Gauge mounting solutions
Old Jun 2, 2010 | 06:49 PM
  #26
kster's Avatar
Thanks for the update. For your first attempt, the gauge pod looks pretty good.
Regarding the spot where you inserted the oil line, that's a factory plug that you removed?
Also, any reason not to use the Racing Beat water temp sensor?
Old Jun 2, 2010 | 07:56 PM
  #27
BlueR3's Avatar
Wants to tune my 09
Yes, that is a factory plug. The shop manual calls for Mazda techs to remove that plug and hook up their pressure gauge for troubleshooting purposes so that is a perfect place for the sensor. Since the oil temp doesn't work how I have it set up, you wouldn't even need the steel line, you could just screw the sender in after taking out that plug. I can't think of any reason not to use the RB sensor, I just felt like ordering all my stuff from one place. The upside of that one is stated...it has continuos flow. The one I and so many others have installed doesn't require cutting any coolant lines, but doesn't start to register until the thermostat kicks open, but I don't mind.
Old Aug 10, 2010 | 04:22 PM
  #28
GT'ler's Avatar
Hi BlueR3,
I like to do the same like you.
I'm lucky someone tried it first. I was really unhappy after the mail from racingbeat as they wrote they haven't a solution.
Is the Oil temp working now?
Old Aug 10, 2010 | 10:12 PM
  #29
fyrstormer's Avatar
2009 RX-8 Touring
If you want gauges that are actually useful while driving, put them on the A-pillar or the steering column. Anywhere else is too far away from where you should be looking (i.e. straight ahead) and you won't be able to monitor them out of the corner of your eye. My preferred location is the A-pillar because they don't overlap the gauges in the instrument cluster.
Here's a pic of the gauges I put in my Passat. You can see they are easily visible while keeping your eyes on the road ahead.
Old Aug 11, 2010 | 08:46 AM
  #30
BlueR3's Avatar
Wants to tune my 09
Unfotunatly I have been extremely busy this summer and havnt had a chance to rework the oil temp. I do agree that the pillar mount is easier to see but mounting there is annoying to me. I have a similar setup on my wrx but really Find it annoying because it increases the size of your blind spot a little and the gauge lighting in my eyes at night is annoying as well. The good part though is how easy the boost and egt is to read. But on the 8 a quick glance Down is no big deal to me and once I get the time to refinish the way I want, in my opinion the ashtray area is really clean looking.
Old Aug 11, 2010 | 09:20 AM
  #31
GT'ler's Avatar
yes it's right that the ashtray isn't the best solution. If I make it there is "written in the stars".
First, important for me is the technical feasibility. Is the clearance enough to fit the pressure sensor without the hose?
the prosport gauges are looking good.
Old Aug 11, 2010 | 10:15 AM
  #32
MC8jai's Avatar
Proud R3 Owner
Here is a pic of how I mounted mine. Sorry about the quality of the pic, but you can get the idea.
Attached Thumbnails Gauge mounting solutions-34047_10150195581840654_812210653_12999962_4402691_n.jpg
Old Aug 11, 2010 | 04:56 PM
  #33
GT'ler's Avatar
Thanks guys!
@MC8jai: How did you get the oil temp?
Old Aug 11, 2010 | 05:48 PM
  #34
You could mount a fitting in the oil return line where it returns (after the coolers) the block. I forgot the size of the fitting I used when I converted to a single cooler but that would be the easy place to do it and totally removable if needed.
Old Aug 12, 2010 | 01:38 AM
  #35
kokats8's Avatar
and mine with defi from spec a
Old Oct 21, 2010 | 11:18 AM
  #36
Nemesis8's Avatar
Bigus Rotus
While that looks really nice for the Passat, I have yet to find anybody making a good A-Pillar gauge pod for the RX8....
Old Dec 20, 2010 | 12:52 PM
  #37
paimon.soror's Avatar
Hate reviving old threads but this put a huge happy face on me haha. Looks like this means that I will be grabbing myself some gauges soon now that I know I can monitor oil press . Thanks! Btw, ever find a good place for the temp sensor? Question #2 is, when installing that water sensor, I take it that unless I drain some coolant, I am going to get it pouring out of that line when i crack it open huh?
Old Dec 20, 2010 | 01:37 PM
  #38
Ok, for oil pressure, you could use the a "T" fitting if the 09+ uses the same type of oil pressure sending unit as the 04-08's. Just install the "T" in teh factory threads on the rotor housing and then reinstall the factory oil pressure sending unit (so your gauge in the cluster still works) and then install the sending unit for the Prosport gauge (only one I know of that goes to 150psi).
For oil temp, install one of these (need to verify thread type, etc) between the oil pump and the oil cooler feed line.
Old Dec 28, 2010 | 05:45 PM
  #39
linuxadickt's Avatar
Rotary Enthusiast
I just fabricated one! not 100% without flaws (that i know about) but works well and looks good. Painted Glossy black after the whole thing was said and done. i can get instructions and materials if Anyone needs, just PM me
Attached Thumbnails Gauge mounting solutions-29960_10150208483540224_501390223_13102910_6780280_n.jpg   Gauge mounting solutions-61904_10150277393855224_501390223_15081387_5896392_n.jpg   Gauge mounting solutions-30160_10150199752520224_501390223_12833939_6510992_n.jpg   Gauge mounting solutions-29960_10150207841600224_501390223_13088080_3853215_n.jpg   Gauge mounting solutions-29960_10150207842945224_501390223_13088090_5883387_n.jpg
Old Dec 28, 2010 | 05:49 PM
  #40
Nice fab work.
Old Dec 28, 2010 | 07:46 PM
  #41
steve2tails's Avatar
https://www.rx8club.com/album.php?albumid=1629
Old Dec 28, 2010 | 10:41 PM
  #42
I thought someone tried this method for the oil temp and it didn't end up working? I believe it is mentioned earlier in the thread.
Old Dec 28, 2010 | 10:56 PM
  #43
Rotary Enthusiast
I just got a block adapter, I think Its $29 or so. I was going to do a relocate but got lazy and just got the adapter. Much easier
Old Dec 28, 2010 | 11:00 PM
  #44
Link to the block adapter? I am just trying to get everything together here. I have my water, oil temp, oil press gauges from prosport along with a water adapter for the water temp in my shopping cart.
Old Dec 28, 2010 | 11:09 PM
  #45
Rotary Enthusiast
http://www.glowshiftdirect.com/oilfi...5thread-1.aspx
Just make sure the senders are the right thread and size. Otherwise you can get them from glowshift. They are a bit cheaper but not bad for budget and I've not had any problems with them, just be sure to take the scratch cover off when you get them installed
Old Dec 28, 2010 | 11:51 PM
  #46
Originally Posted by linuxadickt
<a href="http://www.glowshiftdirect.com/oilfiltersenderadapter-20mm15thread-1.aspx" target="_blank">http://www.glowshiftdirect.com/oilfiltersenderadapter-20mm15thread-1.aspx</a><br />
<br />
<br />
<br />
no wonder i was confused...these dont fit in s2's...gotta recheck where you are posting
Old Dec 28, 2010 | 11:58 PM
  #47
Rotary Enthusiast
Sorry, I didn't see any specific gauges mentioned. Are s2's prosports? There are quite a few there size options on the block adapter page
Old Dec 29, 2010 | 12:43 PM
  #48
The Sandwich Block does not fit the S2. Tried that a year ago save your money
Old Dec 31, 2010 | 03:49 AM
  #49
jasonrxeight's Avatar
anyone tried to use the dash display to show the numbers? I dont like the gauges sticking out my dash.
Ive seen someone done it on S1 and it worked pretty nice.
Old Jan 2, 2011 | 03:13 PM
  #50
^^ I believe that thing was called the GOODBox, doubt it would work on the S2 though. I wont mind the gauge mod as long as there is a clean way to get the lotek to work
