DIY: Oil Catch Can Install (basic)
Old Aug 19, 2009 | 10:07 AM
  #101
Leejin's Avatar
Thanks guys.
I've never been helped out so much on a forum. I traded my Maxima in for my 8, and the Maxima guys are pretty cool.
But the technical knowledge of this community is off the charts. Thanks everyone.
Old Aug 19, 2009 | 10:17 AM
  #102
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Originally Posted by Leejin
Thanks guys.
That's because people on here know more about the cars than the dealers... Your options are to either learn about the car, diagnose and fix the problems yourself. Or go into the dealer, have them charge you an astronomical amount while guessing at what the problem could be based on whatever your check engine light code is.
I took my car in and their solution was to... void my warranty and replace all aftermarket parts back to stock to see if that fixed it.
Seriously, read through some of the experiences people have had with dealer service departments. Even if you screw something up and have to buy all new parts, its still cheaper than paying a dealer.
Old Sep 6, 2009 | 09:05 PM
  #103
Sparks91188's Avatar
The elusive one
True story I got screwed with a 1600 bill for replacing my clutch after it burned out. My car use to be a lease car and it was never checked. I never ride it or anything then one day it just gives out and my day told them to fix it. I had to pay for it out of my pocket. I was pissed. I got on here and found all the info I need where I could have solve the problem my self. Long story short I do everything my self and it is all thanks to this community. They have the knowledge and thats what makes me glad to be an 8 owner is we are all one big rare happy family.
Old Nov 1, 2009 | 09:36 AM
  #104
Huey52's Avatar
Registered Zoom Zoomer
Great DIY Vyn (although I must stop looking at these as I can't resist my own mod's).
Attached Thumbnails DIY: Oil Catch Can Install (basic)-oil-catch-can.jpg
Old Nov 10, 2009 | 02:42 AM
  #105
madcows's Avatar
Hey guys.. Just thought I'd chime in..
I've been recently looking into catch cans for my other car (awd turbo DSM), and thought I'd share some info that might be applicable here.
For those that don't know, the purpose of routing line from and engine block/head (or the filler cap in the case of the RX-8) is to evacuate harmful gasses from sitting inside your engine, and contaminating your oil. If you simply just capped off the port on the oil fill tube, the gasses from the oil would eventually build up enough pressure to pop your dip stick out. Besides potentially making a bit of a mess, the gasses could also ignite. I don't know about you, but I don't like the idea of a fire under the hood of my car.
Now, there are a couple of reasons why manufacturers run a line from the block/head (or oil filler cap) into the intake:
1) The gasses are nasty, so burning them during combustion is the most ideal thing to do from an environmental standpoint.
2) The vacuum action from being tied in to the intake is the best way of evacuating these gasses in the engine.
With that said, you can certainly go ahead and place a catch can between the oil fill and a breather like what has been shown in all the previous examples. However, I would prefer to suck out as much of the gasses as possible (while trying to prevent gunk from getting into the engine). So, the way I would do it is as follows:
Oil fill -> catch can -> air compressor filter [or] carbureted fuel filter (http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 and http://www.amazon.com/gp/product/B00...d_i=B001DRHMXW) -> lower intake maintenance ports
What happens in this setup is this: The vacuum from the lower intake maintenance ports suck the gasses from the oil fill (and therefore oil pan) which must pass through the catch can. Most of the heavy oils that were sucked out wont go past the catch can, and will accumulate on the bottom due to gravity. The little bit of oil that might get past the catch can will get separated from the gasses once they hit the filter, so only the gasses make it into the engine. There are many people out there who just use the husky filter as both catch can and separator.
note: when doing any catch can setup where part of the circuit routes to the intake, your system should NOT be employing a breather AT ALL, or else you will probably be sucking in unmetered air to the engine.
Old Nov 10, 2009 | 02:53 AM
  #106
Jon316G's Avatar
Grasshopper
Now that's thinking with your dip-stick:
DIY: Oil Catch Can Install (basic)-castrol-use-your-dipstick.jpg
Maybe I missed something here, but I don't recall anyone suggesting a breather on the intake.
We install a breather on the catch-can and simply cap the intake fitting.
Also note, the '06 models and higher already have the line routed to the lower intake manifold, so no catch can/hose re-routing is needed.
Old Nov 10, 2009 | 03:26 PM
  #107
madcows's Avatar
One of the set-ups mentioned looked like the catch can was running to the intake, while still having a breather on the can. Even if not, I just thought it was worth mentioning.
As for those of use with '04 models (me!), I just thought it was worth while to suggest routing the hoses to the maintenance ports.
Old Jan 17, 2010 | 05:01 AM
  #108
always.anthony's Avatar
is looking for his torque
thread revival.
um, my hose from the oil fill up tube does not go directly to the intake... looks like its being run down to the engine.
how do i install my catch can now?
Old Jan 17, 2010 | 05:07 AM
  #109
Jon316G's Avatar
Grasshopper
always.anthony- Only the '04 and '05 models have it routed to the intake.
A redesigned oil filler neck was introduced to run down to the maintenance ports on the intake manifold.
If you have this design, you don't need a catch-can.
Old Jan 17, 2010 | 09:31 AM
  #110
Kane's Avatar
Yes you do....it just moves the gunk away from the TB so you can't see it... but it's still there.
Old Jan 17, 2010 | 10:54 AM
  #111
Vyndictive's Avatar
True... You don't "need" a catch can. It won't cause the problems for you like it did for me.
However, Kane is correct also... all the oil that would go into your intake is now going into your lower intake minifold where, in theory, its burned off...
But it is best just never to re-introduce that crap into your engine.
You can run the hose from your oil filler neck to the catch can. Put a breather on the exit port of the catch if you'd like, or run it back to the maintenance port like OEM. OR, like I capped the intake port on the intake, you would need to purchase vacuum caps and cover the maintenance ports on the lower intake manifold if you went the breather route.
Old Jan 17, 2010 | 02:26 PM
  #112
ah ok, thank you so much!
um, there should be a little nipple thingy i can cover with a rubber cap down near the maintenance port right? (for if i want a breather)
and then if i want, i could just splice into that hose and stick my catch can in between the connections (routing back to maintenance ports)
i was going to have a catch can for a month, and if i saw nothing in it, i would just revert back.
thanks for replies guys!
Old Mar 28, 2010 | 10:11 PM
  #113
ShellDude's Avatar
weeeeeeeeee
Here's my contribution to this thread already full of win....
3/8" hose
3/8" plug
ebay catch can
3/8" breather filter
2 zip ties
Attached Thumbnails DIY: Oil Catch Can Install (basic)-p3281886.jpg   DIY: Oil Catch Can Install (basic)-p3281887.jpg
Old Mar 29, 2010 | 07:43 AM
  #114
Mazurfer's Avatar
Surf Hard, Drive Hard
^....................hell of a breather/vent tube there Dude!
Old Mar 29, 2010 | 10:44 AM
  #115
ShellDude's Avatar
weeeeeeeeee
yeah, I might flip the intake for the catch can so that the breather fits directly on the end of it... I've also got a megan can I might go with too. The ebay can came with a ton of tubing... figured I'd put it to use :p
Old Mar 29, 2010 | 03:05 PM
  #116
Mazurfer's Avatar
^..............nuttin wrong with it of course, but you could always use the extra to extend the coolant bottle overflow to get it down below the power steering connectors. That's what I did.
Old Apr 13, 2010 | 02:59 PM
  #117
venom914's Avatar
can anyone help me? i have a question about installing, heres my thread
https://www.rx8club.com/series-i-trouble-shooting-95/catch-can-install-question-195210/
Old Apr 14, 2010 | 06:22 AM
  #118
Huey52's Avatar
The coolant overflow is a much smaller inside diameter hose however.
Old Apr 14, 2010 | 06:33 PM
  #119
Mazurfer's Avatar
That may be true in some if not all cases, but we aren't talking a lot of pressure here....at least we hope not! All I did was slide the hose all the way on and use a hose clamp. The idea is still that it will flow downhill all the way out the bottom of the car. If it's able to build enough pressure to back up and come out of that joint/union, then you got serious issues and probably no coolant left at that point anyway!
Old Apr 15, 2010 | 07:42 AM
  #120
Huey52's Avatar
I just used some surgical tubing that was the same OD/ID size.
Old Apr 21, 2010 | 04:09 PM
  #121
Tamas's Avatar
Registered Lunatic
I have a question.
On the accordion hose assembly, there are actually three different nipples connected to three thoses. One of these is the one that goes from the oil filler neck to the intake. What are the two other hoses for? Are they not causing similar gunk to be blown into the intake?
I mean, we eliminate one source of gunk by installing the catch can, but may there be more that can cause similar issues?
Old Apr 21, 2010 | 11:35 PM
  #122
Kane's Avatar
Other two are for Jet-Air and OMP Pump... they do not blow gunk into intake.
Old Apr 27, 2010 | 07:35 PM
  #123
Wig92's Avatar
can someone enlighten me about using the 2 hoses vs. using breather and capping intake.
i have an 05 and definately want to do this but dont know if i need the breather where would i get one too??
help is appreciated, thanks
good DIY btw
Old Apr 27, 2010 | 07:38 PM
  #124
Jon316G's Avatar
Grasshopper
If you want to be extra sure that no vapors get into the intake, install a breather on the catch-can instead of routing a 2nd cable to the intake.
  #125
ShellDude's Avatar
weeeeeeeeee
Breather is cooler IMHO... You can get hosing, vacuum plug, and breather all from an auto parts store. Advance had everything I needed, all surprising close together.
