Please help potential new owner with question - MIAC?
Old Nov 2, 2009 | 11:40 PM
  #26
fyrstormer's Avatar
2009 RX-8 Touring
Weird noises aside, I really do love the sound of this engine.
Old Nov 10, 2009 | 07:46 AM
  #27
EC8's Avatar
EC8
'09 Sport Newbie
MIAC with slight hesitation?
When you had MIAC, was there a slight loss of power or hesitation when you heard it? I read through some other posts and almost all talk about the sound. My '09 makes this noise in 2nd gear at around 7800+, very smooth acceleration up to then, and then at the same time the noise starts the acceleration slows a little, feel a little hesitation. Still winds out and redlines quickly, but definitely a slight hesitation that you feel when the MIAC starts. Is that normal and will be fixed by the coolant restrictor valve? Use only good gas, 700 miles on the car, sport 6spd '09. Thanks.
Old Nov 10, 2009 | 12:52 PM
  #28
Old Rotor's Avatar
Are you using prem-gas? Please give us the history on your car.
Old Nov 11, 2009 | 06:29 AM
  #29
EC8's Avatar
EC8
'09 Sport Newbie
Only 91 or 93 octane gas. Did a little more "research" driving the car around last nite and accelerating slowly or at least slower up to 9000rpm. The sound definitely starts around 6200rpm and after listening to the youtube video of MIAC, I definitely attribute the sound to that, and will get the coolant restrictor valve in the near future. Under mild acceleration there is no hesitation around 8k. Under WOT I didn't perceive the sound until closer to 8k but now am pretty sure it starts earlier, just couldn't hear it quick enough or link it to the right rpm. Under WOT I definitely get a slight hesitation/hiccup in power right around 8k. Nothing major and it still hits 9k very quickly after that, just going from 7900 - 8100 is not as smooth as 1k-8k or 8100-9k. Speaking with Lane over PM it sounds like he notices the same slight hesitation/power burp right around 8k as well, but only under full throttle.
Summary: My sound starts earlier than I thought, most likely coolant restrictor valve, but both '09s (mine and Lane's) seem to exhibit a slight power hiccup under full acceleration at 8k
Old Nov 11, 2009 | 01:27 PM
  #30
Old Rotor's Avatar
You don't sound like you have the MIAC detonation problem. The MIAC is loud followed by a loss of power and is very bad on the engine. It sounds like you might have the water restriction sound that some complain about. This restriction does not cause the hesitation you notice. Some on here have got Mazda to fix this water restriction sound.
Old Nov 16, 2009 | 08:22 AM
  #31
EC8's Avatar
EC8
'09 Sport Newbie
Part # ???
Sounds like several people have had this issue, and several have had it fixed by Mazda with the installation of a "coolant restrictor valve". Could someone please do a little more digging and check their receipt or even call the dealer that fixed their car and get a Part # of what was installed?
My dealer is willing to install the part/make the fix but can't find the part number or find a listing for the restrictor valve and has found nothing to order. As he put it, help me help him please.
Old Nov 16, 2009 | 01:57 PM
  #32
shallowater's Avatar
Originally Posted by Lane03
I test drove both the R3 and the Sport RX-8 yesterday, and even took one home for an extended test-drive over the weekend. On both cars I heard a pretty noticeable rattling noise when I have the engine above 6k rpms (in any gear). It sounds like the noise is coming from behind the glove box. I have since read that this noise is often described as MIAC (marbles in a can). Today I drove two other RX-8's at a different dealership and I didn't notice this noise in either car. I have since ran my loaner to empty and filled up with premium (in case it was a fuel issue), but the noise remains. The video below shows the sound I am referring to. How common is this noise in RX-8s? Is this something any owner should expect to hear? I really enjoy the car otherwise and would probably purchase it, but this noise is rather annoying if it is something that will always be there. Thanks in advance for the help.
Sound clip/video of problem: http://www.youtube.com/watch?v=bm3NcgTnmRk
Cause of problem: Too much coolant flow at high RPM
Solution: Have Mazda install coolant restrictor valve
(thanks to Trubach and RX8pwnage for the fix)
my car developed this exact problem since last week, time to call mazda dealer...again.
one question though, why there is no such problem before and suddenly it just came out of no where? if it is caused by too much coolant flow at high RPM, does it mean there is something wrong with the coolant (reservoir/sensor etc.) as well (since the rattle did not happen before)?
Old Nov 16, 2009 | 02:47 PM
  #33
Lane03's Avatar
2009 RX-8 Sport MT
Updated first post with P/N...
Old Nov 16, 2009 | 03:20 PM
  #34
Mazurfer's Avatar
Surf Hard, Drive Hard
Lane..............the only thing I can find under that part number "F10061E09" is
ORIFICE, HEATER HOSE DIESEL
You confident about that number? Guess it could've changed or maybe this is something that secret and not widley known???????
Old Nov 16, 2009 | 04:03 PM
  #35
EC8's Avatar
EC8
'09 Sport Newbie
P/n
Thanks Lane,
Got a call into my local dealer to check on that P/N. Hopefully he'll come up with the same restrictor valve that was installed on your car. I'll update when I hear back from them.
Thanks again for the extra legwork
Old Nov 16, 2009 | 11:50 PM
  #36
Lane03's Avatar
2009 RX-8 Sport MT
That's the number I was given over the phone. I will be getting my oil changed next month, at which I will try to get a print out of what was done. If that number is for a hose, perhaps they just replace the coolant hose with a smaller ID hose to restrict the coolant flow???
Old Nov 17, 2009 | 07:11 AM
  #37
Mazurfer's Avatar
That's what I'm thinking. The only thing I could find under that number was for like an 02 Mazda 6 and it did look like a small hose coupler actually. I'll see if I can find the picture of what I came up with.
Here it is:
Top lefthand dashed area.................F10061e09
http://www.avtopartmaster.com/ru/?ac...E9%20%E3%EE%E4
Old Nov 17, 2009 | 07:28 AM
  #38
EC8's Avatar
EC8
'09 Sport Newbie
Orifice Heater Hose
Talking with Trubach over PM, he confirmed this and also gave me a Mazda Techline Case number:
Techline Case # 613795 (I think thats a Mazda thing telling the techs what to do)
The part is F100-61-E09 Orifice, Heater Hose
Spoke with my dealer this morning and he said they can look up the case number and will help them with the fix.
Thanks Lane and Trubach/Gary
UPDATE: My dealer can't open up another dealer's case number, but has ordered the part anyway. Said he could order it 2 different ways, one with the hose, and just the orifice, he has ordered just the orifice because based on the replies above, that should be the only part needed.
Old Nov 18, 2009 | 01:58 PM
  #39
Lane03's Avatar
2009 RX-8 Sport MT
This really should be a sticky or in the FAQ...
Old Nov 18, 2009 | 03:19 PM
  #40
Mazurfer's Avatar
Once proven on a few more cars....then I would agree.
Old Nov 25, 2009 | 09:44 AM
  #41
EC8's Avatar
EC8
'09 Sport Newbie
Another confirmed fix
Brought my '09 into the dealer today to have the "orifice heater hose" installed that he ordered last week. This fixed my problem as well! Thanks for those supplying the part numbers.
Old Nov 25, 2009 | 11:39 AM
  #42
MikeBusch2's Avatar
Anyone have pictures of where this orifice goes? I'd like to order this part and install myself if at all possible.
Thanks.
Old Nov 25, 2009 | 12:06 PM
  #43
Suspension's Avatar
I hear the coolant cavitation noise (what you guys call MIAC) in my '09 R3 at higher RPMs. I brought it up to the service manager and he said "That's normal." BS. Did this ever happen on '04-08' RX-8s? Is there a TSB?
Old Nov 25, 2009 | 01:52 PM
  #44
there is no TSB.
i brought the car to dealer today and described the problem, i even printed out this thread to show him. no go. dealership says that is normal since there is no TSB. also said that they cannot do it just because some internet forum (that is here) posts this as a problem...oh well. spent 10 mins arguing and told him it is just a simple fix. no use, the dealership won't budge...
it is thanksgiving eve and i don't have time to waste there, asked him to document the problem so that it is in the record that i brought this up...maybe i will call mazda later...is this a known problem to mazda? i have had enough BS from the dealer already.
Old Nov 25, 2009 | 01:55 PM
  #45
ASH8's Avatar
Super Moderator
News For ALL 2005-2010 ~ Owners...
Now I can't speak for your LHD Cars, but, it appears Mazda did not put these "orifice's" in ANY 05-2010 RX-8's..
I just checked the part number in my RHD Parts Catalog and this orifice was Originally Used in the Series 1 RX-8, UP TO December 1st, 2004 production....
Mazda then Stopped Installing them from Dec 1st 2004.
Here is a Parts pic of exactly where it goes (in RHD S1), it is actually in the engine bay by the Thermostat outlet that supplies coolant to your Heater.
Attached Thumbnails Please help potential new owner with question - MIAC?-orifice.jpg
Old Nov 25, 2009 | 02:10 PM
  #46
ASH8's Avatar
Super Moderator
Here it is:
My EPC (RHD) says it is used in S1 RX-8, FD RX-7, 07 Mazda 2 Diesel, 02-07 Mazda 6 Diesel...in the heater hose areas.
Old Nov 25, 2009 | 02:17 PM
  #47
EC8's Avatar
EC8
'09 Sport Newbie
Installation notes
I'm not sure exactly how it was done, but this is the write-up on my service invoice:
R&R battery, drain coolant at block to gain access, removed smaller size thermostat hose to firewall and install orifice in hose, replaced coolant.
Probably doesn't help a ton, but that's what I got.
This sounds definitely like a dealer problem for "Suspension" and "Shallowater". My dealer had never heard of this before and I told him my car was having this problem, here's a printout of what I found on the internet, the RX8 forum is actually linked through MyMazda so at least there's some connection. He couldn't find the original "restrictor" part and then I called him with the part number. They were extremely accommodating and never paused about whether to fix it or not. Other's have suggested you/they drive other '09s on the lot and see if they hear the problem, if not then it's obviously not normal. And just because there is no TSB is no reason why it's not a problem... Good luck with them, or take it to another dealer. I've heard others contacting Mazda NA and getting resolution that way. Good luck
Old Nov 25, 2009 | 08:20 PM
  #48
ASH8's Avatar
Super Moderator
Yep, your service Invoice is correct, and the "orifice" is installed inside the Heater Hose that supplies Coolant to and inside under dash Heater Core (Radiator), see parts pic above (red) that is the small orifice that your dealer fitted.
The Hose "end" in question slides onto the metal Outlet on the Thermostat Housing near the bulk head or firewall.
As I said the Initial 30,000 03-04 RX-8's had them factory installed, AFTER Dec 1st 2004, they ceased to put the orifice in ANY RX-8's.
At this stage it is not a TSB because Mazda are only rectifying cars in which owners complain about....
Old Nov 25, 2009 | 11:02 PM
  #49
ASH8's Avatar
Super Moderator
Originally Posted by shallowater
there is no TSB.
Yes, I would call MNAO for sure...
There is NO Difference to the Heater Cores or Hoses/Pipes between Series 1&2 RX-8's, or the bits that matter.
This is another one of those "sneaky" repair jobs that Mazda Distribution don't tell the dealers (via TSB) unless the Dealer Calls Mazda NAO, or they get a customer complaint.
There have been many of these done in the US, so your dealer needs to BONE UP or GET OUT!
Old Nov 26, 2009 | 07:42 AM
  #50
Mazurfer's Avatar
Yeah, I checked all my diagram files and parts lists and don't see it anywhere. Originally when that part was talked about in this thread, I googled it and the only place I found it was on some Euro site and said it was for a Mazda6.
This is good to know for those that really suffer from MIAC as it appears as if this is going to cure it.
I can't see any real long term effects can you?
