Pettit Super Charger Owners
Old Sep 25, 2009 | 03:25 PM
  #6176
Rote8's Avatar
Originally Posted by Striker-7
Let me guess, inadvertent "overpressure blowout panel"?
Well, you gotta ask to know, so thanks for saving me that bit of embarrassment.
He did say they had polished it real shiny too.
Old Sep 26, 2009 | 06:11 AM
  #6177
california style's Avatar
Londons Yellow Peril
yeah unfortunately the welds were ground right out.
It looked nice though, and the rest can be shiny with no problems, just watch out to leave the welds intact!
Old Sep 26, 2009 | 06:54 AM
  #6178
zenrx8's Avatar
Dare I say it, that engine bay is "elegant".
Zenrx8's question does raise a couple of my own, and those would be, "Can you powdercoat the Pettit without damaging the intercooler?", and "Can the weld lines be ground flush?".
Grinding the welds flush, no-no. Besides, Cam's welds are a work of art in their own right. As far as powdercoating, yes , you should be able to do it, but the problem is going to be oil creep contaminating the powedercoated surfaces as the blower sits in the oven. High temp paint should work as well and can be touched up easily.
Old Sep 26, 2009 | 01:04 PM
  #6179
yeah I did hi temp paint too..looks very nice....(imho)
Old Sep 26, 2009 | 02:57 PM
  #6180
Rote8's Avatar
Originally Posted by zenrx8
but the problem is going to be oil creep contaminating the powder coated surfaces as the blower sits in the oven. High temp paint should work as well and can be touched up easily.
Uh, you know you can remove the blower intake and the inter-cooler side too?
Do NOT put the blower into an oven....
Old Sep 26, 2009 | 06:03 PM
  #6181
Rote8's Avatar
I rotated my bypass valve.
Now my vacuum hose fitting is pointed straight away from my blower intake side.
Idle engine vacuum is steady at 20 inches of vacuum, where the other way I had a bounce between 18 and 20.
The vacuum line connection is easier to get to as well.
Old Sep 26, 2009 | 06:48 PM
  #6182
Rotr8's Avatar
whines all the way home
got any pics?
Old Sep 26, 2009 | 08:32 PM
  #6183
olddragger's Avatar
you did what?
you know ppf's can be a bit tricky to get just right.
also having a exhaust leak when cold--after it warns up good it mostly goes away. ???
new gaskets all the way around--hand cut from percy;'s XXX carbon sheet.
you think i have warped a flange?
also with both mm @ 60 hardeness (poly mounts) you do get a bit of nvh below 2.2K. not much--- but it is there, thinking about doing a 1.5 mm set up.60 on passenger side and reinforce a oem mount on drivers side.
you can really tell a different in throttle "stap" and shifting--its nice. just feels stronger.
OD
Old Sep 26, 2009 | 10:25 PM
  #6184
Rote8's Avatar
Originally Posted by Rotr8
got any pics?
Here is the new bypass valve position, this way the vacuum side of the blower intake seems to seal better, under boost it seems the same as usual.
The top -4 AN fitting is my Methanol and the check valves for methanol.
The wire from the very top of the Pettit I/C is the new air temp sensor position.
Yeah, it needs a cleaning, it is my daily driver.
Old Sep 27, 2009 | 08:37 AM
  #6185
olddragger's Avatar
hmmmmm--what type bypass vavle is that?
no worrys mine is a dd too.
OD
Old Sep 27, 2009 | 09:12 AM
  #6186
Rotr8's Avatar
that interesting that yor seeing a difference in vac during idle, what made you think to do this?
and did you paint your LIM in the engine bay or take it out,,,
Old Sep 27, 2009 | 10:31 AM
  #6187
Rote8's Avatar
OD
I got my billet bypass from Cam when he was first testing them, Juan and Gleyner are running the same model.
that interesting that your seeing a difference in vac during idle, what made you think to do this?
The vacuum on the 1 inch pipe pulls the bypass shut harder in this position, more vacuum to boost difference equals a harder pull/push closed on the bypass piston.
The boost pushes the bypass valve piston towards the S/C intake vacuum side, instead of boost pressing the side of the piston to hold the piston shut against the boost.
I painted the LIM out of the engine bay, I also have a Pettit clutch.....
Old Sep 27, 2009 | 03:04 PM
  #6188
JMKuco's Avatar
Rotary engine addict
Question Pulleys for Water Pump and Alternator
hi
While my water pump pulley is out..I was look for some others & I found those 2 ones at fluidmotorsports : "Greddy Pulleys for Water Pump and Alternator"
do some of you guys have them ?
any change noticed ?
thanks
Last edited by JMKuco; Sep 27, 2009 at 03:05 PM. Reason: forgot to mention the brand
Old Sep 27, 2009 | 04:05 PM
  #6189
olddragger's Avatar
if they are underdrive pulleys --dont ---
if they are just lighten pulleys --dont waste your money unless you just like the looks.
OD
Old Sep 27, 2009 | 04:45 PM
  #6190
olddragger's Avatar
ok guys--- i know i am a pain in the *** because i keep talking about our fuel pump /delivery system. But, hear me out.
You dont want to "discover" a fuel delivery problem while you are at 8K in 3nd gear --it may not be pretty.
I dont know if anyone else has done any tracking while running the big pulley setup, BUT I have. Even with the 09 pump in I am suspecting it cant keep up.
Manufacturers design the fuel system so that it can oversupply by 30%. That is basically the rule. Well we are way past that 30%.
Is youre car running well? Probably. A/F's look great and all that jazz. Well--dont feel so good.
Remember we are running with the fuel injectors at 100% duty cycle at times--if there is a dropage in voltage to the pump of only 1 volt---guess what--and it can happen so quick that your a/f gauge may never even read it, or it just gives a lean reading for a split second and you may think its just a hiccup, either way you are playing with blowing it.
I am convinced of it. I mean --how the hell can a oem system safely supply the engine when there is an increase of power by over 50%?
I saw it briefly at Road Atlanta (before my fuel fitting thing). It bogged--it just did not have the power I knew it was suppose to have.
After engine break in--i am getting the Kenne bell boost a pump--not only will it help the pump last longer, it also acts as a voltage regulator specially for the pump. Even if the alternator dies it will still provide the correct voltage. Think about it!
For rezzale.
OD
Old Sep 27, 2009 | 06:17 PM
  #6191
Rote8's Avatar
For rezzale.
OD
Denny,
I fully agree about the fuel system sucking.
I am thinking of going further than changing the stock pump output.
I am actually thinking of replacing the saddle tank with two proper tanks and tee everything, or set an electronically switchable dual tank/reserve system.
Old Sep 27, 2009 | 06:27 PM
  #6192
ZumnRx8's Avatar
RX8 & RX7 owner
Just letting some of you guys know that Phil's 8 from vegas SC AT 4 port dynoed at 258
Old Sep 27, 2009 | 09:14 PM
  #6193
olddragger's Avatar
the fuel cell swap would be one heck of amount of work--you going to a 20B with external pump or something?
easy and cheap--=kb bap! I like e&c
Phil at 258!? Woo Hoo--you go old dude!
OD
Old Sep 27, 2009 | 10:28 PM
  #6194
Rote8's Avatar
OD
No, but I would like my fuel system to be able to fully support that, then I know I have plenty of fuel.
If I build my fuel system for 600 HP, I will not lean out... EVER.
Old Sep 28, 2009 | 06:39 AM
  #6195
the thought that an RX8 might not be able to use up fuel fast enough is scary! ahha!
Old Oct 1, 2009 | 12:38 AM
  #6196
Moon Assad's Avatar
Sweet, I bet phill is lovin that.
Old Oct 1, 2009 | 07:06 AM
  #6197
JMKuco's Avatar
Guys !!
I just received My body kit
Hope I can mount it since the end of the month !!!!
Guess what I choose
I am a little bit disapointed by the bumper finition... I though I might have been beeter
It is not a replica but was kind of cheap (450$) insteed of my dreamed bumper...the Feed's !!! but 1300 box a bumper is a pain in the ***
I'll try to paint my all car with some mettalic aspect
Old Oct 1, 2009 | 07:19 AM
  #6198
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
I had my car dino-ed after seven stock at a little get together put on by Jedi54 of the So. Cal Club. I figured that after all this time, money spent and insults over my 4 port AT I would go ahead and ether show the nay sayers right or wrong.
I do think that 258 is a very respectable HP figure for a 4 port. The Pettit s/c worked to perfection. My tuner even had a smile on his face (he rarely smiles).
I was kinda waiting for the graphs to come out to let everyone know but there has been a delay......somthing to do with software compatibility.
Old Oct 1, 2009 | 08:59 AM
  #6199
hakuna matata!
jedi is always hogging those dyno sheets forever....
Old Oct 1, 2009 | 10:14 AM
  #6200
cool JMK...we are waiting for the pics! 8)
