Do you rev before turning off?
Old Nov 20, 2009 | 12:11 PM
  #26
Mazurfer's Avatar
Surf Hard, Drive Hard
Originally Posted by ARE-EX-8
I know the needle is not in the middle at first. But what im asking is ... atfer your rev 3k for 10 sec it wont make the needle go to the middle... do you still shut it off though ? Sorry i know im being a pain in the ***.
"YES", I don't know why it took so long to answer your question.
Old Nov 20, 2009 | 12:15 PM
  #27
tamz273's Avatar
Yeh thats the whole point of revving it for 10 seconds.. If the needle is already in the middle, most people dont appear to be revving before shutoff..
Old Nov 20, 2009 | 12:30 PM
  #28
Huey52's Avatar
Registered Zoom Zoomer
Oh, now I get it [thanks to others]. You meant to ask "If the coolant temperature needle is at the midpoint of its range do you need to follow the Rev procedure?"
The answer is No, since the vehicle is already warmed up.
If however the coolant temp. needle indicates below nominal operating temperature (to the left of midpoint) then Yes the procedure is recommended.
You'll find that using fully descriptive sentences, especially when posing a technical question, makes life far easier for others and you'll get better and more timely answers.
question ... if you rev 3k for 10 seconds... and the needle is not in the middle... do you still shut if off ... shouldnt the needle be at least half way ?
Old Nov 20, 2009 | 12:53 PM
  #29
ARE-EX-8's Avatar
Rotary > Piston
Ye i figured lol . Sorry about the trouble in communication guys.
Old Nov 20, 2009 | 01:01 PM
  #30
Huey52's Avatar
You had me thinking the midpoint of the tach, since we were discussing rev limts, and I got all confoosited.
Old Nov 20, 2009 | 01:06 PM
  #31
Mazurfer's Avatar
I thought that's what you were thinking!
Old Nov 20, 2009 | 01:32 PM
  #32
ARE-EX-8's Avatar
Rotary > Piston
maa badzz
Old Nov 20, 2009 | 06:08 PM
  #33
GeorgeH's Avatar
Absolutely no reason to do this unless the engine is cold. I've had my car since new in '04, and have never done this, unless the idle is above 1250 or so.
Waste of carbon.
Old Nov 20, 2009 | 06:55 PM
  #34
04RX8man's Avatar
Rotary Powered Countryboy
I don't do it...I just let it warm up first....
Old Nov 20, 2009 | 07:06 PM
  #35
neofreak's Avatar
I've been doing this for the past ten years. FC, FD, RX-8.
Blip and shut off, no need for ten seconds.
Old Nov 20, 2009 | 07:21 PM
  #36
8upbad's Avatar
Jared
^^ agreed. I have only had a rotary for a few months but reving for 10 seconds seem like 9 seconds of overkill.
Old Nov 21, 2009 | 12:58 AM
  #37
ASH8's Avatar
Super Moderator
Like...idling your car for 2 minutes before you turn it OFF after a long drive/use...thinking you are "cooling" it down when in fact you are only heating it up more!
Old Nov 21, 2009 | 04:16 AM
  #38
@!!narotordo's Avatar
FLAME ON!
NO. Last time I did that I flooded my 8. And it was not a short drive and it was not cold. I let the car warm up. Did a 20min run then reved up to 4k rpms and shut if off. Next day car would not start. Geeez. Stupid *** at the dealer told me I drove it for a short distance lol what ever. Lesson learned.
Old Nov 21, 2009 | 04:18 AM
  #39
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
Lol I just rev to 3k and wait for it to go back to idle. No problem since I've owned my 8. I also like to hear my intake before killing the engine. Plus people look at the nosie.
Old Nov 21, 2009 | 06:48 AM
  #40
8upbad's Avatar
Jared
Who said anything about reving when the engine is warm? From what I have read the problem is when you drive a short distance and then shut it off cold. The engine runs rich the first few minutes which is probably the reason it will flood. If you rev it up warm you are just making it run rich again.... The solution to this problem IMO is to simply let your car warm up and cool down if you have to say, move it out of the driveway. Sometimes I let it run for 5 minutes and then go back out and turn it off (this method doesn't work if you live in a rough neighborhood). I think some people here are mistaking basic rotary maintenance for having a turbo. If this was theway to go then everyone here would buy a turbo timer for n/a 8's..... stupid.
Old Nov 21, 2009 | 07:07 AM
  #41
Spin9k's Avatar
Momentum Keeps Me Going
The only thing reving the engine before turnoff does is, as soon as you turn the key off, fill the combustion chambes with unburnt gas at a higher rate than idling would. And as the ignition is off and with no spark, the unburnt fuel (gas) collects and washes the rotor housing walls, providing ample opportunity for flooding the next time the car is started.
Old Nov 21, 2009 | 08:03 AM
  #42
Bigbacon's Avatar
2006 WB AT
no.
Old Nov 21, 2009 | 08:53 AM
  #43
ARE-EX-8's Avatar
Rotary > Piston
WHat do you mean by "blip" ??
Old Nov 21, 2009 | 08:58 AM
  #44
04RX8man's Avatar
^blip as in "stab" the accelerator real quick up to 3k then shut it off don't hold the pedal in...
Old Nov 21, 2009 | 09:21 AM
  #45
ZumnRx8's Avatar
RX8 & RX7 owner
+1 happened to me for the first time two weeks ago.... never in 70k
Old Nov 21, 2009 | 10:21 AM
  #46
ken-x8's Avatar
Only if I've warmed it by idling rather than driving, per Mazda's "short trip" procedure.
Ken
Old Nov 23, 2009 | 04:03 PM
  #47
Pico's Avatar
It's Complicated
My 8 never moves until the temp gauge is pointing north and the car has been running for about 20 minutes (give or take). No need for a rev.
I also hate having to move the car for others then waiting for it to warm just to shut it off again.
Old Nov 23, 2009 | 04:12 PM
  #48
Gr8Bullet's Avatar
^ i hate that cuz my driveway is narrow and the other cars cant go around me. i have to sit in the car for like 10 mins.
Old Nov 23, 2009 | 04:38 PM
  #49
neofreak's Avatar
Drive it around the block and then rev when you shut down, you don't need to wait that long.
Old Nov 23, 2009 | 04:59 PM
  #50
Brettus's Avatar
Boosted Kiwi
never do it - never flooded in 5yrs of ownership .
The key to prevent flooding IMO is :
thrash the s**t out of it regularly
keep up your regular maintenence (especially spark plugs)
don't touch the throttle when starting
