DIY: RX-8 Oil Change for dummies
Rating: Thread Rating: 5 votes, 5.00 average.
Old May 30, 2005 | 05:56 PM
  #101
Ellar's Avatar
Originally Posted by S3/P3/E2
<snip>
This is where the warning bells go off. Am I willing to chance my life on the "emergency" scissors jack graciously provided by Mazda (you know, the one that was provided without a spare tire unless you ordered it)? Short answer: oh hell no.
<snip>
Good choice. I actually watched the big screw spontaneously strip right through one of those jacks once. It happens with no warning, very quiet and very fast. Like someone lowering a hydraulic jack.
Old Jun 7, 2005 | 01:01 AM
  #102
elysium19's Avatar
Originally Posted by syntrix
Anyone fit the Mobil M1-110 yet?
And when I meant cheap Mazda filter, I was referring to the PRICE of the filter. The internals are the same, and motorcycle filter has to work MUCH harder than a car filter. So rest assured, that little filter must be doing great things for the rotory!
I installed a mobil1 M-110 today, and seemed to work fine. It's a little bigger than the one that was in there and kinda hard to get a good grip on, but seems fine.
Old Jun 12, 2005 | 04:35 PM
  #103
mjcampb's Avatar
Thanks to all the previous posters. First oil change today at 2300 miles. Used the pureone filter, fram sd-2 sure drain and castrol oil (4 qts). Everything went smoothly, except the factory filter, which was very much more than "hand" tightened.
Had I not read this thread, my experience would probably have been much different, thanks again RX8club!
Old Jun 12, 2005 | 05:10 PM
  #104
StealthTL's Avatar
Smile Sd-2.....
Istalled a Sure Drain valve (SD-2) a while back, and just changed my oil for the second time with it installed.
Very impressed, the brass cap covers the ball valve, keeps it nice and clean, and it drained reasonably quickly - I cut the drain hose down to a couple of inches, so it just clears the bottom of the car.
Capped, the whole thing is WAY lower profile than the Fumoto setup, which needs the 'extender' so sticks out even more.
S
Old Jun 22, 2005 | 10:11 PM
  #105
x-ped's Avatar
What happened to the pics?
Old Jul 5, 2005 | 07:56 PM
  #106
slllygrl10's Avatar
EX-Member
Post the pics again pls would help
Old Jul 5, 2005 | 08:12 PM
  #107
Michael's Avatar
Yes please.
Old Jul 5, 2005 | 08:52 PM
  #108
just a note i am also using the fram sd-2 sure drain. put it on at the first oil change. now a 28K mile it is a great investment. think it was 12 buck and you can get it at auto zone or i guess any other parts store.
Old Jul 5, 2005 | 11:51 PM
  #109
silentgame's Avatar
is anyone using synthetic? I've always used Mobil 1 full synthetic in my two vtec cars and i drove them to hell and back with no problems.
Old Jul 6, 2005 | 12:13 AM
  #110
therm8's Avatar
Bummed, but bring on OU!
Well, the synthetic debate raged for quite some time here. The conclusion I think, after people emailed MNAO, was the Mazda will not recommend the use of synthetic oil, simply because they never did any long term testing of its effects. That being said, many people here run synthetic. Me, I stick to dino and see no benefit whatsoever in using synthetic oils on any engine, if you are going to change the oil every 3k miles, but that's my opinion.
Old Aug 16, 2005 | 12:33 PM
  #111
SlowLude's Avatar
Were there supposed to be pics with the original post?
Old Aug 16, 2005 | 12:51 PM
  #112
Go48's Avatar
Yes, there were images but they disappeared some time ago and the mods have not been able to resurrect them. I happen to have the first part of the thread saved on my hard drive and will send you a zip file that includes the images. PM me with an e-mail address and I'll send them now.
Larry
Old Aug 16, 2005 | 01:35 PM
  #113
BlueRenesis82's Avatar
Registered Tracker
Its not a big deal for the pics, its pretty idiot proof if you have any idea what you are looking for and/or have a manual.
Old Aug 18, 2005 | 10:18 PM
  #114
croakar's Avatar
so the drain plug is on the passengers side of the oil pan?
Old Aug 18, 2005 | 10:19 PM
  #115
staticlag's Avatar
The Professor
Yes.
Old Oct 22, 2005 | 09:23 AM
  #117
Go48's Avatar
I would be concerned that some significant quantity of oil, including the heavier metalic particulates that settle to the bottom, would remain in the oil pan. Not to mention that I can crawl under the car many times for that kind of money.
Old Oct 22, 2005 | 07:24 PM
  #118
kraeji's Avatar
Youre dangerous.. *CHOMP*
What type of oil filter wrench are you guys using for the OEM filter?
Old Oct 22, 2005 | 09:32 PM
  #119
Registered Tracker
my hand
Old Oct 22, 2005 | 10:32 PM
  #120
Gerael's Avatar
Rexella's Daddy
anyone try using a magnet at the bottom of the oil pan to take up additional metallic particles?
i know tranny pans have em... maybe i'll just stick some magnetic strip on the bottom of the pan outside... then once in a while take off the pan and clean it up...
Old Oct 22, 2005 | 11:30 PM
  #122
Registered Tracker
pretty sure that the stock plug is magnetic.
Old Oct 23, 2005 | 01:00 AM
  #123
Gerael's Avatar
Rexella's Daddy
does it pick up stuff?
Old Oct 23, 2005 | 05:26 AM
  #124
Go48's Avatar
You can get one from a dealer or just pick up a Type F at an auto parts store.
Old Oct 23, 2005 | 09:03 AM
  #125
Registered Tracker
If you are taking care of the car, there shouldn't be a lot of stuff for it to pick up, but I seem to remember there being stuff on it after the break in period.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
