Pettit Super Charger Owners
Old Oct 24, 2009 | 01:32 AM
  #6351
stephenti's Avatar
Just a thought... could it be that the brass plug restricting the return flow is there to actually aid in cooling the system?
The positive pressure ensures that every nook gets the water/coolant. Also, pressurized water has a higher boiling pint.
Keep an eye on the temps as you experiment with this, as increased flow at the cost of a lower system pressure may or may not yield the results you're after.
Originally Posted by olddragger
jmk--its a brass plug in the return heater hose close to the thermostat housing--it is inside the hose.
Phile if you have replaced the hose with silicone then you are good to go.
thermostat needs drilling to stabilize warm up temps. a non thermostatically controlled seconary radiator will cause the warm up to be a little slower. while this is happening the engine is only getting coolant from the bypass and second rad. when the therm cracks the "cooler" coolant in the primary rad will hit the engine cause a rapid cooling until it balances out. drill the t fix this for me and I think it helps with having constant temps after ther theromstat starts opening.
OD
Old Oct 24, 2009 | 11:40 AM
  #6352
olddragger's Avatar
Dude--we are talking about the restrictor in the heating hose--that coolant is never ever routed to the radiator and it doesnt have anything to do with pressure in the engine---its purpose is to hold coolant in the heater core a little longer and to cut down on the noses fast flowing coolant can may inside the cabin---thats all.
Coolant pressure is handled by the radiator cap.
OD
Old Oct 24, 2009 | 11:58 AM
  #6353
stephenti's Avatar
OD
Got it. I wasn't 100% clear on where this restriction was as described, and thought it was inline in the system. It's great to see such a wealth of info for the rest of us researching this mod.
Old Oct 24, 2009 | 08:15 PM
  #6354
olddragger's Avatar
just took my oil filter apart it was a fram ph type(time for an oil change after break in of 1000miles)
and I am impressed with the filter and the filter mag.
The filter mag did just what it was suppose too---pattern of particles on the inside of the filter can just like the pictures show--and its grit feeling.
The bypass valve is at the top of the filter with an anti drain back feature--all metal, filter material and silicone
The outside of the filter material was dirty--inside clean.
Looks good.
OD
Old Oct 24, 2009 | 11:09 PM
  #6355
Rote8's Avatar
Looks good.
OD
So you are a "hacker"?
Nice find, Fram has improved.
Old Oct 25, 2009 | 08:25 PM
  #6356
olddragger's Avatar
man cave has to have a dremel available at all times!
OD
Old Oct 25, 2009 | 09:53 PM
  #6357
Rotr8's Avatar
whines all the way home
OD
+1 on that, a dremel is like having a go-go-gadget hand for me,,,
Old Oct 26, 2009 | 04:20 AM
  #6358
Rote8's Avatar
OD
I have the cordless.....
Old Oct 26, 2009 | 08:26 AM
  #6359
Rotr8's Avatar
the cordless suck ***, I went through two of them in 3 months, and the docking stations are pretty much worthless,
Old Oct 26, 2009 | 09:15 AM
  #6360
olddragger's Avatar
i even clip the dogs nails with it!
Old Oct 28, 2009 | 11:57 AM
  #6361
JMKuco's Avatar
Rotary engine addict
I just ordered the 2nd pettit intercooler kit !
my question : do I plug it with the S/C intercooler or with the engine radiator ?
Old Oct 28, 2009 | 12:12 PM
  #6362
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
What temperature is the fluid in your intercooler now?? I was under the impression it was the engine radiator water that was overheating. Cam does sell a cooling system that goes to the engine:
Old Oct 28, 2009 | 01:21 PM
  #6363
JMKuco's Avatar
ok !
that's the one I ordered !
I asked just to be sure I did understand well...
Old Oct 28, 2009 | 01:39 PM
  #6364
Phil's 8's Avatar
Originally Posted by Rotr8
you'll like how simple Cams layout is Phil, I just hope it works for ya, on a typical 80-90degree day I saw consistant temps 12-16 degrees cooler, averaging 175-185 degrees,,,
I talked to Cam about it actually working too well now that ambient temps have dropped, he suggested to just block the ram air scoop,,,
Just as a refresher hers what we're talking about,,,
Mine is still in the box.....I'm going to install it this weekend if time permits. We suddenly got a cold storm moving thru Vegas. Unusual for this time of year.
Old Oct 28, 2009 | 06:36 PM
  #6365
Macius8's Avatar
Anyone have any pictures of Cam's upgraded bypass/blowoff valve? Installed would be nice too.
Old Oct 29, 2009 | 08:08 AM
  #6366
JMKuco's Avatar
NOt yet...but I just ordered it :D (thank you exchange rate )
Old Oct 29, 2009 | 08:32 AM
  #6367
Rotr8's Avatar
I can take pics of it later today when I get home from work,,,
Old Oct 29, 2009 | 09:28 AM
  #6368
Macius8's Avatar
That would be sweet. Thanks
Old Oct 29, 2009 | 10:19 AM
  #6369
Rotr8's Avatar
Dont know how well the pics will turn out everything is black, but we'll see...
Old Oct 29, 2009 | 04:59 PM
  #6370
Rotr8's Avatar
Old Oct 29, 2009 | 06:50 PM
  #6371
Macius8's Avatar
Awesome thanks. One more question. Where does the hose from the small nipple in the valve connect to?
Old Oct 29, 2009 | 08:03 PM
  #6372
Rotr8's Avatar
Vacuum...
Old Oct 29, 2009 | 10:23 PM
  #6373
Macius8's Avatar
Thanks, somehow the hose came off and I couldn't find it. Installed the new bypass valve and wow what a difference. The plastic one completely crapped out. The piston inside it pretty much actuated due to gravity alone. Completely different car
Thanks again rotr8.
Old Oct 30, 2009 | 04:28 AM
  #6374
Rote8's Avatar
Vacuum...
Vacuum/Boost, not "Vacuum"
It is a vacuum line that goes on the "boosted" side.
FTFY....
Old Oct 30, 2009 | 08:52 AM
  #6375
olddragger's Avatar
finally gotten a boost gage and oil pressure gage + RB's ashtray mount plate--too lazy to make my own. I have been running the turbo x valve for some time and it seems fine, but i have heard that it leaks. When I get my gauges install (too many damn gauges--now I have 6 to watch lol) I guess I will be able to tell.
Yall are reading the tech section thread on oil pressures? You should.
OD
