Engine Dyno testing of Renesis
Old Aug 14, 2006 | 08:55 AM
  #326
Red Devil's Avatar
You're about 3 years too late on asking that question.
Old Aug 16, 2006 | 04:33 AM
  #327
AgedFreak's Avatar
AgedFreak
Thanks for your RESPONSE.
Old Aug 16, 2006 | 07:51 AM
  #328
Hymee's Avatar
Race Steward
The answer to the question is that the engines are the same. 4 ports are 4-ports, and 6-ports are 6-ports. It is just the advertised power measurements have "changed".
Cheers,
Hymee.
Old Aug 23, 2006 | 03:36 AM
  #329
Rasputin's Avatar
Originally Posted by Wildcard
... Understanding and controlling the ECU seems to be the key to reliable performance. ...
This is one of the wisest and truest remark I've read on this forum.
Old Aug 23, 2006 | 04:29 AM
  #330
juanjux's Avatar
I recently did a 3200km road trip, mostly in remote parts of Australia, so I had plently of opportunity to look at the top speed of my RX-8 under different conditions. Here is what I learned:
Over time the long term fuel trim (LTFT) in my car seems to gradually creep up. It was at 11% at the start of this trip. The result was that above (160km/h) 100mph, AFR's were pig-rich (<0.75). This not only effected fuel economy, but also max speed. Under this condition, I only got a max speed of 205km/h. Running that rich must really kill the power.
Seeing this, I reset the ECU by disconnecting the battery, and immediately my AFR's leaned out by 10%. My top speed also increased to 216km/h. As the trip progressed, I found that the LTFT would stay at 0 for about 3 hours max, and then it would start increasing gradually - first 2%, then 5% etc. This also resulted in the AFR's becoming richer and economy getting worse. In all I reset my ECU 3 or 4 times during the trip to reset the LTFT back to zero.
Note that these AFR problems only seem to be an issue in Closed Loop. I have found that the cruising speed needed to be in closed loop varies - anywhere from 130km/h to 160km/h. So most people aren't going to encounter this LTFT problem at all. Unless you are trying for max speed. I have no idea what criteria the ECU uses to adjust LTFT.
The second thing about top speed is that I think wind direction and speed make an pretty big difference. On this drive, I had headwinds all the way, and the fastest my car ever got to was 220km/h. 6 months ago in exactly the same configuration, it got 240km/h with a slight tail wind.
Sorry for replying this late, I've seen this message now. 206 kms/h & 216 kms/h max speed? That really sucks, my car can get to 220 kms/h in very few time, and with a long enought straight and a little patience, to 245-250 kms/h. Not bragging here, I can make a video about the 220kms/h thing starting from 140 kms/h to 220 kms/h (the 250 kms/h thing I would prefer not because it's a little scary )
You must have something broken, maybe the new recall problem? maybe the cat?
Old Aug 25, 2006 | 04:54 PM
  #331
Hymee's Avatar
Race Steward
220 was into a head wind (i.e. doing it tough).
240 is his best, with documented evidence
Cheers,
Hymee.
Old Sep 1, 2006 | 02:08 PM
  #332
Raptor75's Avatar
Hymee,
Do you plan on putting this engine back into a RX and dynoing it at the wheels or have you already done this and I just missed it? Do you plan on testing a second engine to see if there is discrepancies. One engine test is not a good representation of all rotary engines.
Please don't take this wrong, I really like what you're doing and hope you can capture even more data on this engine. It's nice to see real data that is documented.
Old Sep 1, 2006 | 04:31 PM
  #333
Hymee's Avatar
Race Steward
Thanks Raptor.
No plans to test multiple engines to see if there is such discrepencies. I would think (cough, "hope") that there would not be much physical discrepencies between fairly precision made components that would equate to more than a couple of HP, if that. It ain't like the parts are made in the back-yard or anything
The aim is to baseline with this engine, then test power enhancements against a stable baseline.
Cheers,
Hymee.
Old Nov 9, 2006 | 12:52 AM
  #334
pianoman's Avatar
Any updates on this front?
Old Jan 8, 2007 | 04:11 PM
  #335
jird20's Avatar
Mad for a Furai
Two full months with no news about this topic!!!
anything to say Hymee?
Cheers
jird20
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
uZu
Dec 30, 2015 12:35 PM
dbarber
Jul 25, 2015 01:34 PM
Bamaham
Jul 23, 2015 08:08 AM
