Turbo Intake Manifold Design
Old Jul 20, 2004 | 05:37 PM
  #26
rotarygod's Avatar
Originally Posted by 86rx7
umm.. wouldnt that mean that the s-dias stuff wouldnt function under
WOT when there is zero vacume? You sure they dont use airpump air or something else?
You might have me on that one. It could be run off of the airpump.
Old Jul 20, 2004 | 05:38 PM
  #27
rotarygod's Avatar
Originally Posted by shelleys_man_06
Back to the intake manifold, would using longer runners affect low-speed power? The goal for any tuner, especially in making a sound street car, would be to increase the average power, not maximizing it at x-rpm. I think this is why S-DAIS is employed, since changing the length of the runners assures a healthy powerband and a flat torque curve.
Yes it would affect low speed power. It would increase it. The turbo makes up for the top end. It would be a nice braod power curve.
Old Jul 20, 2004 | 05:47 PM
  #28
rotarygod's Avatar
If you blow up an engine at only 5 psi, it is really quite simple, it wasn't tuned. Period. I don't buy into the it was the side seals crap. They are sheltered around the side of the rotor. They may cross over the exhaust ports but the exhaust gasses do not directly cross the seals. Look at a rotor or a picture of one sometime to see what I mean. The side seals are much thicker and stronger than the previous seals as well. I find it interesting yet strangely disturbing that one shop could blow up more than one engine. If it wasn't one shop, they do know the people who have done it. Since no one here knows of anyone who has, it is easy to see that they are affiliated in some way. If I blew up 8 motors, I'd find a new line of work. Don't be afraid to tells us who they are. You'll do us a favor by letting us know who to avoid. I won't use them anyways so no harm done here.
Just some food for thought. If someone were developing a turbo kit and knew they had competition, they could very easily claim that the engines blow up with forced induction. That way they would discredit their competitors systems. Then when theirs hits the market they can claim to be the ones who have solved the problem. Not everyone falls for it but some do. We see it here on this forum from time to time. Some people still claim the engine can't be boosted. It can.
Old Jul 20, 2004 | 06:15 PM
  #29
shelleys_man_06's Avatar
Not anymore
I concur. A broken side seal, I believe, has nothing to do with the actual combustion process. From the looks of it, the side seal might be the last one to be compromised. I hope someone will be able to answer this question:
Also, is the intake manifold on the RENESIS symmetrical? If not, what would be the effect of a symmetrical manifold? I hear that Mazda rotary engines employ non-symmetrical manifold designs, but I'm not sure.
What about the position of the fuel injectors? Will the angle with respect to the horizontal suffice under a high-boost application? I hear injectors are not to exceed 20 degrees with the horizontal (Corky Bell).
With the extra boost supplied by the turbocharger, is it necessary to include a MAP, assuming there would be a positive change in pressure in the intake manifold?
Old Jul 20, 2004 | 07:27 PM
  #30
see i should have said my piece first and then had rotarygod back me up. side seals breaking seems to me like it would be more of a oil injection problem than a boost problem. also another thought. how did they get 8 motors to work on? did they buy in bulk? or did they break the same on over and over. what's the going price for a renesis? somewhere close to $6,000 right?
Old Jul 20, 2004 | 07:40 PM
  #31
Not anymore
Don't feel bad Zoom44. You did make a good point .
Is it possible to buy engines in the bulk? Seems kind of like a Sam's Club deal . I hope whoever broke eight engines didn't use the same one over and over. IMO, if it breaks once, there's no point in re-trying. I would imagine that a 13B-MSP new would cost $6,000.
Old Jul 20, 2004 | 07:59 PM
  #32
but i think if a "good" rotary shop( think Atkins Rotary) toasted some seals while tuning a new FI component they would pop it open fix what broke and put it back together. they would also know exactly WHY they toasted those seals. so they would not repeat that mistake. if for some reason those seals broke again they would be replaced with much stonger ones. there is no reason for someone to burn thru 8.
Old Jul 20, 2004 | 08:01 PM
  #33
skc's Avatar
skc
rev it up
Guys,
I am not sure if you are aware that a turbo has been sucessfully added to the renesis engine. They claim increased power with low boost. Try the following link for more information. https://www.rx8club.com/australia-new-zealand-forum-37/rotor-master-turbo-30526/
I understand the system is for sale.
skc
Old Jul 20, 2004 | 08:10 PM
  #34
thanks for the link. i should pay more attention to the aussie forum since they are well know for their rotary madness. i have posted there for more info.
Old Jul 20, 2004 | 09:52 PM
  #35
Not anymore
This is what I get for avoiding the Australian RX-8 Forum .
Old Jul 22, 2004 | 05:02 AM
  #36
86rx7's Avatar
In rex'es side seal only usually break if you clearence them bad, or the rotor hits the side housing, or super bad detonation or soemthing else catastrophic. It is possible though that the side exhaust ports are stressing them much more, or maybe the new keystone side seals are weaker? or maybe it was a fluke....
Old Aug 25, 2004 | 04:50 PM
  #37
Not anymore
What are the keystone seals made out of?
Old Aug 25, 2004 | 04:55 PM
  #38
rotarygod's Avatar
Beer bottlecaps!
I just tried calling you! Check your messages!
Old Aug 28, 2004 | 11:06 PM
  #39
Not anymore
Sorry about that. I was at work.
poacherinthezoo
Aug 3, 2016 11:01 PM
vapor2
Jul 9, 2016 07:35 AM
Rx8_412
Sep 24, 2015 08:51 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
Fickert
Sep 9, 2015 01:21 PM
