Rx8 Greddy Turbo from brazil - 255.5whp with 5psi
Old Aug 10, 2005 | 05:58 PM
  #26
what are the other 2 boxes attached with the unichip in the 4th and 5th pics above?
Old Aug 10, 2005 | 06:57 PM
  #27
BrazilianRX8's Avatar
the hp difference is running at about 35hp (at least on my car)
the dyno does this calculation based on the "weight" of the transmition during the "come back" of the rpm, this i done when you release the gear that you are on after acelerating on to 9500rpm down to 1000rpm
... i think my explanation sucked .... (i am a portuguese speaker:D) if any one care to do it better please help....
Old Aug 10, 2005 | 07:01 PM
  #28
the unichip is a 32bit computer that runs with a lot of possible add ons...
the one on the right is to 'see' the pressure that i am getting and pass it on to the main unit to control the extra injector.
the other one is to control the solenoid.... it comunicates with the main unit too... of course
Old Aug 10, 2005 | 07:02 PM
  #29
the hole unichip fits right in toguether with the car's original ecu
no modifications made to have it fit.
Old Aug 10, 2005 | 07:20 PM
  #30
last track day picture
Attached Thumbnails Rx8 Greddy Turbo from brazil - 255.5whp with 5psi-small_dsc08078.jpg
Old Aug 10, 2005 | 10:27 PM
  #31
BigOLundh's Avatar
#1 Legend
Originally Posted by adrian-1
He's running at 0.7bar (10psi) and 0.5 bar holding (7psi). Also, he said they have 25% alcohol in their gas down there.
And also... those dynos are not at the wheels...
Still very impressive tho.
Old Aug 11, 2005 | 05:50 AM
  #32
http://www.multiturbo.com.br
shop owner is a nice guy called eytan
cheif tuner is also a nice guy called leo
give them a call and find out
Old Aug 11, 2005 | 05:58 AM
  #33
http://www.oktaneclub.com/
this is the link for a race group down here in brazil
subscribe to it and ask around for people that were there at the time....
(have to speak portuguese tho
Old Aug 11, 2005 | 06:03 AM
  #34
ahhh
there is a CBA (confederacao brasileira de automobilismo = brazilian automotive confederation) director on the group... ask him
also check his credentials on www.cba.org.br
(i am also a member... not givin you my name tho)
Old Aug 11, 2005 | 06:07 AM
  #35
last one on this subject....
i am trying to get help for my matters and give help, if i can, to any one who asks...
no one here pays my bills ... so no one should be impressed by impressive numbers
if any one is interested in replicate my experiments they can do so with the info that is posted here
this is my contribution.
Old Aug 11, 2005 | 02:09 PM
  #36
thank you
Old Aug 11, 2005 | 05:24 PM
  #37
storemannormin's Avatar
hey do you have to have a laptop to do the install on the greddy turbo?
Old Aug 11, 2005 | 05:34 PM
  #38
rkostolni's Avatar
This could turn out to be good way to go, and looks like it has worked on your car, but the emanage works great on some rx8's also. In general this will not work on many rx8's for the same reason that the emanage doesn't, the ecu adapts to any change you try to make. For a turbo you run an A/F of about 11.5:1, which is far richer than the stock ecu likes, therefor it decreases the fuel output to the stock injectors. If you add more, whichever way that might be, it will just pull more. Now there is a limit to how much it can pull, but if it reaches that limit it will throw a cel for LTFT out of limits. I would watch your A/F carefully as it will take a few hundred miles for the ecu to completely adapt. You really need to get the stock ecu out of control to properly tune the car.
Old Aug 11, 2005 | 05:38 PM
  #39
i'm not sure i folowed you....
i used a laptop to program the unichip and to colect data coming from the car, done with hymee's scanalizer (great tool!!!)
Old Aug 11, 2005 | 05:42 PM
  #40
adrian-1's Avatar
Ex- member.
No, you do not "need" a laptop to install the greddy turbo. The greddy rx8 map is already loaded, but it is pig rich. If you want to tune it, then you'll need the support tool and a laptop to make changes to the map.
Old Aug 11, 2005 | 06:08 PM
  #41
i asked Unichip that exact question today. The unichip has complete control and the pcm will not be able to dial it back. nor would a flash force you to make changes to your maps like when you have the emanage.
I will give you the Mini Cooper as an example; Mini is on REV 42 of the factory ECU meaning that they have re-flashed the factory ECU 42 times since the release of the Mini and we have not had to change the Unichip calibration one time. Even if the Unichip is installed on the Vehicle when they re-flash the stock ECU it will not effect the Unichip or its calibration.
Best regards,
Joe Pucciarelli
National Sales Manager
Unichip of North America
Old Aug 11, 2005 | 06:11 PM
  #42
oh ok I don't know what that means running rich, burns lots of gas?....I just want to install it and go fast
Old Aug 11, 2005 | 06:20 PM
  #43
PoLaK's Avatar
Son what is your Alibi?
oh ok I don't what that means running rich, burns lots of gas?....I just want to install it and go fast
< sings "im so smart, S-M-R-T, so so smart, S-M-R-T"
Old Aug 11, 2005 | 07:18 PM
  #44
Student Driver
I keep seeing Patrick from Sponge Bob singing this...
Good one PoLaK
Old Aug 11, 2005 | 09:48 PM
  #45
great job
PoLaK....
i was takin it seriously... dont know why...
Old Aug 11, 2005 | 09:59 PM
  #46
you are right on zoom44!!!!
but since unichip is so independent, it is a bit harder to clean out the map....
the scanalizer has been a very good tool to help me solve my map.
i recomend it to any one who wants to do a serious tuning
it was acctualy scanalizer's data that made us go back in the tunning to more safe numbers and smother, less powerful, power curve.
right now i am trying to trim, what i think to be the very end, of small back fires, during extreemely heavy use. i know that the source of it is extra gas, so my engine is unharmed.
got to be very careful pulling fuel form it douh
if unichip america wants the data that we produced over here, we will be more than happy sending it.
solenoid, maps, injector specifications... basicaly...
Old Aug 12, 2005 | 06:12 PM
  #47
rkostolni's Avatar
I could be mistaken but I believe the unichip has full control over the single new injector. It has no control over the stock injectors. So while it is true that the stock ecu can't pull fuel from the new injector, it will pull it from the 6 stock injectors to compensate and get the O2 sensors back to 14 or so A/F Which will still cause the same problems. Unless I'm wrong and the Unichip is in fact a full stand alone ecu that controls the 6 factory injectors in addition to the added injector. I hope I'm wrong of course, and this fixes the Greddy issues, I would love to have a cheaper solution than the interceptor.
Old Aug 12, 2005 | 06:48 PM
  #48
i can oly tell you what Joe Pucciarelli the National Sales Manage for Unichip in the US told me. that the unichip has full control over Fuel and Timing and the stock PCM has none. I can check with Pineapple Racing to see what they say since they are dealers. and soemone ask corksport too . they have some history with it on the RX8.
Old Aug 13, 2005 | 09:01 AM
  #49
as far as i know the unichip solution can be a stand alone OR a piggy back.
how ever due to the complexity of implementing stand alone, we dicided to go for the piggy back.
my unit controls the extra injector, and the boost.
so far the ONLY ecu error that i EVER got was related to o2 sensor. but i can see your point. what might be happening then is that i am putting in what ever the original ecu takes out :D.... and from that i am not getting any erros nor i am having dificulties on the power curve, it is as good as it gets.
as far as the o2 sensor errors, i still have a lot to trim there....there are times the the o2 sensor goes out of resolution because it is soo rich. this is on purpose exclusively to protect the engine.
one extra trim that i had to make was to move the rpm cut down to 9000... that was done basicaly to protect the turbo
Old Aug 13, 2005 | 09:10 AM
  #50
if you take a look at the le mans series you will see the mazda team explaining that they run realy realy rich....
and man look at the flames ... beautifuly huge back fires...
