Axial Flow Short Shifter
Old Jun 17, 2006 | 03:03 AM
  #551
SecrtSqurl's Avatar
Jst wnt a relibl Turbo
When I redline the car in first, and try to shift to second quickly (like racing), my car has a tendency to allow me to miss the shift and grind. I have heard that this is not an uncommon problem and am wondering if any of you that bought this have had this problem, and if so, did this kit resolved the issue?
Old Jun 17, 2006 | 06:15 AM
  #552
FABRO's Avatar
Registered Ricer
Originally Posted by strong bad
found that it was hard to engage reverse.. has this been mentioned before? i'm sure it has.. anyway so i called the number at RP and was told to file that edge down a lil bit... so onto installation #2..
aha. i've solved the wire harness clips.. see, i only could find one flat head screwdriver.. and with that, i was trying to get both sides of the harness clips off at the SAME TIME before lifting up.. without a suitable tool, i had used a paperclip and flathead for each side.. not effective.
then i suddenly realized that i could just pry the clips from any one side while lifting up on the harness until the teeth clicks up on the next highest thread.. then zig-zagging my way up, alternating sides until it came out.. duhh.. im stupid =(
ANYWAY.. so i busted out some power tools.. and filed the top part of the reverse lockout tab so that it tapers off.. then used a file to round and smooth the edge.. now, there is no contact with the tab and plate, and thus.. no struggle getting into reverse. Hooray!
Damint, why me too? Im having the same problem with my shifter, when I try to engage it in Reverse the tab hits the plate. Im too tired now, i'll file the reverse tab down later in the morning. What do you recommend to use to file it down?
Old Jun 17, 2006 | 08:23 AM
  #553
scremn8's Avatar
the more things change
yes it will fix the problem. to bad you missed out on gb..
Old Jun 17, 2006 | 08:34 AM
  #554
strong bad's Avatar
I am still awesome...
hard for me to say because we pretty much have every power tool/tool kit/attachment in our garage for just about any project (my fave is the impact gun).. what's "easiest" for me would not be so practical to the avg person..
if using a power tool you could use a grinder or perhaps even a right angle drill with proper attachment.. other option is just to use a metal file.. i actually used both -- power for doing the hard work faster and then the file to smooth out the edge..
so i'd recommend trying to find anyone with access to any of these tools or worst case scenario buying a file kit..
Old Jun 17, 2006 | 10:36 AM
  #555
MotherGoose's Avatar
Running on double cream
Received and installed last evening. This is one of those mods where it's hard to believe how a small part could make a huge difference in the driveability of the vehicle. 4th to 6th is rather nice.
I had to modify the tab to engage reverse. Fabro, I just used a metal hand file with the shifter mounted in a wood vise. Be sure to use a set of gloves or you'll rip up your palms like I did. I kept checking it every so often as to not remove to much material.
Very simple install.
Old Jun 17, 2006 | 10:50 AM
  #556
lesper4's Avatar
T-29 years and counting
recieved yesterday and installed last night, oh baby its nice, i can see how performance mods are so fun thanks RP its perfect
Old Jun 17, 2006 | 01:09 PM
  #557
RX8SaxMan's Avatar
Mine showed up yestered too. Installation was quick and easy, and everything is great. I love the way it shifts now, and I dont have any problems with 6th or reverse.
Old Jun 17, 2006 | 01:35 PM
  #558
dtorre's Avatar
Ultimate ****** Goderator
are you guys saying 5th gear is so hard to go into because it's actually to easy? I mean I tried to downshift from 4'th to 3rd and ended in 5th lol ....no more inside palm and shove to the right here!!!
Old Jun 17, 2006 | 02:05 PM
  #559
r0tor's Avatar
5th does seem really really close to 3rd now... will have to watch myself for awhile. On the bright side the annoying slop in the left of the 1-2 shift that has caused me to grind gears and miss shifts seems to be gone - thank god
One tip for those harness clips - after thinking for a few minutes i was able to get them off in about 2 seconds by: squeezing the inner tab (by the threads) on one side to the outside of the whole clip with a needlenose pliars and then hitting the tab on the other side with a nail and then pulling up with the pliars.
Old Jun 17, 2006 | 05:58 PM
  #560
r0tor's Avatar
after another test drive, this thing kicks so much ***!
Around town the shift effort may be a tad on the high side, and it is a tad louder, but when driven aggressive I can finally shift as hard as i'm driving with absolutely no worry of missing a shift - the feedback is so much more positive and the best thing is the bulletproof, solid feel you get while horrendously thrashing through the gears.
I tend to think the "rifle bolt" term to describe shifters is way over used, but in this case thats the only thing that comes close to describing it!
Old Jun 17, 2006 | 07:08 PM
  #561
D2RX8's Avatar
Installed it yesterday, and I agree with r0tor. Around town the effort is a little on the high side, but it is absolutely worth it!
I broke the first tab on the right side because I had trouble removing it... I stopped and read through all the posts talking about the tabs... then I found one that said "Just push it towards the passenger door, real easy to do". In a way the statement is correct...real easy to break!
The rest was a piece of cake... I did find a bunch of black crud on the 2nd boot:
I'm guessing it came from the "foam" under the boot... why it is on top of it I do not understand.
I also read that removing the insulation in the shifter cover can reduce the extra noise... does it make a big difference?
D2.
Old Jun 17, 2006 | 07:46 PM
  #562
Richard Paul's Avatar
We did 4 cars today at the shop. I yanked them all with no broken tabs. "Yanked by the Yank" ....Gomez.
The black crud is from the boot being rubbed by the bottom of large OD on the stock shifter. Wouln't happen any more.
Yes, remove the green fuzzy thing, it reduces the noise for reasons unknown to modern science.
"Towards the passanger door" in RHD or LHD? Be carfull who wrote the instruction. Which side of the world do they live? Top or bottom?
Old Jun 17, 2006 | 07:59 PM
  #563
poolsidenaz's Avatar
My neighbor helped me install mine today. It's louder than stock for sure, and it locks into gears real nice. Love the feel and have ever since I sat in someone else's drivers seat who had the SS installed.
Now how to fix the wiring for my illuminated ****? It was working fine after the SS install. I tested it when I reconnected it just to be sure I didn't do anything when taking it off. Well apparently when screwing it back on I broke a wire and it's not working now...just in time for tonight's club meet.
Old Jun 17, 2006 | 08:06 PM
  #564
One of the cars we did today had had the illuminated **** but it had broken the wire where it comes out of the unit. At least that's what I was told. He also said they all break. Another owner there concured his had also broken.
Old Jun 17, 2006 | 10:51 PM
  #565
yes,
the lite shift **** broken wire is a know problem... i think a diy fix for it...
Old Jun 18, 2006 | 06:06 PM
  #566
tejon's Avatar
Installed, and I am very satisfied. It reminds me of the "shift feel" of the Morgan that I used to own. I believe that it had a Moss transmission. This would be the first mod that I would make if I were to buy a new 8.
Old Jun 18, 2006 | 08:51 PM
  #567
scremn8's Avatar
mine is in on. there's a group shot of five of us in someones camera
Old Jun 19, 2006 | 03:44 PM
  #568
DarkBrew's Avatar
Extraordinary Engineering
Still waiting
Old Jun 19, 2006 | 04:53 PM
  #569
Sorry Warren, you and one more go out today. I didn't want to overload the Ontario customs with the same "gift" all in one day. It goes 4-6 day Priority Mail.
Old Jun 19, 2006 | 06:10 PM
  #570
DarkBrew's Avatar
Cool! Thanks Richard.
Old Jun 19, 2006 | 06:56 PM
  #571
SiLVeRE8's Avatar
a.k.a. WhITeRE8
received like 30 mins ago and just finished installation and test drive. holy **** this is the funnest mod i ever got for my car!!! i have no prob with reverse or any gears at all! it seems much easier and smoother getting into every gear!! LOVE THE SHORT SHIFTER!! thanks for the GB Vice and Richard!!!
Old Jun 19, 2006 | 08:36 PM
  #572
vIce^gRip's Avatar
Honor & Integrity
GB UPDATES HAVE BEEN MADE....
http://axialflow.com/ssgb.htm
It is funny how a simple little shifter can make that much of a difference ehh???
I think I said somewhere before it adds 5 HP in the fact that you feel like you can get to 4th gear faster!!!
Old Jun 19, 2006 | 09:16 PM
  #573
aplx's Avatar
I received my shifter today…. All I can say is OMG! This thing is so cool, worth every penny if you ask me. Thanks to everyone who help organize the group buy specifically vIce_gRip, sorry if I missed anyone else. Also a big YOU ROCK to Richard Paul for making such a great product.
Aplx
Old Jun 19, 2006 | 09:43 PM
  #574
G-ReX's Avatar
A Torque-Free Zone
Finally got around to the install today. I had issues with the infamous right rear tab - now cracked, but not broken. Definitely use the wrapped screwdriver technique. I had to do a few rounds of filing to get the reverse tang down enough to make reverse usable in daily driving. Works beautifully now. Love the tight shifts! Awesome shifter!
Old Jun 19, 2006 | 11:08 PM
  #575
I gotta get those clear corners. Amber looks real extra shitty on yellow.
