DIY: Side-marker "Clear Corner Lights" Installation
Rating: Thread Rating: 4 votes, 4.75 average.
Old Jan 9, 2010 | 05:34 PM
  #326
RotaryP7's Avatar
Seriously.. FML..
Originally Posted by HWK11
L shaped needle nose pliers work fine
I have regular nose pliers.. What do you mean L shaped?
Old Jan 9, 2010 | 05:36 PM
  #327
HWK11's Avatar
Lighting Yellow
like its bent in the middle. im not sure of the correct name but i used those
Old Jan 10, 2010 | 07:07 AM
  #328
Huey52's Avatar
Registered Zoom Zoomer
These: http://www.harborfreight.com/cpi/cta...emnumber=33202
Also very useful when installing an AFE short shifter.
Old Jan 10, 2010 | 07:40 PM
  #329
RotaryP7's Avatar
Seriously.. FML..
Oh ok thanks.
btw, do I use them to release the reflector? I've tried using a screw driver, it loosened the reflector but it's not out yet. It's stuck. lol.. God, I'm a noob.
Old Jan 10, 2010 | 07:47 PM
  #330
HWK11's Avatar
Lighting Yellow
oh.. like deform them with the pliers and then pull the reflectors out. that should be easier
Old Jan 10, 2010 | 08:11 PM
  #331
RotaryP7's Avatar
Seriously.. FML..
Yea.. I need those pliers first.
Old Feb 6, 2010 | 01:17 PM
  #332
RotaryP7's Avatar
Seriously.. FML..
After almost a month, I finally took out that reflector piece.. lol..
Old Feb 6, 2010 | 02:22 PM
  #333
RotaryP7's Avatar
Seriously.. FML..
After buying the clear corners in 2008. I just installed them. I've been lazy.. The DIY was amazing.
Old Apr 5, 2010 | 09:08 PM
  #334
Bullitt's Avatar
In the pipe five by five.
Beautiful.
Old Jun 2, 2010 | 01:38 AM
  #335
djfa's Avatar
Great DIY. I started at 1 in the morning and finished in 15 mins. Although I decided to do my foglights replacement bulb after that since i was already in that area.
Old Jun 29, 2010 | 01:54 PM
  #336
nx04's Avatar
zoom-zoom
subscribed lol
Old Jul 19, 2010 | 09:40 AM
  #337
phrenetiK's Avatar
PHREN PHUN!!
Why is putting in amber bulbs needed? These side markers are running lights and not turn markers so being white is fine?
Old Jul 19, 2010 | 12:51 PM
  #338
Aipex8's Avatar
X e p i A
Technically, a car needs to have both an amber side marker AND an amber side reflector at the front (to meet US regulations). The stock side marker is both light and reflector. But most people run the side marker with a white bulb (LED most of the time) and have no problems.
Old Aug 8, 2010 | 03:54 PM
  #339
Grog's Avatar
Just want to say thank you for the guide. I used it to install my JDM clear corners, and they look a lot better than I thought they would! For some reason beyond me, my car already had clear bulbs in it so I don't have that yellowish tint in them, either. I'm pretty satisfied.
But anyway, yeah, thanks for the guide! It was all very simple, but I wouldn't have felt comfortable doing it without this.
Old Aug 20, 2010 | 10:31 AM
  #340
Rotary-RX8's Avatar
Girls who drive stick FTW
Sorry quick question. My corners came with bulbs inside which means i only have to disconnect the old bulbs and connect to the new ones that came with it. Do i need to disconnect my battery to do the swap ?? Quick answers please im doing this right now
Old Aug 20, 2010 | 10:49 AM
  #341
msrecant's Avatar
Hubble has been saved!
You do not need to disconnect the battery to switch the light bulbs (see picture in post #9 in this thread).
If what you mean is that your corners included a bulb socket, you can simply remove the new sockets and discard them and then use the existing socket installed on your car. You will still want to switch to the amber bulb.
Old Aug 20, 2010 | 10:54 AM
  #342
Rotary-RX8's Avatar
Yea thats what i meant SOCKETS !!! They came with an amber bulb and sockets. So just switch the sockets ?? kk Thanks
Old Aug 20, 2010 | 11:08 AM
  #343
msrecant's Avatar
Yes, Just move the new bulbs to the old sockets and plug the old sockets into the new clear corners.
  #344
Rotary-RX8's Avatar
Im having a tough time removing the old socket !! Do i just pull them out ? Are there any tabs ? Help please
Old Aug 20, 2010 | 11:19 AM
  #345
Rotary-RX8's Avatar
bump .. left my stuff outside unattended
Old Aug 20, 2010 | 11:27 AM
  #346
msrecant's Avatar
If I remember correctly, you turn the socket counter clockwise about 1/4 turn and it should then come straight out.
Old Aug 20, 2010 | 11:28 AM
  #347
Rotary-RX8's Avatar
KK thanks !!Ill try it. But i doubt itll work cause the housing fits liek 100 percent
Old Aug 20, 2010 | 11:54 AM
  #348
Rotary-RX8's Avatar
I used the old sockets. I just swapped the bulbs. So i didnt have to remove the old sockets.
Old Dec 22, 2011 | 10:48 AM
  #349
jhkuse's Avatar
Great DIY!! props to you man
Old Feb 7, 2012 | 07:43 AM
  #350
don_peppino24's Avatar
The Don
Nice DIY, i just ordered my corners fro ICBMOTORSPORTS http://WWW.ICBMOTORSPORT.COM/marxclcolema.html $64.97 or $72.96 with bulbs so for sure i will refer to this DIY when installing mine.
happy dance!
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
