5W30 Oil Don't Cut it, Engine Bearing Pics 58K S1 RX-8 from England.
Old Oct 21, 2009 | 01:24 AM
  #251
all wrong ...
Old Oct 21, 2009 | 01:32 AM
  #252
ASH8's Avatar
Super Moderator
Originally Posted by TeamRX8
all wrong ...
What do you think then, instead of simple one liners...
Old Oct 21, 2009 | 07:03 AM
  #253
kennyfrc1's Avatar
It amazes me that people refuse to accept that 40-50W is needed to properly protect the bearings in this engine despite the overwhelming evidence to prove it.
Bearings are protected by Hydrodynamic film strength UP UNTIL the oil is squeezed out due to load. Then you better have sufficent ZDDP.
Since engines and oil were invented this scenario remains constant.
Old Oct 21, 2009 | 08:47 AM
  #254
*shurgs*
people so afraid of using 20w50 ... They just have to find 32408124071830579159 excuses to NOT to use it ...
Old Oct 21, 2009 | 09:16 AM
  #255
Shijin-Kun's Avatar
Rotary Power!
my oil change is coming up this weekend ill try out 20w50. Should i use regular oil like castrol gtx or synthetic like royal purple or mobile 1.
Old Oct 21, 2009 | 09:26 AM
  #256
adamwzl's Avatar
<3's Bunnies
What oil were you using before and how many miles are currently on your vehicle?
Old Oct 21, 2009 | 09:33 AM
  #257
Shijin-Kun's Avatar
Rotary Power!
this is the first oil change since i bought the car (the guy who i bought it from takes it to a shop to get the oil changed), the guy would use 5w20 castrol gtx. The car has abobut 80k miles on it.
Old Oct 21, 2009 | 09:36 AM
  #258
GeorgeH's Avatar
it has nothing to do with oil weight, you're all so far off base you might as well be pitching tents on the moon
LOL!:yelro tflm
I'm drunk and in China right now (10:30 at night) and this just made me laugh. Thnks.
Old Oct 21, 2009 | 09:40 AM
  #259
adamwzl's Avatar
<3's Bunnies
Then stay with conventional oil Castrol gtx, and try out 20w50. Do not switch to synth as it might cause issues with the seals since the engine has a good number of miles on it already.
Old Oct 21, 2009 | 09:43 AM
  #260
Shijin-Kun's Avatar
Rotary Power!
thanks for the tip, great help.
Old Oct 21, 2009 | 09:48 AM
  #261
madcows's Avatar
From my understanding, this has only been an issue a long time ago with certain synthetics interacting with certain materials that made up the engine seals. The user should be fine with whateverW-40 or 50 oil. I would suggested an group IV or V synthetics.
Old Oct 21, 2009 | 09:50 AM
  #262
adamwzl's Avatar
<3's Bunnies
yeah no problem. Since your engine has been running for a long time with conventional you probably have some sort of resdue from the oil along the seals. If you were to switch to a fully synthetic oil, after a couple thousands miles the resdue on the seals would be cleaned off then causing the wear and tear from the seals before to show and get worse.
So its better to just stick with the same type of oil at such a high mileage. If you were below 20k then switching to synthetic would have been ok as the wear and tear hasn't progressed yet.
  #263
madcows's Avatar
I've been satisfied with the Valvoline VR-1 non-synthetic 20W-50 oil which has a high ZDDP content.. It's also relatively cheap, and can be found at most auto parts stores.
Old Oct 21, 2009 | 01:31 PM
  #264
Nubo's Avatar
Lubricious
all wrong ...
Man of Mystery!
Old Oct 21, 2009 | 02:19 PM
  #265
ASH8's Avatar
Super Moderator
Originally Posted by nycgps
*shurgs*
I am not...I have been using 15W40 since day one in my 09...well since day 61 when I changed the Oil.
My Mazda owners manual says I can use it, did you know it also says I can use a 20W50..
Old Oct 21, 2009 | 02:45 PM
  #266
madcows's Avatar
I wonder if they only recommend it now since the S2 has the larger pump, and higher pressure regulator. May I propose a toast? Long live the S2 renesis!
Old Oct 21, 2009 | 02:57 PM
  #267
kster's Avatar
Well for 09s here in the US, they still only recommend 5w20.
Old Oct 21, 2009 | 03:07 PM
  #268
plain ole wanker's Avatar
wankel my wanker
That's because we get the magical rotary here
Old Oct 21, 2009 | 05:54 PM
  #269
TZ250's Avatar
Would that be the magical exploding rotary?
Old Oct 21, 2009 | 11:39 PM
  #270
madcows's Avatar
Maybe reduced engine life is totally worth the extra .1 MPG
Old Oct 21, 2009 | 11:58 PM
  #271
Service people deal with the symptoms, the symptoms rarely mirror the cause but are rather the end result of the cause
I don't have an "opinion"
buh-bye
Old Oct 22, 2009 | 12:23 AM
  #272
TZ250's Avatar
I thought I saw a post saying the Aussie oil spec was 0w-30 dino. Could you post a scan of the oil spec page from your owner's manual?
Old Oct 22, 2009 | 12:32 AM
  #273
*sigh*
Mazda USA used to list a chart out ... but I guess the US customers are too dumb to decide what they need so ... yeah just push a "we recommended this oil, cuz it gives us best cafe numbers, " and call it a day, it lowers support cost so yeah, thats it
S1 has the same chart.
Old Oct 22, 2009 | 12:33 AM
  #274
Mazda needs every single drop of mpg they can get !
remember, Rotary is a very thirsty engine !
Old Oct 22, 2009 | 12:34 AM
  #275
*sigh*
can you like ... argh ...
