5W30 Oil Don't Cut it, Engine Bearing Pics 58K S1 RX-8 from England.
Old Sep 28, 2009 | 10:34 AM
  #26
True.
Old Sep 28, 2009 | 10:35 AM
  #27
PhillipM's Avatar
As Rotarygod says, we're not coming out about the lighter oils because that offers no proof either way, you can guess at it if you like, but that's all.
We stripped our engine down last month for a check, ok, it's only done ~15,000 miles, but it's been in racing conditions - full throttle/high revs/high load and high temperatures.
Guess what?
It's gone back together with nothing but new seals.
Does that tell you fully synth 5-30 is the best stuff to use? No, it just tells you the engine's been looked after when cold, and given the wear patterns on most engines, premix seems to be a damn good idea...
Old Sep 28, 2009 | 10:46 AM
  #28
What 5-30 are you using Phillip?
Old Sep 28, 2009 | 10:49 AM
  #29
Originally Posted by slidey
Sorry nycgps i ment 12000mls,here in the uk most cars run extended service intervals for the fleet buyers, also our early RX8's came with colder plugs than the USA, we had an 8 for our leading plug rather than a 7, which i'm sure won't help against carbon build up, plus longer warm up times.
I premix and use bg44k to keep things clean and well lubed, i'm not one of those touchy brits though lol but i know where Ash is coming from.
Dave
whoa ! 12,000 MILES !!!!!!
Are you serious ?
Dang ! I mean, hmm yeah a "GOOD" Synthetic will be ok even at 15,000 miles (assume that your car is not abused in any way plus its driving in pretty clean condition), but a dino based juice ...
Old Sep 28, 2009 | 10:55 AM
  #30
PhillipM's Avatar
It was originally Millers XF Longlife due to some sponsorship on another car (free barrel!), but since that car got sold we've relatively recently switched to Silkolene Pro S, both full ester-synthetics.
It probably helps that we keep our oil temperatures down too, which stops the oil breaking down under the high temperature/load conditions it sustains through the bearings - our oil cooler is roughly 24"x12"....
Old Sep 28, 2009 | 11:06 AM
  #31
24"x12"
Holy crap. But I guess on a track car you don't have to worry about the oil getting too cool huh?
Old Sep 28, 2009 | 11:10 AM
  #32
PhillipM's Avatar
It's still sits at 95-100* even with the fans on when you've been going for a while on a hot day.
Old Sep 28, 2009 | 11:27 AM
  #33
whoa ! 24"x12 " ?!?!?!?!
Well you're racing so thats diff story ...
Old Sep 28, 2009 | 11:34 AM
  #34
TX
Wow. I am looking at installing an additional oil cooler as well. Not quite as big though
Old Sep 28, 2009 | 11:51 AM
  #35
MazdaIMS's Avatar
Mine is prolly having the same problem. i am thinking its my spark plugs, but mine is heating. Maybe the coolant is not reaching and its blocked somewhere along its line or somthing. Once it reaches normal operating temperature I have so much power loss, and lots lots of shaking. Hating my 8 rite now.
Old Sep 28, 2009 | 12:07 PM
  #36
bse50's Avatar
#50
Are you serious ?
I can confirm this as well.
Services are scheduled every 20.000km.
I do it every 3000km since i track my car, 20.000km is more than my transmission fluids change interval!
Wonder why so many engines fail here..
Old Sep 28, 2009 | 12:59 PM
  #37
DUDE ! DON'T YOU GET IT ?
FOLLOW MAZDA's GUIDELINE ! THEIR RECOMMENDATION IS BIBLE ! EVEN IT TELLS YOU TO CHANGE IT EVERY 50K MILES YOU STILL DO IT ! CUZ ACCORDING TO A JACKASS NAME rxrocks ! USE 5w20(or 5w30) ! DO EVERYTHING AT MAZDA DEALER ! NO NEED TO PREMIX ! WHO CARES IF YOU GOT BEARING WEAR DOWN TO COPPER ! MAZDA KNOWS BEST AND YOU JUST DO WHATEVER THEY SAY !
Old Sep 28, 2009 | 01:10 PM
  #38
bse50's Avatar
#50
Seriously, you made my day!
Old Sep 28, 2009 | 01:30 PM
  #39
but seriously, Mazda Italy (or whatever its called) must be smoking crack to have such requirements.
  #40
ken-x8's Avatar
...Wonder why so many engines fail here..
Probably excess carbon buildup from premix and from synthetic oil that does not burn completely. Together with running oil that's too thick and impairs cooling.
Or maybe it's something else. It could be random failures from poor assembly. These engines are assembled by hand, aren't they? And I get the impression that it takes some skill to do it right. For a while someone who worked in Mazda's Virginia rebuilding facility posted here. He bragged about having assembled an engine in 22 minutes. If that's also the way they work on new engines in the factory, no wonder there are failures.
Ken
Old Sep 28, 2009 | 01:31 PM
  #41
Ken
you didnt see the "change oil every 20Km" part didnt u ?
Old Sep 28, 2009 | 01:38 PM
  #42
kennyfrc1's Avatar
it's good to see info like this but again i think we are simplifying things. Not all oils are equal. But maybe looking at specific data on the "higher end" heavy synthetics? I mean does a good 0w-40 hold its thickness as well as a average 15w40?
no.
Old Sep 28, 2009 | 01:43 PM
  #43
bse50's Avatar
#50
I can tell you horror stories via pm if you wish
Ken
There's a video online on how they assemble engines in japan. That tells you a lot, don't know if it is the same there in the usa.
Excess of carbon buildup from premix and synth that doesn't burn? If you pick up the right synthetic it will burn way better and with way less residues than a mineral one! Also the premix helps working as a solvent... If you tear an engine apart you will see that in the area where the oil nozzles lubricate the rotor there's close to no carbon. Anyway they all use mazda's 5w30 dexelia here, i run 10w40 royal purple since my car never sees temperatures below 16°C in the garage.
Guess so, the problem is that they replace the plugs every 60\80.000kms for 220€+labor. Considering that we have a lot of traffic you can think about how they usually are!
Old Sep 28, 2009 | 01:45 PM
  #44
kennyfrc1's Avatar
Ken
Fail.
Old Sep 28, 2009 | 02:08 PM
  #45
Wankel_Rotor's Avatar
thats it. I was changing my oil every 1000 miles, which came up to a monthly oil change. Now its gunna be a weakly oil change for me!! lol.
Old Sep 28, 2009 | 02:30 PM
  #46
tell me about it
those workers in Mazda's plant has been buliding nothinb but rotary for their whole life. So I guess their skill should be at least equal if not better than most techs out there. (in terms of engine building of course)
Premix does not leave residue ... in fact most oil wont ... try to get a gallon of gasoline and burn it ... you probably see more ash there than burning a quart of engine oil.
wow ! these plugs look like crap at 25K miles ...
no wonder engine fails over there ...
Old Sep 28, 2009 | 02:35 PM
  #47
bse50's Avatar
#50
Especially when they forget to do the pcm reflashes... close to no oil being injected in everyday use
Old Sep 28, 2009 | 02:39 PM
  #48
JinDesu's Avatar
went back to srsly broke
I hope you are joking about the 1000 mile oil change like the rest of the statement.
Old Sep 28, 2009 | 02:42 PM
  #49
why stopping him ?
we need people to stimulus the economy u know ?
Old Sep 28, 2009 | 03:15 PM
  #50
ASH8's Avatar
Super Moderator
Did this guy check up the OMP as well? this could explain the housing wear but what about the bearings?
Pretty sure the MOP was working as it should otherwise we would see same markings (gouges) at the sides of the rotor housings, no or little oil makes it to the middle.
Carbon build up has been an issue for every rotary ever built that is used for domestic driving in all regions.
Every higher mileage RENESIS 1 engines I have seen on the net has had this same bearing wear, and yeah I agree it is not normal.
