i tried other CD's and still nothing. input? thanks a lot.
Old Jan 14, 2010 | 07:32 AM
  #119
Mr. Pilot's Avatar
I did mine a couple months ago and haven't had any issues. I did use a ground loop isolator or an ipod adapter so I don't think that would be the issue. My suggestion would be to check your soldering connections, you probably crossed a connection or something like that.
Old Feb 3, 2010 | 01:45 AM
  #120
rudiau's Avatar
Rudi
1008com
Reading thru your http://www.whatsmyip.org/ipodrx8/ article.
"and pop in a CD containing 80 minutes of pure silence. The radio will only pick up your new AUX-Input when a CD is playing."
Do you only have to do that once, if yes how's that work. Do you leave it going for the full 80mins
Old Feb 3, 2010 | 01:52 AM
  #121
l008com's Avatar
Yes you leave it playing, while the radio thinks it's playing the CD, it actually plays the ipod.
Old Feb 15, 2010 | 09:04 PM
  #123
fischer99's Avatar
Awesome DIY. i did this a few months ago in a couple of hours. Thanks for all the great detail. I am using this with my belkin iphone adapter and drilled the aux plg into the face plate. I did have to use ground isolator to get rid of the hum and squeel from the engine noise but i just tucked that behind the face plate too with no issues. I used the MS sound recorder to make my silent cd.
Thanks again this was a huge $ saver. In all this was about $10 and 2 hours.
Attached Thumbnails DIY: Radio Removal / Add an AUX Input-car.jpg
Old Mar 11, 2010 | 12:43 AM
  #124
mopiko's Avatar
Hi i have the 05 rx8, i am going to buy the xcarlink adapter.
I was wondering if the head unit has an aux-in ready for plug and play?
If so, which or where is it?
Please advice.
Old Apr 25, 2010 | 08:20 AM
  #125
Shijin-Kun's Avatar
Rotary Power!
I did the install yesterday, took roughly about 3 hour just cuz we were slacking off and having trouble removing the head unit because of the connectors. I used a ground loop isolater so i hear no static or interference. The DIY had plenty of step by step pics that made it a lot easier.
