Shift Knob Specs
Old Sep 28, 2006 | 02:13 PM
PSUGreySreet's Avatar
Shift **** Specs... Please Help!!
I am looking to buy a replacement shift **** for my 8. The only thing I am a tad hesitant about is the fitting because I know some ***** fit some cars and some don't. Does anyone know if universal shift ***** fit 8?? The one I am looking at says 15 mm inner diameter, but I don't know where that is a measurement of?? If anyone could help or has an aftermarket **** that was universal... let me know.. Thanks!!
I did search for a while, looking in many "shift ****" and "specs" threads, but couldn't find what I was looking for.
Old Sep 28, 2006 | 03:09 PM
NgoRX8's Avatar
you need a 12.5 mm
Old Sep 28, 2006 | 03:13 PM
If adapters (those plastic things) come with the ****, then will it work?? or do i need a 12.5 mm straight and that's all?
Old Sep 28, 2006 | 03:36 PM
endolinz's Avatar
The adappters are usually pretty low quality. When you install them, the **** has the tendency to continually vibrate itself loose (not to the point of coming off in your hands, but enough to have an annoying rattle). I would try and spend a little extra money on one of the correctly sized 12.5 mm ***** for reliability.
Old Sep 28, 2006 | 05:22 PM
Romeo's Avatar
...I'm SOOO Off Topic
just my personal thought on the ****:
When I got my car, I thought the Triangular design of the **** was a bit odd and that it would feel uncomfortable while driving, but I later found out how comfortable it was. Its a real sexy looking ****. I personally wouldnt change it unless i HAD to. ... but thats just me.
-RomeO
Old Sep 28, 2006 | 06:05 PM
romycha1's Avatar
I would stay away from those universal fitting ones. Even though they have different adapter sizes, sometimes they will not fit snugly and will move a little. I would just find one that screws on.
I want a new shift **** too.... what kind were you looking at?
Old Sep 28, 2006 | 06:16 PM
To be honest, I only had started looking on ebay to see what options were out there. It's not the first thing I want to get done, but eventually. I saw a really cool red and black carbon fiber one I liked (I forget where I saw it), but something with red, black, & silver would look awesome with my red/black interior.
Old Sep 28, 2006 | 07:06 PM
spokenstone's Avatar
I bought the DPE shift **** and it fits perfectly like the OEM, but I switched back to the original ****. I just like the way it looks.
Old Sep 28, 2006 | 10:19 PM
BlueRenesis82's Avatar
Registered Tracker
Team Voodoo all teh way. Best ***** on the market. Get the magnum, fits the car and hands great.
Old Sep 29, 2006 | 04:26 PM
MultiSync's Avatar
Razo ***** utilize adapters but they are threaded and screw onto the shaft. I have an RA68A and the weight and shape are perfect for an RX-8.
Old Sep 29, 2006 | 04:32 PM
Ike's Avatar
Ike
Blue By You
I have the Kartboy **** on my Evo after searching for months for one I liked. I'm VERY happy with it and it should fit the RX-8 as well (check around to be sure though).
http://www.allwheelengineering.com/b..._class=KB-E001
Old Sep 29, 2006 | 06:43 PM
rglbegl's Avatar
Baned
Team VooDoo makes really nice ball shifters. They are actually for the miata, says they are the same. Never tried putting one on, but being that they are both Mazda'a .............
Old Sep 29, 2006 | 08:39 PM
Registered Tracker
i have one, as do some of the Georgia RX8 guys, and I am a big fan. Works great
Old Sep 29, 2006 | 08:56 PM
DPE's Avatar
DPE
Ours is actually a solid hunk of aluminum tapped for the thread pitch of the RX-8 shifter, so it screws on perfectly. If you want an aluminum ball-type shifter, it'll work perfectly for you. I find it better than OEM due to the fact you can comfortably use the shifter properly (with your hand on top instead of a pistol grip), but to each their own. And of course I might be a little biased .
Regards,
Phil
DPE
Old Oct 2, 2006 | 11:58 PM
coolstorm92's Avatar
Agreed. This **** looks perfect. Screws on perfectly and feels great. Only thing I wish it was a little heavier like the stock ****.
Old Oct 3, 2006 | 01:04 AM
Regards,
Phil
DPE
this gives good ****... pm me if you want some photos..
Old Oct 25, 2006 | 03:44 AM
model_no15's Avatar
I'll try to explain this the best I can. Does anyone know if there is an adapter for shift ***** that is metal. It would be used to screw into a universal shift ****. That way we can make a 12.5 mm shift **** out of any ****. Does this exist? If not does anybody know someone who can do this? I'm sure there would be a lot of interest in this product.
Old Oct 25, 2006 | 08:49 AM
Rotarctica's Avatar
I wonder...would the stock RX-8 Rotor Shaped **** fit my '86 RX-7? Me like...
Old Oct 25, 2006 | 09:07 AM
dgrx8's Avatar
FN GR8
i just ordered a team voodoo "piano black" ****... it looks real nice. i can't wait to put it on!!!
http://www.thompson-automotive.com/c...63/2029548.htm
Old Oct 25, 2006 | 01:39 PM
rglbegl's Avatar
Baned
Allright!!!! What is up with the 12.5mm????? I tried for a long time to find one, till i realized it is a 10mm. Where does the 12.5mm come from? Do I have a different tranny? Or are you all talking about a different part? I just affix a 10mm nut in any shift **** and it works great.
Old Oct 25, 2006 | 01:52 PM
Nubo's Avatar
Lubricious
To answer the original question, the OEM post dimensions are 10mm x 1.25mm thread pitch. That's probably where the "12.5" is coming from.
Old Oct 31, 2006 | 02:08 PM
dgrx8's Avatar
FN GR8
just wanted to say that my new "piano black" shift **** is KICK ***!!!!
it fits perfectly in your hand & has a nice weight to it...
theblinkof
Oct 4, 2023 05:24 PM
RX8mzda
Oct 1, 2015 10:17 PM
Quiggs321
Sep 30, 2015 05:34 PM
XianUnix
Sep 29, 2015 03:48 PM
