X-box Media Center
Old Nov 6, 2004 | 10:03 AM
  #76
truemagellen's Avatar
Attracts tree branches
Originally Posted by Thommino
Somebody know if the RGB sygnal that come out from Xbox with RGB Cable (scart) is RGB PAL or RGB NTSC? If is RGB NTSC I could bypass my converter PAL Composite-->RGB NTSC and increase video quality
Thank
I looked into that before...the specs are different I believe...but why don't you give it a try anyway...you can always return the scart cable
Old Nov 6, 2004 | 10:18 AM
  #77
Thommino's Avatar
Too difficult to built it!
Old Nov 6, 2004 | 12:49 PM
  #78
thew's Avatar
Thews8
I am going to start sellling Modded Xboxes to.. Since there is such a demand for them. But i still think the Carputer kit is the way to go.
as for Sound you will use the PIE /Aux input .. look in my vendor forum for mor info
Old Nov 6, 2004 | 01:55 PM
  #79
Japan8's Avatar
Int'l Man of Mystery
Check out this... http://www.mini-itx.com/projects/bmwpc/
Old Nov 6, 2004 | 03:04 PM
  #80
flyboyindy's Avatar
Be careful selling modded X-boxes Matt... Microsoft could have a big issue with it. The chip companies are already walking a fine line with the sales of the chips as it is. There is a reason why people cant legally download a working version of X-box media center... Microsoft is really playing big brother on this one.... Anyways... good luck.. but be careful how you lable your new "product" =P
Old Nov 6, 2004 | 07:16 PM
  #81
Thommino's Avatar
Nothing about Rgb and Xbox? RGB PAL or RGB NTSC?
Old Nov 7, 2004 | 10:57 PM
  #82
Spyder_doo's Avatar
Turbo'd 5
Hey man the only way you can kinda sorta "legally" sell these consoles modded is to sell them bone dry. Meaning no bios or OS can be present. This is basically all that you can get from anyone who sells them pre-modded. Oh and by the way if you need a download of the X-player media center let me know, I think I still have my copy. If you have any legal ?s just ask me. I've looked into and researched this topic a good bit. There are many "loop holes" in Microsofts case arguement.
Jamie
Old Nov 11, 2004 | 04:44 AM
  #83
mirricleboy's Avatar
sound wicked, im wanting to put a x-box in my boot witha 15" moniter mounted in the boot lid. hope i can do it with the rx-8.
With you install can u still use the sat Nav?
Old Nov 17, 2004 | 11:52 AM
  #84
aruffell's Avatar
Thanks for all the great info! After seeing flyboyindy's setup I rushed out to buy an XBOX. I am now going nuts trying to figure out what mod chip to buy and where to get all that I need to make it run XBMC. Anyhow, what I'd like to ask the forum readers that have installed an XBOX in their 8s is:
1) Any issues with crash harddrives if you get a pot hole while it is in use?
2) Where did you install it? Flat in the well? If so is it covered? what about ventilation? I'd rather have it attached to the back seat but it is quite heavy and I think it would not work too well for the DVDs.... can anyone post some pics of their install? I mean pics of the boot/trunk whatever it is called...
thanks!
Alex
Old Nov 17, 2004 | 12:17 PM
  #85
Thommino's Avatar
here!
Attached Thumbnails X-box Media Center-mini-dsc01308.jpg   X-box Media Center-mini-dsc01314.jpg   X-box Media Center-mini-dsc01270.jpg
Old Nov 17, 2004 | 05:13 PM
  #86
thommino doesn't have a job he just works on his car all day
hey thommino if you are having noise problems (audio or video noise) talk to flyboy or thew they figured out a solution for the xbox
Old Nov 17, 2004 | 05:54 PM
  #87
Thommino's Avatar
I have Video noise, but it's the converter. They are working to give me a better version.
Next week for update. I have a little noise audio, but it's my FM Modulator.
I have not a job. I'm an University Student. I finished my car job about 2 weeks ago:
Look (In Italian):
http://www.thommino.com/images/Mazda...r_Su_Mazda.pdf
Old Nov 17, 2004 | 06:35 PM
  #88
Blue87Sport's Avatar
Rotary only since 1980
My son wants to mod his Xbox. Any recommendations on the best mod chip? His Xbox is at least a year and a half old if that make a difference.
Old Nov 17, 2004 | 07:03 PM
  #89
Look (In Italian):
I'm telling you talk to flyboy or thew they have the answer to your video noise problem! and thew has the answer to your audio noise (no more fm modulator)
Old Nov 18, 2004 | 03:44 AM
  #90
Thommino's Avatar
I look Thew Garage! Where is tha answer to the problem (Video)? I cannot Find it.
Old Nov 18, 2004 | 05:21 AM
  #91
thew's Avatar
Thews8
what Thom ?
you need Noise Filters and or a Gorund loop Isolator. i will ship to you go buy it on my site
Nosie filter and the Ground loop iso in the electronics section
http://www.rx8garage.net/?page=shop/...346062399c168d&
http://www.rx8garage.net/?page=shop/...46062399c168d&
Old Nov 18, 2004 | 07:58 AM
  #92
Thommino's Avatar
But this are for Audio! isn't right?
I need a Video Xbox filter. I hope www.converters.tv send me a better converter. They are studying a new version Pal Composite to RGB NTSC for me.
Old Nov 18, 2004 | 08:13 AM
  #93
thomino the groud loop can be fixed through the audio and will then fix the video it works great for flyboyindy
Old Nov 18, 2004 | 08:37 AM
  #94
Thommino's Avatar
I should buy also Pie Aux-in because I connect my switch with FM Modulator now!
I don't understand like an audio filter Can adjust video source.
My converter is installed after my A/V Switch!
Old Nov 18, 2004 | 02:38 PM
  #95
thew's Avatar
Thews8
yes you can run the Vidoe or audio thur it. the lines you see are from your Alternator. the filter will make the video lines or noise go away . Yes the PIE box allows you to plug your audio rca into the Radio and switch it on with the CD button.
Old Nov 18, 2004 | 03:07 PM
  #96
actually thew I believe flyboy just hooked up the audio, one set going into the box for each input and one set going out of the box, no video and it fixed the audio AND the video problems, flyboyindy you want to chime in on this one?
Old Nov 18, 2004 | 05:09 PM
  #97
Thommino's Avatar
No I tryed to connect my Xbox to 220V (without alternator) and the video problem there is again.
Old Nov 18, 2004 | 05:27 PM
  #98
thommino definitely get the pie box...the ground loop isolator should fix the ground loop caused by different grounding points on the audio
my guess is you have the inverter grounded at a different point then the video in card you have and the Nav for the dvd
Old Nov 18, 2004 | 05:50 PM
  #99
Thommino's Avatar
Excume me, I don't speak English very well. Could you better explain this sentence? "my guess is you have the inverter grounded at a different point then the video in card you have and the Nav for the dvd"?
So I would have to buy:
1)P.I.E. MAZ/PC-alp Price - 75.99 USD
2)RCA inputs For MAZ/PC-ALP Price - 14.50 USD
With 1 and 2 I could connect directly connect my Diversiti Switch to Mazda Central Audio Unit (I have 9.55vers)
3)20 amp inline power lead noise filter Price - 11.00 USD
4)Ground Loop Isolator Price - 4.50 USD
With 3 and 4 I encrease Audio quality and for you also Video Quality.
Right?
Total Price:75.99 + 14.5+ 11 + 4.5 = 76+30= 106$ plus shipment to Italy (How much?) About 83Euro + Shipment
This is my problems:
Video 1 (Power-on Xbox): http://www.thommino.com/Video/Rx-8/B...one%20Xbox.MPG
A little Video noise, on black colour
Video 2 (Menu Xbox): http://www.thommino.com/Video/Rx-8/B...enu%20Xbox.MPG
I cannot read nothing. Resolution is very badly
Video 3 (Game 1 Xbox): http://www.thommino.com/Video/Rx-8/B...n/Game%201.MPG
Converter Lightness Problem. I hope www.converters.tv solves this problem.
Video 4 (Game 2 Xbox): http://www.thommino.com/Video/Rx-8/B...n/Game%202.MPG
Video 5 (Film Divx on Xbox):http://www.thommino.com/Video/Rx-8/B...ilm%20Divx.MPG
Video 6 (Film DVD on Xbox): http://www.thommino.com/Video/Rx-8/B...Film%20DVD.MPG
Video 7 (Film DVD 2 su Xbox):http://www.thommino.com/Video/Rx-8/B...%20DVD%202.MPG
Old Nov 18, 2004 | 06:00 PM
  #100
aruffell's Avatar
I'll explain the sentence "my guess is you have the inverter grounded at a different point then the video in card you have and the Nav for the dvd" in italian....
Italian: Essenzialmente dice che hai probabilmente collegato tutte le masse in punti diversi percui hai creato dei "ritorni di massa" chiamati "ground loop". Se colleghi tutte le masse allo stesso punto non dovrebbe accadere. Il "Ground loop isolator" dovrebbe risolvere il tuo problema e potenzialmente migliorare l'audio (elimanando ronzii) ed il video (riducendo le linee).
BTW - I could not view all the links he posted until I pressed QUOTE... now they show up in his post... weird...
