Series II Technical and Trouble shooting Discuss technical details for the Series II RX-8 and any issues or problems you are facing
My 20K (12K Miles) Service with Spark Plug Pic
Old Jan 30, 2010 | 11:20 PM
  #26
lzhmax's Avatar
Rotryyyyyy
Originally Posted by ASH8
Can't exactly remember as I used up the last (almost) in two separate Redline Containers (see Air Filter Pics ^^^) which I then pour into a separate pump bottle and then pump into Trans/Diff till it overflows, which is the correct procedure...the Diff is same as S1 capacity wise around a litre, and the Trans is about 1.9 litres...
Sorry I don't measure it, I refill till it overflows...
Thanks Ash
Old Jan 31, 2010 | 06:03 AM
  #27
lzhmax's Avatar
Rotryyyyyy
BTW,Ash,
Where do you recommend to change the spark plug?? is the dealer ok?? or i just need a workshop?
Old Jul 9, 2010 | 10:39 PM
  #28
MC8jai's Avatar
Proud R3 Owner
the gear box 2.0L and the Diff is a bit less than 2.0L
I just did my gear and diff, 2 bottles of each from Redline is just enf.
Old Apr 16, 2011 | 02:13 PM
  #29
liq's Avatar
liq
Here are my plugs after 19k miles, 1 year, and about 25 autocrosses
Attached Thumbnails My 20K (12K Miles) Service with Spark Plug Pic-img_0499.jpg
Old Apr 18, 2011 | 09:07 PM
  #30
moeswrx's Avatar
I thought the S2 models do not need to use pre-mix oil due to the third oil injectors? Anyone else using pre-mix besides the well informative Ash from down under?
Old Apr 19, 2011 | 05:28 AM
  #31
PeteInLongBeach's Avatar
I'm premixing about 4 ounces of Idemitsu per fill-up in my S2, which roughly matches the volume of motor oil it has been using. I think they are running the oil injection rates pretty lean, so I feel premixing can't hurt anything.
Old Jul 11, 2011 | 08:23 AM
  #32
hoss -05's Avatar
Lucky #33
Crusty~!
ironj221
36
Jan 20, 2026 08:28 PM
05TR1CH
Apr 18, 2023 04:56 AM
PotatoCannon
Sep 6, 2015 11:48 AM
Zank300
Aug 26, 2015 07:40 PM
AussieGray
Jul 16, 2015 03:58 AM
