upgrade injectors with greddy turbo
Old May 9, 2009 | 09:54 PM
  #51
05rex8's Avatar
sold the 8... :(
My modified injectors from KG Parts are being shipped back. It was only 1 day turnaround time. The results of the modification was better than expected. I was looking to get 720cc, but after modification and cleaning they are rated at 820cc. Not bad for $50. Attached is the pdf file that shows the injector flow.
File Type: pdf
Old May 22, 2009 | 12:02 AM
  #52
gregs's Avatar
Pull My Finger
will the AT blue injectors do the job to break 300 whp? i can probable get these for a killer price anybody know the part number for the injectors?
Old May 22, 2009 | 12:11 AM
  #53
Brettus's Avatar
Boosted Kiwi
Yep - they sure will , with room to spare . I'm at around 320+ now and still have room to move ...
Old May 22, 2009 | 12:46 PM
  #54
PhantomRX-8's Avatar
Bad Ass
I got mine on eBay for $100. Some people that part cars out are catching on that the blue injectors are being used in 6speed turbo applications so the prices are on the rise. There was a couple on there the other day, think they were $120.
Old May 22, 2009 | 01:29 PM
  #55
gregs's Avatar
Pull My Finger
since i work at mazda i want to see what my cost is...thats why i was looking for the part number
Old Oct 29, 2009 | 09:27 AM
  #56
JMKuco's Avatar
Rotary engine addict
so you just replace the P2 injectors with the blue ones ?
need a PCM recal ?
why not changing all the 6 with more powerfull injectors ?
Old Oct 29, 2009 | 09:35 AM
  #57
carbonRX8's Avatar
U-Stink-But-I-♥-U
Unless you are boosted, you dont need larger injectors.
As for the primaries, they are used for idle and cruise. So why add bigger injectors just to idle? The secondaries and P2s are used in boost. P1s are not, iirc.
Old Oct 29, 2009 | 10:18 AM
  #58
Mr.&Mrs.Magic's Avatar
You'll also complicate tunning for no good reason. From what I understand you don't need anything bigger unless you plan on going above 300 whp so why complicate things when a set of blues will be more than sufficient
Old Oct 29, 2009 | 10:24 AM
  #59
Red Devil's Avatar
If you guys are referring to flash tuning, than be aware that the latency is different for the blues yet there is only one data entry point for latency aside from the primaries on the 6 port engine. You want to have the same latency for all four injectors in this bank.
Old Oct 29, 2009 | 02:08 PM
  #60
Brettus's Avatar
Boosted Kiwi
/\ please elaborate . I've been running the blues for a year now without issue .
What diference in latency is there between the yellows and the blues ?
Old Oct 29, 2009 | 02:41 PM
  #61
MazdaManiac's Avatar
The "blues" have about .7ms lag (at nominal BARO and voltage) compared to the "yellows".
Old Oct 29, 2009 | 02:46 PM
  #62
Brettus's Avatar
Boosted Kiwi
/\ got any idea what kind of issues you might see with this ?
Old Oct 29, 2009 | 02:57 PM
  #63
Relatively unstable fuel delivery with output values lagging behind commanded values anywhere from 1% - 5% in a fairly unpredictable fashion.
For most people, it will simply be a tuning variation that will be exacerbated by BARO and battery condition.
If you are only shooting for a 1/2 point of AFR here and there, it probably wont be a problem, but it will make you wonder why your tune "wanders"
Old Oct 30, 2009 | 08:29 AM
  #64
fail.
i made it almost a month!
Old Oct 30, 2009 | 09:19 AM
  #65
JMKuco's Avatar
ok, so if I want...adding like a 650cc...wich ones should I change : the P1? P2 ? or auxilary
in fact I have 330whp.... and I want more...so if I have to change all 6, I do not care !
Old Oct 30, 2009 | 10:39 AM
  #66
Brettus's Avatar
Boosted Kiwi
Originally Posted by swoope
fail.
Old Oct 30, 2009 | 10:42 AM
  #67
Brettus's Avatar
Boosted Kiwi
There is a thread around here where someone just modified their yellows and got 800cc - o5rex8 I think . Put those in the P2 position and you should be sweet .
Also : where is your dyno ?
Old Oct 30, 2009 | 10:53 AM
  #68
gregs's Avatar
Pull My Finger
^^i just purchased those fuel injectors from 05rex8 hopefully i will be installing them at the beggining of the year
Old Oct 30, 2009 | 10:58 AM
  #69
Brettus's Avatar
Boosted Kiwi
/\ how come he did not use them ?
Old Nov 2, 2009 | 03:03 PM
  #70
baysj's Avatar
has anyone actually used the injectors from KG Parts? I need to get some upgraded injectors and really don't want to have to tear off the upper intake more then 1 more time. Does anyone have a suggestion of where to get them now that MM has stopped shipping them?
Old Nov 2, 2009 | 03:10 PM
  #71
Its not that I'm not shipping them, but I have a looooooong list of purchasers who never returned their cores.
So, I've run out until those people start sending back their old injectors.
Old Nov 3, 2009 | 03:02 AM
  #72
JMKuco's Avatar
ebay ?
where can I found the blue injectors, I'll first replace my auxiliary's with those ones.
Old Nov 3, 2009 | 03:05 AM
  #73
RWagz's Avatar
Piston-free 07.11.2007
Send my AP out and mine are all yours.
Old Nov 3, 2009 | 07:40 AM
  #74
baysj's Avatar
MM I have mine out of the car already, if i send them to you can you send them back with the accesport?
Old Nov 3, 2009 | 10:22 AM
  #75
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
MM,
I sent you back my old fuel injectors back in July and still have not received my core charge refund! I even sent you a tracking number.....
Please check your emails!
