AT to MT swap
Old Jul 26, 2008 | 02:08 AM
  #51
Originally Posted by RotaryResurrection
****, I wish mine had a 4.10 in it like the rx7s run. I mainly use mine for cruising and I see no reason for it to be turning 3500-4000 at interstate speed. The 3000-3300 that rx7s turn at similar speeds is bad enough for gas mileage.
so on a note.
as you a person of do....
if you were charging 50 bucks an hour to do this, how much would it cost, note. 50 bucks an hour would never happen, but.
this is not a diy, unless you have a shop. !!!
but good for you.. give us a total when you have it dialed in.
Old Jul 26, 2008 | 02:23 AM
  #52
RotaryResurrection's Avatar
kevin@rotaryresurrection
As I mentioned earlier, I would do this job (no rebuild, just a straight used engine drop in with the swap) for a grand in labor. I don't usually do hourly labor, I quote by the job ahead of time whenever possible. Usually my labor works out between 25 and 50 per hour, but due to the intermittent nature of my work schedule, I don't like to do hourly, I like to do flat rate for a job, plus any materials or extra options/modifications.
Again this would obviously not include any PCM programming etc. which would have to be done at a dealer with a WDS/MDS.
Old Jul 26, 2008 | 03:34 AM
  #53
rx8phase1's Avatar
man i so would have paid you to do this if u lived in socal
Old Jul 26, 2008 | 10:13 AM
  #54
mdw1000's Avatar
I'll snap his neck.
I guess that's the one nice thing about the tall gearing in the 4AT. Even with the 4.77, at highway speed I'm still at only about 3000 rpm at around 70mph. Of course I find it hard to keep it that slow
Old Jul 28, 2008 | 03:00 PM
  #55
UPDATE:
I managed to track down the ABS module from the same car that the PCM came from. I switched ONLY the black electrical half of that module, onto the existing ABS unit in my car, leaving all the hydraulic line conections untouched. I was able to do this in the car without removing anything except the harness plugs and engine cover. Once I installed the new electronic control unit onto the ABS module, the ABS and TCS lights went off, and the ABS does function properly in my car now (I stabbed the brakes at 30mph to verify). The DSC button also responds normally now and the TCS light is no longer lit, so I assume those functions work properly as well (since they apparently route through the ABS module).
So as of now I have a 100% functional AT to MT swap with cruise, ABS, TCS/DSC, AC, PS, etc. and no CEL or codes. THe only loose end for me to tie up is the trim ring that holds the shift boot in place to the underside of the console trim, which is on order.
I have updated the original post accordingly to prevent confusion among those who might not read the entire thread.
Old Jul 28, 2008 | 06:20 PM
  #56
UPDATE:
good job..
damn trim ring!!
Old Jul 28, 2008 | 08:08 PM
  #57
laulongfei's Avatar
laulongfei
Hey, Rotary Resurrection:
Do you think its possible to use the old AT engine with just MT tranny and clutch with some computer tuning with Cobb access device. Because you knoe its quite expensive buying a MT engine.
Old Jul 28, 2008 | 08:40 PM
  #58
IT would be possible, but you would most likely always have a hard CEL and codes for the lack of auto transmission inputs to the original AT PCM. IT might be something Jeff can take out of the PCM code list, but the dealer said there was definitely no way he could get rid of it, for what it's worth.
Plus you'd still be down about 30-40hp versus a manual engine...UNLESS you already have the 06+ 6 port automatic.
Old Aug 5, 2008 | 10:24 PM
  #59
p61190's Avatar
Okay, If you swap Do you get the extra 40 hp?
Old Aug 5, 2008 | 10:32 PM
  #60
ShellDude's Avatar
weeeeeeeeee
The extra HP comes from the intake. if you've got a spare 6 port engine, then yes you'd get the Horsepower too.
Old Aug 5, 2008 | 11:29 PM
  #61
IT would be possible to simply put a flywheel-back MT drivetrain behind an existing 04-05 4 port AT engine...in this case you would not generate any more hp, but more hp would make it to the wheels so it would feel like a 15-25hp increase versus the old slushbox.
The 40hp increase would come from a 6 port engine with 6 port intake, and MT PCM programmed for 9000+rpm. In reality, the 4 port and 6 port engines seem to make similar power up to the 7000rpm limit of the 4 port. The additional HP from the 6 port MT comes because it can rev higher and flow more air, and of course the PCM has to be able to control it, so it needs to be swapped too.
So short answer, yes the way I have done the swap, I got the 40hp increase (at the engine) and closer to 60-70 at the wheels (auto's seem to dyno 130 at the wheels and manuals 190-210), so it depends on how you look at it.
This hasn't taken into account the 06+ AT cars that already had the 6 port engine, but had the AT PCM programming and low redline.
Old Aug 7, 2008 | 01:50 AM
  #62
G-Gray dude's Avatar
Boost Virgin Gonnabe
RR, you said 06+ AT car makes it easier to do a conversion?. so you just need a transmission, PCM, and clutcth pack?
Old Aug 7, 2008 | 02:05 AM
  #63
If you already have the 6 port engine, you can reuse that without swapping it. I am not sure, but it should have the same injectors and sensors as the MT 6p.
You'd still need the MT pcm, engine wiring harness (since the transmission control wires are part of the engine harness), starter, flywheel (a lightweight aftermarket flywheel would be a direct bolt on in this case as well), driveshaft, shift stuff, clutch pedals, clutch hydraulics, clutch kit, etc.
Old Sep 21, 2008 | 11:28 AM
  #64
yushinrt's Avatar
hay RotaryResurrection how are you today. just got a question do you think it possible to put 6port motor in to a 4at ? with out changeing the trans ?
Old Sep 21, 2008 | 01:31 PM
  #65
Yes...it would have to be the 06+ AT version of the 6 port though. You could not put a MT version of 6 port in front of an AT, because there would be nowhere to mount the starter.
And you'd also need to find a way to engineer the 6 ports to be open...since the 4 port PCM is not going to be able to operate the additional valves. Even if you get the 6 port PCM with the engine, you probably couldn't use it, because it expects to see a trans with 6 speeds instead of 4, so likely the shifting would be screwed up if you tried that.
Old Oct 3, 2008 | 02:02 AM
  #66
philipchan's Avatar
I have a question...any of you guys know that the 4speed AT in japan is called type-E and the 6 -speed MT is called type -S, and the 4 port engine not only comes with 4 speed auto but a 5 speed MT
is that possible the swap our 4 speed auto to 5 speed MT so that we dont have to change so many stuff,just change the trannie and the computer??
Old Oct 3, 2008 | 11:45 AM
  #67
quote from post above:
You could probably just keep the existing PCM, and you'd have some error lights to deal with. Or you could swap the PCM if you could find the proper one from the MT model.
I wonder...are the 5sp transmissions any stronger or more reliable than the aisin 6 speed units? What are the gear ratios of the 5sp transmission plus rear end final drive ratio?
Old Oct 10, 2008 | 03:28 AM
  #68
philipchan's Avatar
i dont know the 5speed transmission is any stronger than the 6-speed one or not
but i found the gear ratio
1st 3.483
2nd 2.015
3rd 1.391
4th 1.000
5th 0.806
R?? 3.288
final drive 4.300
Old Nov 28, 2008 | 05:37 AM
  #69
3cjf897's Avatar
sry i got a noobie question, how much did the whole process cost u? and estimate how much would it cost for the shop to do everything?
Old Nov 28, 2008 | 12:21 PM
  #70
please read the body of the thread again, this was discussed at least twice already.
Old Apr 22, 2009 | 08:44 AM
  #71
j0eStER's Avatar
wow nice, Congrats
Old Apr 22, 2009 | 09:32 AM
  #72
nice ninja edit, I was about to post a fail pic of facepalmpicard.jpg for you, lol.
Old May 25, 2009 | 12:01 PM
  #73
peytonj's Avatar
Hey man, is there any chance that you would come out with a package for sale for the AT to MT swap? I've been looking all over for all the parts and i can't seem to find everything.
Old May 26, 2009 | 12:06 AM
  #74
multiple and consistent supply of parts cars would be required for such a "kit" and I am not really interested in paying 3-4 grand of my own money up front for a wrecked rx8 from insurance auctions so I can sell MT swap "kits" for what the members here are no doubt willing to pay (2 grand or so max, plus some labor, I'd guess) and then having to try and sell the small parts of the rest of the car off on ebay or elsewhere to make my money back off the car.
Old Aug 13, 2009 | 02:47 PM
  #75
rx8dudebud's Avatar
hey there can you just you the one oil cooler from the auto or is not possible?and do you need the manual starter?
