what is this??? wont rev past 3k!
Old Sep 27, 2006 | 06:58 PM
Jeromie's Avatar
i was on the freeway and suddenly lost power!
when i would try to rev the engine it would slowly rev to 3k then bounce like a rev limiter......????
i did the brake thing to reset the computer and it seems to fix it. this has happened 3 times already. i dont wanna take it to the dealer just yet cuz they will probly void my warranty. anybody know whats goin on????
i took a quick vid with my phone....
http://www.youtube.com/watch?v=HC-d1OAoa30
Old Sep 27, 2006 | 07:01 PM
otherside's Avatar
I dont care...
I noticed your CEL is on as well. Find out what fault code is stored, that will get you started.
Old Sep 30, 2006 | 12:45 AM
Jeromie's Avatar
the cel is on cuz i dont got a cat.... i think that answers both ur questions....
Old Sep 30, 2006 | 08:35 PM
CosmosMpower's Avatar
1935 lbs. FTW!
Put your stock parts back on, take the car to the dealer.
Old Sep 30, 2006 | 10:59 PM
Jeromie's Avatar
ahhhh i want that as a very last option. was kinda hopin someone would have an alternative.....
Old Oct 1, 2006 | 08:56 AM
Why did you disable the DSC/TSC ?
You're having MT. when was the last time yoiu've been to a dealer.
And also, they CANNOT void your warranty , but they can report you for having catless pipe. Which is a federal offence.
Tell us more details, when did the CEL came on, what were you doing before the CEL came on ? what were you doing right before your car wont be able to rev past 3K rpm.
Going on freeway suddenly lost power sounds like a .... engine replacement. Which oil do you use ? I mean engine oil. weight ?
What gas you're using ? brand, grade.
we need more information.
Did you pull the battery plug , let it seat for 5 minutes, and connect it back on see what happens ?
Old Oct 1, 2006 | 08:23 PM
Jeromie's Avatar
the cel came on when i took out the cat so if there is another code i wouldent know about it....
ok so im just ridin 6th gear about 60mph. i give it gas to pick up a lil and it slows down.... i pull over and rev the engine and it slowly revs to 3k like the vid shows....
to temporarily fix the problem i turn the car off, put the key in the on position and push the brake 20 times fast. this resets the computer and it goes back to normal... doesnt this sound more like a ecm problem???
Old Oct 1, 2006 | 09:28 PM
dtorre's Avatar
Ultimate ****** Goderator
dude put your cat back on and get the recall done before you hurt yourself or someone else!! YOu may need a new engine better to get one now then have your engine blow at 90 mph and then have you panic and kill yourself
Old Oct 1, 2006 | 10:27 PM
sounds like a dry apex seal problem... part of what the recall is about.... might put the cat back and get to the dealer.... it is new motor time...
Old Oct 1, 2006 | 10:46 PM
Mazdaspeed RX8 ver2's Avatar
Old Oct 4, 2006 | 10:23 AM
Jeromie's Avatar
holy **** i didnt think it would be that serious....
well thats kinda what i needed from u guys thanx. i will with the stock **** back on and go to the dealer....
Old Oct 9, 2006 | 01:15 PM
Jeromie's Avatar
just wanted to post one more thing my car is an 05 with only 12k miles on it. and wouldent it lose power all day if it was the engine??? i really dont think i need to go to the dealer for them to look at my cat and plugs. cant i have a friend do the vacume test????
Old Oct 9, 2006 | 01:18 PM
no dice's Avatar
I bomb atomically
You need to get the recall performed..
Swap to stock and take it in, youll probably end up with a new engine...
Old Oct 9, 2006 | 02:27 PM
agoodcave's Avatar
You know, I hate pollution control stuff as much as the next guy until.....
I visit some place outside the U.S. where they don't have strict pollution controls. It stinks!, my eyes burn, etc.
Show a little social conscience and leave the pollution control stuff hooked up. Your kids will thank you.
Flame away.
Mike
Old Oct 9, 2006 | 06:36 PM
no,
after the motor cools and restarts it will run just fine.. until you hit the right conditions again...
that is why it took so long to find the problem.. dropped mine off for a new motor this afternoon...
Old Oct 9, 2006 | 06:43 PM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
Flame away.
Mike
Agreed.
If you have to do something get a high flow cat. Your emissions will be worse but at least wont be nearly as bad as a cat delete.
Old Oct 9, 2006 | 06:47 PM
otherside's Avatar
I dont care...
Get the CEL checked, find out what code is stored. If there is a problem with the metering oil pump it will set a code. You dont want to drive around with a potential problem like that. The code stored will be a p1687 of p1688 is the MOP is suspect.
Old Oct 10, 2006 | 01:12 AM
Jeromie's Avatar
so when i put the cat back on i herd i should drive with it for a few days.... or should i just slap it on and get the car checked?
Shankapotamus3
Mar 14, 2021 03:53 PM
WranglerFan
Nov 5, 2017 09:35 AM
Ovr-9000
Apr 7, 2016 11:19 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
Jb4ker96
Sep 27, 2015 10:06 PM
