DIY: Oil Catch Can Install (basic)
Old Mar 9, 2009 | 02:32 PM
  #76
RK's Avatar
RK
It's Not Easy Being Green
Originally Posted by Vyndictive
Well, if you let your catchcan get filled to the point where its running back to your intake, you really deserve getting oil all over the place...
Says the guy with the dirtiest SSV ever recorded...
I guess you could argue that it is a good thing to run it back on the chance that your catch can gets overfilled and runs it back to your intake, but I would rather see the can run to the bottom of the engine bay and dump onto the road (although very illegal, it is unlikely that it would ever happen like that.)
Ideal setup is to have the overflow piping routed past the SSV in the auxiliary teet. That gives you overflow protection, gives you vacuum to facilitate venting, and keeps the moving parts on your intake from getting gunked up by oil.
Everything else is a compromise. I've got my can routed back to the throttle body because that's what I had piping for. You have no exit because your didn't come with one. Some people don't have cans at all.
Old Mar 19, 2009 | 12:34 PM
  #77
oosik's Avatar
Originally Posted by JantzenRX-8
milky dipstick TSB re-routing done which i mapped out in yellow.
If I understand that TSB, they are still routing from the the "new" oil filler tube back to the port on the 'accordian' intake, just at a lower part of the oil filler tube, thereby still introducing oil back into the system.....which doesn't alleviate that gunked up SSV. Which is something I'm currently fighting at the moment. i'm trying to hash it out with my service center to have Mazda pay their techs to "properly" clean the intake manifold and I'll pay them to clean from the the extension out to the air filter....or try and do that part myself. My car is well out of warranty, but I know mazda is well aware of this issue and I've had a SSV CEL 3+ times over the past 3 years. 2 of those times were 2 months apart!
Old Mar 19, 2009 | 06:19 PM
  #78
Mazurfer's Avatar
Surf Hard, Drive Hard
Who's been filling your oil?
Old Mar 22, 2009 | 11:31 PM
  #79
Kane's Avatar
Do you happen to have a pic of this? I'm curious.
Happened to be pulling one off a car.... and remembered you.
Attached Thumbnails DIY: Oil Catch Can Install (basic)-oil-line-07.jpg   DIY: Oil Catch Can Install (basic)-oil-line2.jpg
Old Apr 15, 2009 | 03:31 PM
  #80
04-Rx8's Avatar
Instead of capping the intake, Can u put a breather on it. And have one on the catch can as well?
Old Apr 15, 2009 | 03:36 PM
  #81
cjkim's Avatar
^noob
no on the intake
yes on the catch can
Old May 15, 2009 | 07:44 PM
  #82
Proxi's Avatar
duct tape works wonders
Oh my. I recently purchased an oil catch can for my '06 RX8. After reading through this thread it mentions that a 2006 RX8 may not necessarily need an oil catch can. Please say it ain't so! Can I actually still use it?
Old May 15, 2009 | 07:47 PM
  #83
cjkim's Avatar
^noob
yes you can use it
i've heard the "fix" that mazda made was worthless
Old May 17, 2009 | 03:45 AM
  #84
Proxi's Avatar
Originally Posted by cjkim
yes you can use it
Thanks for the info.
But before I install mine, I have a few questions though. Since I have a 2006 model and have the TSB re-route setup on my engine already:
- So once I connect the hose from the front oil filler nipple to the catch can, what is the best way to seal/cap the two small nipples on the intake manifold/maintenance ports that is originally connected to that front oil filler?
- Also just to make sure, if I'm planning to put a breather on the catch can - I will have to seal/cap one of the fittings on the intake tube AND also the "back" oil filler nipple (as per Kane's post regarding where the "separate line went from the intake accordion tube to the 'depths of your engine bay'.")
Sorry for the noob questions.
Old May 17, 2009 | 04:13 AM
  #85
cjkim's Avatar
^noob
I have an 04 without the TSB, so I'm sure someone who's done it before can help you
-the two nipples can just be capped with any ordinary vac cap at your local auto parts store.
-back oil filler nipple? not sure what this is referring to since mines an 04, but if Kane is saying to cap it, I'd believe him. yes, cap the intake.
Old May 18, 2009 | 08:16 PM
  #86
Proxi's Avatar
Okay. Finally installed the catch can on my '06 RX8. Since my car already had the TSB re-route, I capped the two small inlets at the maintenance ports which was originally connected to the front oil filler. I also capped one of the inlets of the intake tube and also capped the back oil filler (which was connected to the inlet of the intake tube I capped).
Hopefully this installation is correct. Kindly take a gander at the pics and please let me know if all is good on this install. Thanks.
Attached Thumbnails DIY: Oil Catch Can Install (basic)-catch1.jpg   DIY: Oil Catch Can Install (basic)-catch2.jpg   DIY: Oil Catch Can Install (basic)-catch3.jpg   DIY: Oil Catch Can Install (basic)-catch4.jpg   DIY: Oil Catch Can Install (basic)-catch5.jpg
Old May 28, 2009 | 01:20 PM
  #87
Mazurfer's Avatar
Looks okay to me.
Old Jun 18, 2009 | 12:02 PM
  #88
klepto's Avatar
Great DIY bro.
I have a question though. I have an 08. I attempted to install my catch can last year but when I did I got really bad idoling. Everything was capped and installed as you described. My question is if there are perhaps differant ways to set it up the catch can by year of the 8?
Because if I am not mistaken isnt the entire maf map totally differant from an 08 to lets say perhaps an ealier verision of the rx8? I'm asking because I was/just kinda sort of sold my catch can and would actually like to install a catch can for just in case precautions that it is meant for.
Old Jun 18, 2009 | 09:49 PM
  #89
Mazurfer's Avatar
Not sure, I'll look it up. I didn't think there were any changes in this area until 09, then there is a slight difference. Well..........when you are ready for one, I have a powder coated Greddy on just sitting in a box in my garage all packed up!
See this link.......... https://www.rx8club.com/rx-8-parts-sale-wanted-44/f-s-various-stuff-163778/
Old Jun 20, 2009 | 12:25 AM
  #90
EmperorBen's Avatar
is it normal to see the oil light go on and smell oil??? cause that's what I'm seeing lol's.
Old Jun 20, 2009 | 09:23 AM
  #91
Vyndictive's Avatar
"13B vs. Renesis" Discuss
No, that isn't normal. Double check your oil levels first.
Old Jun 21, 2009 | 08:36 PM
  #92
Mazurfer's Avatar
Old Jul 17, 2009 | 11:02 PM
  #93
lepichichi's Avatar
I LuV mY Rotary....
i had mines installed about 14 months ago and never had any issues here is my set up!
DIY: Oil Catch Can Install (basic)-imag0008.jpgDIY: Oil Catch Can Install (basic)-imag0009.jpgDIY: Oil Catch Can Install (basic)-imag0010.jpg
DIY: Oil Catch Can Install (basic)-imag0011.jpg
Old Jul 17, 2009 | 11:09 PM
  #94
rodjonathan's Avatar
silent assasin
great diy im gnna do this soon
Old Jul 18, 2009 | 12:49 AM
  #95
cjkim's Avatar
^noob
Attachment 142413Attachment 142414Attachment 142415
Attachment 142416
did revi change their design or did you change out the accordian?
Old Jul 18, 2009 | 11:50 AM
  #96
lepichichi's Avatar
I LuV mY Rotary....
^^ i changed the accordian
Old Jul 26, 2009 | 01:30 PM
  #97
stanknasty56's Avatar
8lover
very nice diy, going to do this when i get back to the states
Old Aug 17, 2009 | 01:14 PM
  #98
Leejin's Avatar
Question
So, what is the Benefit of just putting a breather on the oil catch can? Isn't it SUPPOSED to go back into the intake? I recently found a ton of oil in the ribs of my accordian and freaked out.
I plan to do this mod, but just wondering about the adverse effects of not routing back to the intake.
Thanks guys!
Old Aug 17, 2009 | 01:41 PM
  #99
Vyndictive's Avatar
Thanks guys!
I would say there are no adverse affects to not running the hose back to your intake.
Oil shouldn't ever be in the intake, end of story.
The breather is just there to make sure no debris gets into the catch can where it could (theoretically) make its way back into the engine. The filler neck isn't under vacuum or anything, but I wouldn't cap the catch can just because any air will have no place to go.
Old Aug 18, 2009 | 04:30 PM
  #100
Mazurfer's Avatar
Yeah, you've had blow back into the intake and that's exactly what you want to avoid. It will get into the throttle body and could/will gum it all up in due time.
Now......if you route the hose back.........theoretically you could have oil fumes returning and therefore have a little bit of oily residue, so that's why some people just don't even return it to the intake, but put the breather on it. I guess Vyndictive makes a valid point as well concerning not just capping the catch can.
