Hydraulic e-brake (for Rear BBK's)
Old Jan 22, 2011 | 10:56 PM
Highway8's Avatar
Registered RX8 Nut
Originally Posted by TeamRX8
You dont really need a larger diameter rotor, which only adds cost and rotation mass with little-no benefit IMO. What we need is a lightweight aluminum e-brake caliper/mount to compliment the RacingBrake 2-pc OE size rotor.
I think I added 2-3 pounds per side compared to stock size with 2-piece racing brake rotors.
And yes you really do need larger diameter rear rotors if you install a front BBK. When I only had the front BBK I had more nose dive and my 60-0MPH braking distance increased over stock sized rotors, with the rear BBK my stopping distance was just a few feet shorter then stock style set up.
Now does anyone really need a BBK at all??? Simple answer is no. The stock brakes with good pads work great. We can loose some weight with 2-piece rotors and even more with the stock sized rotors and aluminum calipers up front.
I only went with the front and rear bbk because I was adding FI and front splitter (reduces air flow to brakes) and wanted to play it safe. Before FI and the splitter, I was getting front brake rotor temp readings of 1000deg in the hit pits.
Old Apr 27, 2012 | 12:27 AM
m4f1050's Avatar
I am doing a 20B swap on mine, going twin turbo, I think it's best to have good braking. For now I have been busy working and haven't had a chance to work on the car much. It's been from shop to shop, long story short, it's back on track (thank God.)
Old Apr 27, 2012 | 12:44 AM
Awesome bump.
Old May 5, 2012 | 12:38 AM
m4f1050's Avatar
Here is another teaser...
Digitz0070
Oct 7, 2015 12:43 PM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
