Auto RnD Suspension and Wheels experts
Stance coilovers in stock!!!!!
Old Sep 2, 2008 | 11:54 PM
  #51
what are the #s on the rear springs?
i have felt the pain you talk about. but for different reasons!
Old Sep 3, 2008 | 07:06 AM
  #52
Mr. Pockets's Avatar
As I said, the rears are 6kg/mm. The fronts are still 10kg/mm.
Old Sep 3, 2008 | 01:07 PM
  #53
Endless Rotaries's Avatar
Awesome update.
Can you tell us what alignment settings you're running Nick?
Rishie
Old Sep 3, 2008 | 01:23 PM
  #54
I have -2deg camber up front, -1.5 in the rear. Toe is 1/8in out on the front, 1/8in in on the rear. Caster is 6deg, I believe.
The toe-in on the rear was especially important with the 7k springs. If I find that the car doesn't rotate as well on concrete as it did on asphalt, I'll try setting the rear to zero toe.
Installing the coilovers and lowering the car allowed me a much greater range of camber adjustment. Honestly, I'm not certain what the front camber was set to before because I asked the shop for 'maximum,' and they didn't give me a print-out. That was the first and only time I went there. After the coilovers, the pre-alignment check said my fronts were set to -2.5. As I said above, I have that dialed back to 2.0 now.
Old Sep 7, 2008 | 12:17 PM
  #55
So, I took the car out of town with the coilovers for the first time this weekend. Since I installed them, the car has only been about 45min. outside of the city, and that was on a smooth freeway.
Honestly, I'd call the coilovers 'annoying' on a rough freeway. My wife, however, would call them 'intolerable.' On smooth, asphalt freeway there's no problem. On concrete freeways, you'll feel every seam. If the freeway is old and heaved at all, your wheels are going to feel square.
Me, I'll live with it. My wife says this is the last time we're taking my car on a long trip. :p
For some people the ride might be compromised too much. I don't put a ton of miles on my car and I'll swap the stock parts back in for winter anyway.
Old Sep 7, 2008 | 03:25 PM
  #56
Daemos's Avatar
so...how would these compare to the KW varient 3s on performance? How do they measure up on shock dynos?
Not to be a kill joy or anything, there are there are other coilover manufactures on the market that advertise tons of features for a lower price set, but in the end they are of lower quality, the shocks vary greatly in force, and they're not even matched right. And in the end even though the car felt more 'planted' due to the stiffer ride, it actually performed worse overall.
Old Sep 7, 2008 | 04:33 PM
  #57
You get what you pay for. The KW v3's are independent bound and rebound.
If you're on a budget but require certain adjustability then the Stance might be your best value but don't expect to get the best of both worlds, as nick stated.
Good for track, street debatable.
Rishie
Old Sep 7, 2008 | 05:48 PM
  #58
shaunv74's Avatar
Power!!
For comparison: With stock springs I can only get 0.9 degrees of camber in the front.
Old Sep 8, 2008 | 07:14 AM
  #59
I've never even seen a shock dyno, so I don't know what these would look like. I've also never tried the KW V3s. I intended to get those, but with the exchange rate they didn't make a lot of sense any more. These were such a good deal I had to try them out and I'm very happy with my decision. I can't imagine with the aforementioned 'lower priced sets' that you'll get anywhere near the support I have from Stance.
These are an awfully good bang for the buck, in my opinion.
Just ask for the longer, softer rear springs. More on that after this weekend.
Old Sep 8, 2008 | 07:15 AM
  #60
The lowering alone gets you that, but the Stance coilovers have the advantage over a fixed spring/damper setup in that they retain travel when adjusted lower.
Old Sep 8, 2008 | 09:15 AM
  #61
imput1234's Avatar
I ♥ Drifting!!!
? My front camber was over -1 with stock spring
Old Sep 16, 2008 | 08:27 AM
  #62
Over the weekend we returned to the first surface I ran the Stance coilovers on. As it did on the asphalt a couple weeks ago, the car felt very neutral and predictable.
At this point it feels like the car has developed well and next season I can focus on learning to drive it quickly while making the smaller changes I'm allowed in ST.
Thanks to Stance for their support and to Rishie for the great deal. Both were a pleasure to work with.
I'm including two pictures of my car. One is of another driver who, on a fun run, ended up in a mad-tight JDM yo drift.
Attached Thumbnails Stance coilovers in stock!!!!!-img_1848sm.jpg   Stance coilovers in stock!!!!!-img_1912sm.jpg
Old Oct 17, 2008 | 03:58 AM
  #63
PeeTom's Avatar
Do Werk!
I will be joining the stance clan as soon as mine arrive!
Old Oct 17, 2008 | 01:04 PM
  #64
They go out today sir.
Old Oct 17, 2008 | 06:40 PM
  #65
PeeTom's Avatar
Do Werk!
Thanks Rishie!
Old Oct 23, 2008 | 01:12 PM
  #66
Originally Posted by PeeTom
Thanks Rishie!
Sorry, I didn't notice your post until now.
If you have any questions about installing these, shoot me a PM. I'd be glad to help.
Old Oct 28, 2008 | 08:29 AM
  #67
I took the Stance coilovers off my car and put the stock parts back on over the weekend. Winter is coming, and I don't want to get the Stance parts all gummed up with salt. The car doesn't feel as squishy as I thought it would, but it's definitely taller.
The rears took me about two hours to swap, and the fronts about 45min. I'm sure I could get the whole process down to about two hours.
I wanted to make a final note for the season, though. We had a two-day event last weekend. The car still felt pretty good, but my tires were uncooperative. I think they've had enough.
Since I've had the Stance logo on the car at events, I've had questions about them, but the really cool thing is that I meet other people who have also received great support from Stance.
These guys really support their customers. That's fantastic and rare.
I didn't achieve what I wanted to this season, but I usually set my sights pretty high. Next season I'll have the Stance coilovers back on, with a good baseline setup I didn't have at the beginning of this year. I'll have narrower tires in STX, but they'll be better than the Azenis I used this year. I look forward to working with Stance, and I will keep everybody updated on any setup changes they recommend for the new tires.
Old Oct 31, 2008 | 03:00 PM
  #68
imput1234's Avatar
I ♥ Drifting!!!
Can you change the ride height on the Stance without affecting preload?
Old Nov 3, 2008 | 08:47 AM
  #69
Yes. The ride height adjustment is separate from the spring perches on both the fronts and rears.
Old Dec 2, 2008 | 08:50 PM
  #70
RotaryDrift's Avatar
I know I'm probably too late.... but DO YOU HAVE ANY OF THESE LEFT?!
Old Dec 2, 2008 | 09:21 PM
  #71
TopGear8's Avatar
mkuhnracing.com
If you still have them, Send me a PM for the price. Thanks
Old Dec 5, 2008 | 05:23 PM
  #72
Couple sets in stock. PM me for best price.
Rishie
Old Jan 7, 2009 | 06:52 PM
  #73
PF-Racing's Avatar
Pig Fast Racing
You got pm, Rishie
Old Jan 7, 2009 | 08:08 PM
  #74
PM replied Christian,
Sorry i been on holiday for past 3 weeks. i'll be back in my southern Cali warehouse early next week. That's where your paperwork is.
Rishie
Old Jan 28, 2009 | 11:36 AM
  #75
trustbuddy's Avatar
do stance offer these in 6k rear springs like Mr. Pockets experimented? or are only 7k's offered right now?
