AT to MT swap
Old Aug 14, 2009 | 12:24 AM
  #76
RotaryResurrection's Avatar
kevin@rotaryresurrection
While it would be *possible* to use the AT fluid cooler as an MT oil cooler, it would require a lot of custom plumbing that most people would find hard to pull off...so it is simpler to just find the factory plumbing and the cooler with it.
As stated in the first post, third item on the list of required parts, the manual starter is necessary. The auto starter is totally and entirely different.
Old Aug 16, 2009 | 07:47 PM
  #77
bkkkk93's Avatar
alright i have a 2006 at shinka and i was looking into this and i already have the 6 port so what would i have to do to swich over to a mt?
Old Aug 16, 2009 | 09:10 PM
  #78
I give up.
Old Aug 17, 2009 | 01:42 PM
  #79
G-Gray dude's Avatar
Boost Virgin Gonnabe
did you read the first 3 pages?
Old Aug 17, 2009 | 07:37 PM
  #80
bhop's Avatar
NO A/C :(
Long post RR and I forgot who said if it would be cheaper to just buy a used MT RX8. I don't think so because for $2000-$3000, that probably is not a bad price. I was thinking about doing it myself but then reading your post, I officially changed my mind and said "screw that ****"! So have you been on a dyno yet, lol. Gonna go FI, or are you just leaving it as is?
Old Aug 17, 2009 | 10:36 PM
  #81
It now has about 1 year and 6k miles of NA driving...compared to other rx8s I've driven it makes standard power for a 6MT. No plans for significant mods to the renesis...however long term I'd like to do a 13brew swap and stop playing games with NA rotaries.
Old Aug 17, 2009 | 10:41 PM
  #82
rodjonathan's Avatar
silent assasin
Originally Posted by RotaryResurrection
I give up.
lol really interesting thread and omg some ppl ...
Old Aug 18, 2009 | 07:55 PM
  #83
bhop's Avatar
NO A/C :(
Yeah, I cannot believe the guy who asked did not read all that ****
Old Aug 19, 2009 | 11:54 AM
  #84
bkkkk93's Avatar
cost
so how much overall did it cost you?
Old Aug 19, 2009 | 12:27 PM
  #85
I'm not trying to be mean here, but can we possibly ban bkkkk93 from making further posts in this thread?
Old Aug 19, 2009 | 12:38 PM
  #86
Originally Posted by rotaryresurrection
i tried to go over that in the writeup. Now of course i am a professional rotary engine builder who has worked on rx7s since 1999 full time, so it's a little different than a regular joe working in his back yard. Also with that said, i do not work in a big shop full of lifts and pits and such, i work with cherry pickers and jackstands in my garage, like like everybody else.
As for cost, i got all of the parts necessary for the swap for around $2500-2800. The engine could have been run as-is, but i of course chose to go through it being that i am a builder and i never trust used engines in my own cars. As such i will not really include rebuild/refresh time and cost.
If someone were to bring all the parts to me and ask me to do the work for them (the swap alone, not a rebuild) then i would charge them around a grand to do it. Most other rotary shops tend to charge more than that for swaps on rx7s, and would probably charge even more for an rx8 given the new-ness and the fact that they had probably not done the swap before either.
So in theory, if you do it yourself it can be done for under 3 grand, and in about 20 hours at most. The only difficult parts are pulling and reinstalling the engine/trans as a unit out the top, the car is not really made to do it this way (mazda wants you to drop the whole subframe/engine/trans out the bottom, which requires a lift) and also the pcm reprogramming. However if you get more/all of the electronic **** from the donor car (keys, cylinder, immobilizer module, abs module, etc.) then it is possible that this issue could be bypassed and it could become closer to a plug and play.
The next time i have an opportunity, i will try to do it that way and see if it works out any better.
Originally Posted by 3cjf897
sry i got a noobie question, how much did the whole process cost u? And estimate how much would it cost for the shop to do everything?
fial
Old Aug 19, 2009 | 12:58 PM
  #87
rev8's Avatar
so it's a V twin?
very good info. does the car feel oem or do you have any problems as a daily driver.
Old Aug 19, 2009 | 01:18 PM
  #88
Old Sep 4, 2009 | 12:55 PM
  #89
Darkpoison187's Avatar
I'll cut ya bitch!!
Great thread you have here.....quick question so all i need is a tranny swap how much did this cost you in the end.... cuz four pages is way too much to read ppl are lazy On a serious note overall not a bad amount to spend on a swap wish I could do it on my own
Old Oct 6, 2009 | 11:15 AM
  #90
T-Mar's Avatar
TX
i was tring to swap my engine for a long time to manual, but decided got to be happy with what you got and im just looking for upgrades.
Old Oct 13, 2009 | 01:06 PM
  #91
Veil_Side's Avatar
RPM issue
on an auto at the speed of 100KM/H the RPM used to be at 2000.
now after change to manual transmission, the RPM is at 3000 for 100KM/H.
Is this normal ? do you hv such issue ?
https://www.rx8club.com/series-i-trouble-shooting-95/rpm-increase-aft-change-manual-transmission-184455/
Old Oct 13, 2009 | 11:58 PM
  #92
Of course the rpm will be different...you now have 6 gears instead of 4, and the ratios are all different.
Old Oct 14, 2009 | 03:08 AM
  #93
Veil_Side's Avatar
it's from 6AT to 6MT.
more details of the car here - https://www.rx8club.com/showthread.php?t=184455
Old Oct 14, 2009 | 10:11 AM
  #94
THE GEAR RATIOS ARE DIFFERENT BETWEEN AUTO AND MANUAL
http://www.mazdausa.com/MusaWeb/disp...ode=RX8&bhcp=1
Gear Ratios (:1)
------6MT 6AT
1st 3.82 3.54
2nd 2.26 2.06
3rd 1.54 1.40
4th 1.18 1.00
5th 1.00 0.71
6th 0.79 0.58
Old Oct 14, 2009 | 12:48 PM
  #95
secret8gent's Avatar
the enemy in the mirror
you're very nice to spell it out for him.
also did he change the rear end?
Old Oct 14, 2009 | 01:07 PM
  #96
Doesn't matter. The speed and rpm will be different because the ratios IN THE TRANSMISSION are different.
Of course changing the rearend (if his AT has the 4.3 instead of the 4.44) will also change the speed/rpm.
But he is trying to compare the way the car is now, to the way it was before...most of the difference is in the transmission gearing. Just look at the difference in overdrive (6th) gearing. The AT has about 25% more overdrive than the MT so of course the rpm/speed will be a lot different.
Old Oct 14, 2009 | 10:10 PM
  #97
Veil_Side's Avatar
Gear Ratios (:1)
------6MT 6AT
1st 3.82 3.54
2nd 2.26 2.06
3rd 1.54 1.40
4th 1.18 1.00
5th 1.00 0.71
6th 0.79 0.58
thanks for the info.
Old Oct 28, 2009 | 01:06 PM
  #98
BReal-10EC's Avatar
My car was an early build 04 AT with 117,800 on the original engine and a reman trans. I bought it for dirty cheap with the intention to convert it and mod it at some point. I drove it for over a year as an AT to learn how the car responds and drives, while gathering parts and information for the swap.
Wow Kevin- I was wondering what year RX8 you bought. But I had no idea you bought an auto RX8 and converted it. Though I should have assumed you got it dirt cheap.
(I had been avoiding this site for some time now because it seemed to just point out more and more possible flaws with my car... but whatever. Voluntary ignorance is not smart. And that's why I just now read this thread.)
Wow- converted it. That's quite an ambitious task on any newer vehicle. Though it sounds like you swapped out everything needed to make the auto a full US 6 speed model. Have you considered auto-crossing it? The ETR SCCA uses the safety test area across from Walters State (other side of 25E) several times during the year. The RX8 is amazingly capable in stock form on a tight auto-x course.
I'm curious- did you consider swapping a 5 speed RX7 transmission onto the four port Renesis? IIRC- Mazda actually sells or sold the RX8 in four port Renesis form in other countries with a 5 speed manual, and they had suprisingly decent real world performance and fuel economy.
FWIW- I think Strange has a complete wrecked RX8 right now. Not sure if it's auto or 6 speed though.
Good luck selling conversion packages.
Old Oct 28, 2009 | 11:42 PM
  #99
10 grand 2.5 years ago, at the time they were still bringing 13-16 grand all day long.
BTW I have seen you around town in yours. It looks almost as small with you in it as your 1st gen did.
Thats the main reason I bought the car to begin with, to learn to work on the car and learn their tendencies, strong and weak points, etc. to utilize in my business in the future.
It kinda fell in my lap. I would never have gone out and purposely bought one. I liked them okay, they were interesting, but not awesome or anything. After owning, driving, and working on it, I like it a lot, but it's still not all that and a bag of chips IMO.
If you were to look at it right now...inside, under the hood, underneath the car...you would never be able to determine that it used to be an auto. Everything works. In fact I went from automatic touring (I guess?) to basically a manual GT. I added the rear wing, front lip, sideskirts and rear aeros. I changed the interior from base cloth to power/heated leather, and made the seats work like stock.
The only part that was remotely difficult was the electronic programming part...transponder key programming, pcm programming, and the abs/tcs issue. Everything else was easier than swapping an FC or FD (except for the engine swap).
Behind walmart? I have never even went back there...
No, its a totally different 5MT trans. The rx7 trans comes nowhere near mounting up or the shifter lining up properly without major modification.
I am pondering on an REW swap with an FD 5sp trans and probably a small/conservative single (twins are garbage most of the time) for the future. I am not happy with the gearing of this car, nor with the stoutness (or lack thereof) of the transmission. I can make more power and more torque while getting better MPG and having a stronger drivetrain for well under 4 grand, and I should be able to keep almost everything functional except for perhaps cruise control.
Strange is sometimes hard to deal with. They want to sell to insurance and bodyshops more than anything. They want real money for everything they have. They won't let you pull anything yourself or even look at the car most of the time. They just want to look up something in the computer and make you hold 10 minutes while they make up a (high) price, and you either want it (in which case they will pull it one day this coming week) or not.
As indicated earlier in this thread I have no intention of selling packages. I would offer the conversion service if someone provided their own parts.
Old Nov 2, 2009 | 05:52 PM
  #100
BReal-10EC's Avatar
Appearances can be deceiving. The non sunroof RX8 is actually quite accommodating for a tall driver, for this class of vehicle.
The chassis is a great handling chassis (rivaling cars costing twice and more at this ride/handling balance). But that's the car's strong point. Everything else seems to be a weak point (if you believe everything you read on the internet).
I'm surprised you didn't drop a sbc in there. But that might hurt your image here.
I didn't realize you were that adept with modern engine stuff. Wait- is the FD OBDII or I?
The light at the top entrance to Wally World- stay on College Park Road instead of turning into Wally World. There's a large oval paved area back there used for police driver trainer (check google maps).
And I kicked myself several times in the nuts for not trying SCCA auto-x before this year (I had to dislocate my knee- but it was worth it). Honestly- it's mainly great down to earth car people. Even the PCA (Porsche Club Association) event sponsored (open) auto-x I went to at Pellissippi State was full of (surprisingly) down to earth car people. And I honestly think running your AT to MT swap RX8 at some event (SCCA or other) will eventually return some RX8 business. You are a straight up down to earth guy, and that's refreshing (and very unusual) for somebody in your line of specialty work (at a fair price). And the RX8 is a very popular club sport car, which will probably grow as these get cheaper used.
See what I did there- I just turned a fun time into a work related event. That's called spin... for a justifiable reason for doing this.. for your wife.
And beyond that- it's just dang fun. Where else can you push a car in corners at 11/10ths legally? As they say- if you don't spin at least once, then you ain't driving hard enough.
Gotcha. I know that sounds like a nubee mistake, but when I first come across a 3+ page thread, I tend to skim.
And what about that sbc conversion?
j/k.... j/k.
