Power Adders (FI) For Dummies (Turbo, Supercharger, Nitrous)
Old Nov 11, 2007 | 06:11 AM
  #51
Kane's Avatar
Agreed - but also Know Thyself.
If you tend to be more aggressive than most when it comes to modding; find a shop who is more conservative and vice versa. It never hurts to have a devils advocate. The downside being the point made by Rumboo; lack of exp. But hopefully a happy medium can be found.
Old Dec 5, 2007 | 09:09 AM
  #52
Kane's Avatar
Updated with a tid-bit about Air Fuel Ratios.
Old Dec 5, 2007 | 12:20 PM
  #53
Kane's Avatar
Post #3
Old Dec 5, 2007 | 12:47 PM
  #54
Kane's Avatar
My bad - was that a subtle way to tell me I should have put in a link?
Old Jan 4, 2008 | 09:33 PM
  #55
Viich's Avatar
82 RX-7 GSL
Originally Posted by Kane
Rotary Fragility with Detonation
Understanding the "fragility" of a rotary motor as compared to a piston motor is not a simple exercise. Though the inertial loading on the rods of a piston motor are extreme, the dynamics are known and very simple. Piston design is at a state where there are very few variables left to consider.
A rotary motor is under considerably more stress and that stress is highly dynamic, principally because of the engine's simplicity. Think about what an apex seal is being asked to do: it must support two phases of combustion simultaneously on opposite sides while constantly accelerating (and decelerating) along two axes of motion!
Though there are no rods to stress, detonation affects the dynamics of the rotary motor with forces that are exponentially more damaging than they are in a piston motor. (BTW - detonation is not pre-ignition and understanding the difference is pretty important.) The Renesis is FAR more fragile than any other motor in existence. It cannot take ANY overheating. It cannot survive any pre-ignition. It will not survive any oiling malfunctions. Though it might keep running, any failings in the fuel/water/oil will yield a damaged motor. A piston motor's typical failure mode will lower its operational efficiency by some fraction of its total output. A rotary motor - even with a minor failure - typically becomes completely unusable. Similarly, a Renesis is not really rebuildable after a failure. Under optimal conditions however, the Renesis may be the most robust motor in existence because of its simplicity.
I don't know about this. I know the guys with REW's are putting huge boost on them at times (guys talk about being up around 40lbs) The difference is those engines were pulled apart and rebuilt for boost. It could be done with the Renesis just as easily, it just hasn't yet. Lowering the compression of the rotors, maybe even some shaped scalloping on them, beefier apex seals, and maybe some mild porting (extreme porting is usually only done by N/A guys). Big ignition upgrades, methane and water injections, etc, etc. Lots of things that can be done.
The engine is also certainly rebuildable. Guys have been doing it at home with kits for years on the 12A and various 13B's. The 13B MSP is just the latest variant.
Piston engines that aren't reinforced tend to have problems with boost as well. They also have to have parts replaced when they blow, same as rotaries.
Don't sell these engines so short.
Old Jan 6, 2008 | 04:30 PM
  #56
Kane's Avatar
I agree with most of what you say - the biggest issue for me is scoring housings when apex seals go - last I heard both of Jeff's blown engines were not rebuild-able without new housings.
Old Mar 6, 2008 | 02:15 PM
  #57
snipaz2420's Avatar
the bukkake master!
didnt really know where to post this question so here looked like a good spot. ok well in regards to a turbo how is it that by different tuning, the turbo is able to change how much boost it is providing? like how do you get the turbo to change how much air it is pushing into the engine by tuning. are you somehow increasing exhaust output so that the turbine is spinning more? i know i'm wording it wrong and it probably sounds like a retarded question but i'm just trying to learn so please be gentle
Old Mar 6, 2008 | 02:43 PM
  #58
mysql's Avatar
Doppelgänger
The turbo has a wastegate. It's basically a turbo bypass. When open, exhaust can flow around the turbo blades, causing the turbo to no longer spool up any higher. This is important or your engine will blow up.
The wastegate has a spring that is connected to a pressurized vacuum hose. the pressure opens up the wastegate. So if the spring is rated for 7 psi, it'll start to open up at 4 psi a bit, and by 7 psi it'll be all the way open.
A boost controller can be used too, which sits between the wastegate and the boost signal. All it does is tell the wastegate that there is less psi than there actually is, which keeps the wastegate shut longer, causing boost to build more rapidly. If you wanted more psi, you just tell the boost controller, and it will hold off on telling the wastegate about the pressure till the desired pressure is reached.
Old Mar 6, 2008 | 03:00 PM
  #59
snipaz2420's Avatar
the bukkake master!
thats exactly what i was looking for thanks! so then basically the larger the wastegate the more boost will be allowed(taking the turbo limitations into account)
Old Mar 6, 2008 | 03:02 PM
  #60
staticlag's Avatar
The Professor
The larger the wastegate, and the more control you have over the boost. To make boost the gate is shut, making the exhaust gas push the turbo.
To not make boost the gate opens slightly to let the gas exit out the exhaust. This causes the turbo to slow down because nothing is pushing it.
Old Mar 6, 2008 | 03:04 PM
  #61
staticlag's Avatar
The Professor
check my thread, the first post has pictures of the turbo, the big purple thing is the wastegate. https://www.rx8club.com/series-i-major-horsepower-upgrades-93/esmeril-turbo-kit-review-pics-138414/
Old Mar 6, 2008 | 03:12 PM
  #62
mysql's Avatar
Doppelgänger
Not really. The wastegate just bypasses the turbo, it's function is to prevent boost, not increase it. Also, many turbos have built in wastegates, so you can't replace them.
Like I said, it's the wastegate actuator (spring) that determines how much boost the turbo will reach. A boost controller gives you even more control.
Not all turbos are alike, there are many variations, and configurations.
Also boost is not just boost. You have to consider flow rates too. For example, 9 psi on the greddy turbo is a lot less powerful than 9 psi on the mazdamaniac turbo.
Old Mar 6, 2008 | 03:17 PM
  #63
staticlag's Avatar
The Professor
ah, I remember when 300 was a magical unachievable number
Old Mar 6, 2008 | 03:18 PM
  #64
staticlag's Avatar
The Professor
Now its 400
Old Mar 6, 2008 | 03:21 PM
  #65
mysql's Avatar
Doppelgänger
if you stick with the greddy turbo, 300 will always be just out of reach :P
Old Mar 6, 2008 | 03:44 PM
  #66
snipaz2420's Avatar
the bukkake master!
i miss read your post mysql. thanks to both of you for helping me out!
Old Mar 15, 2008 | 07:59 PM
  #67
Rote8's Avatar
You are looking for an Oxygen candle.
Originally Posted by MazdaspeedFeras
now this may be out of left field, but remember a while back some nascar drivers got fined for having a foreign substance in their airboxes...any idea what that substance was and if it is some sort of evaporating oxidizer where can i get some lol.
My guess would be this:
Oxygen Candle
Wikipedia entry
The candle is Iron and Sodium Chlorate, burns very hot though, 600 degrees C.
There is a Russian version that burns at a lower temp.
Old Mar 16, 2008 | 02:12 AM
  #68
Kane's Avatar
I thought we were not going to go into that part...
BTW - There are other oxidizers that can be used both on the intake side and as a fuel additive; but again... velly velly dangerous.
Old Mar 16, 2008 | 09:55 PM
  #69
Rote8's Avatar
fuel efficiency?
Originally Posted by RogueTadhg
I have a question, I've been reading from different sources for fuel efficiency.
I have seen reports that adding a charger, turbo or super would increase fuel effiency. But i've also heard that adding such devices to increase engine power decreases fuel effiency. I'm guessing there's two type of Fuel Effiency being talked about, but I haven't read 1 source that has both types (if both exist) listed.
I'm interested in getting the highest MPG out of an RX8 as possible and if there's any aftermarket items that would increase the MPG to a more tollerable number - like a low 30s. I don't care about engine power, Im not racing and I don't have any interest in showing off. I'd rather leave a couple minutes eariler and ride without a care, then stress and zoom for that hot flash that'll come over me when I see a parked police car. Thankfully the car must've not noticed me >.>
A gear change would be the only hope, and that would only help on the highway, and would hurt city milage.
Mazmart has a 3.9 and a 4.1 ratio gear set for sale to replace the stock 4.44.
Old Mar 19, 2008 | 10:47 PM
  #70
Robbie's Avatar
How does a taller gear only help highway mileage? A higher gear will help all types of mileage.
Old Mar 19, 2008 | 10:49 PM
  #71
Kane's Avatar
You would push the throttle more on acceleration (since taller gears would be slower) with taller gearing - therefore MPG could go down.
Old Apr 6, 2008 | 11:05 PM
  #72
TechGeek's Avatar
electric Supercharger
Thought I would share this. Hadn't seen anything like this since the RX-8 hydrogen protoype.
http://www.autocar.co.uk/News/NewsAr...-Elise/232017/
Would be interesting to see this applied to an 8 when it hits production.
Old Apr 7, 2008 | 01:16 AM
  #73
Kane's Avatar
I'll believe it when I see it....; but yeah - it would be cool.
Old Apr 7, 2008 | 11:52 AM
  #74
Brettus's Avatar
Boosted Kiwi
mazdamaniac has already cornered the electric supercharger market so this thing will never fly !
Old Apr 8, 2008 | 12:04 AM
  #75
MPG > HP's Avatar
Hey someone with fewer posts than me! You might want to do a second take on the publication date of that article. Also a forum search will kick up a few old threads.
