Post your AP "dyno" results
Old Mar 6, 2009 | 11:18 PM
  #51
MotoGeno's Avatar
Originally Posted by elysium19
that's for the automatic (4 gears, different ratios)
Ahhhhhhh, thanks!
Old Mar 12, 2009 | 02:27 AM
  #52
ferrocene's Avatar
ohio gozaimas!
Easy E seems to have upped his redline from the default 7.5k. 50mph in first gear? That's crazy!
Do you have an extra tranny cooler?
Old Apr 3, 2009 | 06:21 PM
  #53
Nemesis8's Avatar
Bigus Rotus
500+ ftlbs!
LOL - NA '04 with weak compression...
252.08 HP @ 2586 RPM
511.97 FTLBS @ 2586 RPM
Old Apr 4, 2009 | 12:50 AM
  #54
ramos1556's Avatar
ROTORHEAD
199.5-HP
172.0-TQ
2000 - 7000k 3rd gear.
I am sure with the mods that i have done and running a 9.1 @ 72 mph at the 1/8 mile, these numbers are really close if not low (just a little)! well maybe not the Torque!!!
Old Apr 22, 2009 | 02:00 AM
  #55
neit_jnf's Avatar
diesel powa! lol
Old Apr 22, 2009 | 09:17 PM
  #56
Nemesis8's Avatar
Bigus Rotus
Originally Posted by neit_jnf
diesel powa! lol
LOL - now that I think about it, the HP feels about right - weird.
My compression is improving.
Old Apr 23, 2009 | 10:47 AM
  #57
elysium19's Avatar
Really what you need to do is do a run with your properly tuned map, then either uninstall the AP or choose "stock style map" and then run again.
I'm sure the results will be more accurate for CHANGES in power rather than absolute power #'s. And more interesting too....
I will do this in the next few days....
Old Apr 23, 2009 | 10:57 AM
  #58
Amaris8's Avatar
[I know the AP dyno feature will never be completely accurate, but just for funsies lets post our results. I did 3 pulls and wrote down the one that "could be" accurate.
Old Apr 26, 2009 | 01:20 AM
  #59
Saphus's Avatar
253 & 183 ....
gonna try it again tomorrow, for the first night using my ap, getting jeff his required datalogs and so fourth, I thought it was a pretty cool feature
didn't really care for the 2.86 60' time on the 1/4 mile time feature though...
Old May 9, 2009 | 04:20 PM
  #60
ijt-rx8's Avatar
stock dyno done yesterday 5/8/09 1st pull 3rd gear 179.75hp 127.42tq thats after correction pre-correction was 183hp ... also did pull in 4th and got 135 ft lbs of torque. run conditions were 76 degrees and 31% humidity
Old May 9, 2009 | 07:22 PM
  #61
elysium19's Avatar
I tried doing a back to back test on my way home from school, but the AP won't recognize that i'm in gear unless I use 3rd gear, even though it lets me select 3rd. I don't know if this has been fixed with the most recent flash, anyone else have this problem?
I'll try again, but I'll have to go out of my way to make sure I can max out 3rd gear safely.
Old May 9, 2009 | 07:45 PM
  #62
kersh4w's Avatar
Hit & Run Magnet
hmm, this sucks.
has cobb decided to support vista 64 bit yet?
if not, im fuxxed. or mac os x.
Old May 9, 2009 | 10:56 PM
  #63
kersh4w's Avatar
Hit & Run Magnet
yea, so this is still screwed up on vista 64 bit. wtf cobb, please fix this?
so i went to a friends house and updated this. at first i was like, "man this is cool, im loving the update!"
then i try to check my horsepower and the accessport keeps turning off when i hit bumps.
finally i make it, i do 2000-9000rpm. i enter 3169. 3029+140. and im off.
301hp@8750hp.
when did someone install a turbo into my car without me noticing the increase in power?
Old May 13, 2009 | 03:26 PM
  #64
kersh4w's Avatar
Hit & Run Magnet
would tire size affect the numbers? by affecting the overall distance the car traveled?
Old May 14, 2009 | 09:54 AM
  #65
rotary.enthusiast's Avatar
The Local Idiot
Yes. The "dyno" numbers are going to be based on vehicle speed, which is not accurate if you have different sized tires.
Old May 30, 2009 | 09:33 PM
  #66
myriadshalaks's Avatar
rot8ing
here's some dynos
there's 1 stock,
1 with cobb stage1,
and 3 with kanes tune.
i'll post another cobb stage1 in the next post. only lets me do 5.
looks like pretty good data to me.
Attached Thumbnails Post your AP "dyno" results-stock-ap-dyno.jpg   Post your AP "dyno" results-1-cobb-stage-1.jpg   Post your AP "dyno" results-1-tuned-dyno.jpg   Post your AP "dyno" results-tuned-dyno-3.jpg   Post your AP "dyno" results-2-tuned-dyno.jpg
Old May 30, 2009 | 09:36 PM
  #67
rot8ing
another cobb stage1
Old May 31, 2009 | 01:29 AM
  #68
Kane's Avatar
214-222.... hmm; would be nice - but probably a bit on the high side.... the change from the old though is nice.
Old May 31, 2009 | 02:19 AM
  #69
rot8ing
shh shh.
Old Sep 22, 2009 | 05:11 AM
  #70
Easy_E1's Avatar
So I finally got around to doing this. Little run down on the car.
2005 4 Port AT
SR midpipe (catless)
Mazdaspeed V2 catback
AccessPort, Mazdamaniac tune, redline 9000.
BHR Ignition kit. Dwell adjusted.
AEM CAI
ZEX Nitrous, 75 shot
Weight 3100
2nd gear pull
5000 rpm to 9000 rpm.
231 HP 7154 rpm
210 Torque 5355 rpm
Old Sep 22, 2009 | 07:11 AM
  #71
DarthRX8's Avatar
Force User
Nice, thats a fast azz 4port AT!!!
Below is my best. The pull was from 3000 to 8300 rpms in third gear:
Oh and this is without my final tune from Jeffe....
Old Sep 22, 2009 | 01:07 PM
  #72
Easy_E1's Avatar
Wow Peak torque at 7000 rpm. That's a first. Numbers look good for the mods DarthRX8.
I really don't know how accurate this actually is. But mine is a little higher than I expected. About 10 HP. So just to see how accurate this really is. I'll be doing a Dyno on Sunday after SSXII. So I can compare the numbers.
Old Sep 22, 2009 | 03:20 PM
  #73
DarthRX8's Avatar
Force User
Yeah, I know that these numbers mean nothing. The one thing that I do like however is that everytime I have added a mod my numbers have gone up.
The first one I took was 205hp/ 147tq @ 5800 (Aem intake, AP (about 4 away from my final tune))
Added the BHR ignition and another tune from Jeff - 211hp/ 158tq @ 6910
Added the RB exhaust and another tune from Jeff - 217hp/ 162tq @7018
Hopefully when I get one of your BHR midpipes and upload my final tune from Jeff (in my inbox but can't install until I get home), I will see another jump.
Old Mar 18, 2012 | 04:55 PM
  #74
Mattyberryman2010's Avatar
Help needed please ........... Starting problems on my rx8 231 2004 with 50,000 miles on
I went to start it this morning and it wudnt start after several times so I put sum revs on and it just back fired , since then I have been told it could be flooded so I disconnected the fuel pump under the back seat and reconned it several times but had no luck , can any one help me please ?
gwailo
May 14, 2024 06:57 AM
