Interceptor help, Rough idling, P0661 CEL
Old Jun 16, 2006 | 01:22 AM
  #26
Originally Posted by Bart!
Okay. Intercooler piping came off, the long pipe where the other end holds the airinix. Couldn't get it back on in time because I had a soccer game, but I'll be getting that sucker back on tomorrow morning. That was probably the effin CEL, and the poor idling. I noticed there was some sort of silver liquid inside that pipe, what the hell was that? It didn't really have a smell too it, but if anyone is experienced with computers.. it's pretty much like the liquid form of Arctic silver paste that goes onto the processor.
uh,
that would be a vacum leak... as to the silver stuff... the artic silver is a great discription, but i have no idea..
Old Jun 16, 2006 | 02:02 AM
  #27
MazdaManiac's Avatar
Nope, not a vacuum leak. A vacuum leak is after the throttle body.
Air was being drawn in after the airflow meter. This allowed for a lean condition because this air was not metered. This would be most noticible at idle when the airflow was small.
The silver stuff is lubricant used when making the bends in the aluminum tubing. Nothing to worry about. You can wipe it off if you don't like it.
Old Jun 16, 2006 | 02:06 AM
  #28
got it, but a leak none the less... would not that area be under vacuum when not in boost??? i am trying to get this concept into my head...
thx,
Old Jun 16, 2006 | 02:39 AM
  #29
It shouldn't be under any sort of traditional "vacuum" - that would be the indicator of a restrictive intake.
However, the pressure would be lower than ambient (since air is flowing). Not a significant amount, I'd hope.
The throttle acts as an intentional restriction. The rotating motor is trying to draw in air, but the butterfly keeps it from acheiving the desired flow. This yeilds a vacuum in the manifold.
Old Jun 16, 2006 | 02:44 AM
  #30
thx,
not i got to go find a diagram of the greedy kit.. it will come to me... got the symptoms right...
Old Jun 16, 2006 | 06:43 AM
  #31
Bart!'s Avatar
RAWR!@#
Just fitted everything back on, huge overall boost of power. I can't believe the ENTIRE fitting just came off.
Old Jun 16, 2006 | 12:22 PM
  #32
I can't believe you drove it that way.
I keep a very basic set of tools in my car at all times.
Every car I've ever owned has lost a charge pipe at some point for some reason, so I'm prepared.
It is usually the ones that are connected to the intercooler because they get banged around a lot.
However, since I switched to Turbonetics t-bolt clamps, I haven't had one come off.
Old Jun 16, 2006 | 03:26 PM
  #33
rotarygod's Avatar
I do need to point out that it wasn't the Interceptor that had the problem afterall. Many people have blamed it for problems that it hasn't been responsible for and I just thought it would be nice to exonnerate Scott since he has been the one that has worked extremely hard (and been repeatedly criticized without cause!) to give us a good and reliable product superior to any other ecu currently available for the car.
Old Jun 16, 2006 | 03:48 PM
  #34
I don't know about "superior", but it is effective.
I'd add that the vast majority of problems people face with the various solutions are, in one way or another, "user error" rather than an inherent failing of the components in question. There is a fundamental lack of understanding that this sort of modification is not a casual one and requires an intellectual investment.
These EMS boxes are just tools. It is up to you to use them effectively. I always prefer to do the job with what is available and walk the path less traveled, rather than get on the highway with everyone else - hence my resistance to merely accept any particular "P-n-P" solution.
Hands matter.
My favorite comparison would be David Lindley to Eric Johnson.
Both produce astounding music, but one does it with an arsonal of high-thech goodies and the other with whatever junk is available.
That's why "Running on Empty" sounds better to me than "Cliffs of Dover".
But I digress...
Old Jun 17, 2006 | 05:12 PM
  #35
rotarygod's Avatar
That was the whole point. Typically when people try to use something they don't fully understand, the first thing they blame when a problem arises is the product rather than thir own abilities.
Nothing wrong with that if you have the skills which you obviously do. I build/adapt a lot of my own things as well.
mdl0209
May 23, 2019 05:46 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
