DIY: Spark Plug change.......
Old Sep 9, 2009 | 01:33 AM
  #226
Jasonvaldez's Avatar
did mine the other day really easy Thanks!
Old Sep 9, 2009 | 06:43 AM
  #227
cliffkemp's Avatar
Originally Posted by ASH8
I am forming the opinion that Coils should be changed at every other spark plug change.
And about 15,000 Miles is enough for the Spark Plugs, even though "Mazda" says you can go a lot further..yes, you can, but how efficient is the spark, from that how complete is your Fuel Igniting.
Much also depends on your type of driving and RPM's, even weather.
Unless you are running lots of boost (even that is debatable) the stock coils are just fine. Its the connections you need to check. The plugs should be changed often, yes. The coils are good for a while. Make sure you have a good connection between the coil/wire, wire/plug. If the connection is loose, even just a little bit, will cause the coils to want to overheat and the spark will not be as consistant on top end. You should dyno your car often to see how it is performing and check the connection of the plug wires to the coils and sparkplug end too. I am going to find out what we use at work to make good connections to our annealers and let you all know so you can use it, its some kind of paste similar to silicon. Will keep you posted.
Old Nov 8, 2009 | 06:26 PM
  #228
BReal-10EC's Avatar
Wow- you guys aren't kidding about replacing the spark plugs often. I just changed the original plugs on my 04 RX8- with 33.5k miles. Wow- they are worn/fouled- though mine seem "oilier" than the OPs. The car runs so much better now.
Attached Thumbnails DIY: Spark Plug change.......-rx8fouledplugs.jpg
Old Dec 16, 2009 | 08:49 AM
  #229
mannerofspeakin's Avatar
Originally Posted by Spoolin8
If you scroll down they also have a packaged deal that includes 1 leading, 1 trailing and a pack of NGK ZE81 spark plug wires for 59.00 so thats roughly 120$ for a set of plugs and wires.
You only need one set of wires. So actual cost is $92 for 4 spark plugs and 1 wire set. Awesome deal. Wish Amazon sold the ignition coils too.
Old Dec 28, 2009 | 04:25 PM
  #230
77mjd's Avatar
Autozone must have screwed up the order I made for the plugs because I ordered 2 leading and 2 trailing and received a box which contained 4 individually boxed leading plugs and another box with 4 individually boxed trailing plugs. 8 plugs total for for 84.99.
Attached Thumbnails DIY: Spark Plug change.......-005.jpg   DIY: Spark Plug change.......-006.jpg
Old Dec 28, 2009 | 07:58 PM
  #231
Pico's Avatar
It's Complicated
^ Yeah they messed that order up.
Nice x-mas gift
Old Dec 28, 2009 | 08:29 PM
  #232
77mjd's Avatar
Nice x-mas gift
Yup...Merry Christmas to me! Maybe I should try my luck ordering some coils from there too. 2-for-1's on those would be really good.
Old Jan 5, 2010 | 12:30 PM
  #233
bejackso's Avatar
doing all 4 of mine tonight. i bought the car with approx 42.5k mi on it, now it has approx 57.5k mi. i have never changed the plugs, and to my knowledge they've never been changed in the past. so we could be dealing with 4 stock plugs with 57.5k mi on them. regardless, will post pics when done.
Old Jan 9, 2010 | 12:23 PM
  #234
Taz Ismail's Avatar
TAZ
Very nicely explained tony.
I wanted to ask that will the car display CEL light if there is a foulty spark plug??
Old Jan 14, 2010 | 06:06 PM
  #235
ksanders8706's Avatar
Hey, guys. I've read most of this thread and have a few questions. Is it recommended to change the ignition coils along with the wires and plugs? Which vendors currently offer the better prices on OEM parts? I'm sure I'll order the plugs from sparkplugs.com, so are the twenty-some dollar plugs sufficient, or are the racing class plugs recommended? I noticed the wireset from sparkplugs.com is much cheaper than finish line performance. Are they the same? Which vendors do you guys recommend for the coils? Finish Line Performance has them at thirty-five dollars each. I've heard people talking about one hundred dollar four-packs, but am not sure.
Also, using the wheel removal method, how long from start to finish is expected for someone with moderate mechanical skills and understanding? Don't wanna run out of daylight!
Old Jan 14, 2010 | 09:14 PM
  #236
Rote8's Avatar
I needs plugs.
My car is the spark plug zombie...
Old Jan 15, 2010 | 03:18 AM
  #237
djfa's Avatar
there is a store on ebay selling NGK laser iridium plugs, NGK wires and 4 latest version coils for 375$. I bought it right away and installed myself. My baby feels fresh.
You can change plugs without changing the rest. Your wires and coils will probably last longer than your plugs but i wouldnt go more than 25k with them before i change
Old Jan 15, 2010 | 01:07 PM
  #238
VTR_RX8's Avatar
I have changed the plugs; miss-firing gone!!!
however, when it is on drive and idling, it vibrates the car, kinda funny noise I hear coming from the front of the 8.
Suggestions?
Old Jan 15, 2010 | 04:23 PM
  #239
ndhoffma's Avatar
Are all the wires connected securely?
Old Jan 16, 2010 | 06:43 PM
  #240
rXter's Avatar
Ran into the same problem as kersh4u. First plug seems like its in there good. Even put a little cheater bar to get more leverage. Any one else find a solution to this problem?
Old Jan 16, 2010 | 07:45 PM
  #241
ASH8's Avatar
Super Moderator
Can happen, just make sure you put an anti-seize grease on the new spark plugs threads before install...will make it much easier to remove next time, and don't over-tighten.
Old Jan 17, 2010 | 11:02 PM
  #242
skrubol's Avatar
Use a bigger cheater bar is my suggestion. I think I needed an impact wrench to get one of mine out. Took all the threads from the block with it. Needed to helicoil mine. Hope yours isn't as bad.
Old Jan 25, 2010 | 02:02 PM
  #243
kwikslvr's Avatar
Rotary User
My 8 has 67k miles on it, and i bought it 2 years ago with 48k... sure that a tune up had been done. i figured it was getting close to needing one again, but just to make sure i called my stealership. they looked through the records and found that the car has never had a tune up, and still has the stock OG plugs, wires, and coils... WOW. it runs fine except for a little wait on the starting (or maybe ive never really experienced what this car can do), but im going to replace it all this week and we'll see how bad it is...
Old Jan 25, 2010 | 08:06 PM
  #244
uncleant's Avatar
Eat Sleep Drive
SAME THING JUST HAPPENED TO ME!!!! it was great! the guy at the counter was like its your lucky day they sent you eight plugs! SO GOOD! 8 plugs for 85 bucks hell yeah
Old Jan 26, 2010 | 08:53 PM
  #245
Just needing a little clarification. I ordered a new wire set, plug set, and a coil set. I understand the removal and installation of each, but I'm a little unsure of the average time? This week would be ideal to work on it, but it's going to get nasty by Thursday. When I get off work, it's almost dark out. Are we talking a half hour job? Hour? Three hour?
What are your experiences?
Old Jan 27, 2010 | 01:26 PM
  #246
uncleant's Avatar
Eat Sleep Drive
are the NGK plugs pre gaped?
Old Jan 27, 2010 | 01:50 PM
  #247
ASH8's Avatar
Super Moderator
Yes
Old Jan 27, 2010 | 03:12 PM
  #248
Huey52's Avatar
Registered Zoom Zoomer
All sparkplugs are gapped for their intended application, but a good idea to doublecheck them yourself.
Old Feb 11, 2010 | 12:52 AM
  #249
DougR's Avatar
Does anyone know of other working spark plug brands that I can use, its proving difficult to get NGK's in South Africa other than from the dealers and Im not willing to be bent over by them on pricing. I have heard that there are a Greddy version that can be used....anyone know the product code?
Old Feb 20, 2010 | 05:19 PM
  #250
the1jesster's Avatar
Trained true Killers
I have stumbled my way through most of the post's in this thread and still need to know what is the avg life span of our spark plugs mine are stock Mazda.
